Client preventing other clients from connecting to SSID
  • 1.  Client preventing other clients from connecting to SSID
    Posted Mar 30, 2016 03:33 PM
    I have several users that are unable to connect to corporate SSID when there a particular client connected. If I blacklist the suspect client, then users are then able to connect. Once I remove from blacklist, other users lose connectivity. I repeated this test several times, and the results were consistantly the same.
  • 2.  RE: Client preventing other clients from connecting to SSID
    Posted Apr 01, 2016 01:44 PM
    Does this client use encryption?
  • 3.  RE: Client preventing other clients from connecting to SSID
    Posted Apr 07, 2016 09:02 AM
    He uses TKIP encryption if that's you mean. EAP TLS is also a requirement to connect to our ssid. I don't know much else about the client as it sits inside of a train locomotive and I do not have access.
  • 4.  RE: Client preventing other clients from connecting to SSID
    Posted Apr 07, 2016 09:04 AM
    I would do a packet capture on the channel during the incident to understand what is going on.  You are giving us very limited information.
  • 5.  RE: Client preventing other clients from connecting to SSID
    Posted Apr 07, 2016 09:12 AM
    Thank you and I understand it is difficult to troubleshoot with little information. I have to coordinate with others as the location is 1500 miles away and rely on users to let me know when train is there.
