Client request with different source IP on radius
  • 1.  Client request with different source IP on radius
    Posted Feb 26, 2018 09:43 AM
    We have Arbua 7210 WLC, AP 325, Brocade (core) switch, radius (SBR), proxy server and firewall setup for wireless network.
    WLC MGMT IP = 10.6.1.1,
    For "Employee" SSID(cert. base auth) interface ge-0/0 IP = 172.16.4.1 and
    for "Guest" SSID interface ge-0/1 IP = 192.168.50.1
    Employee and Guest SSID(cert. base auth) network is isolated from each other. Inter vlan routing is disable.
    We observed that, radius is getting all client request from WLC MGMT IP.
    How can i get client request based on respective IP subnet (NAS IP) on radius. so i can create radius client in SBR and assigned authentication policies.(Please find attached network diag.)
    Thank you..
    Attachment(s)
    pptx
    New NAS IP.pptx   33 KB 1 version
  • 2.  RE: Client request with different source IP on radius
    Posted Feb 26, 2018 03:25 PM
    By default, the controller, only uses a single interface/IP to send RADIUS requests (located on Advanced tab of Authentication).   If you need to differentiate it for your 2 SSIDs, you can setup duplicate RADIUS server entries for your SBR servers; and define your different NAS IP and/or NAS Identifier per individual server configuration.  You'd then create new Server Groups with these server entries, and apply at the AAA server level.   Keep in mind, routing must work for each NAS IP you are defining to/from RADIUS.
    See attached.
    Attachment(s)
    pdf
    dup-radius.pdf   53 KB 1 version
  • 3.  RE: Client request with different source IP on radius
    Posted Feb 27, 2018 12:43 PM
    Hi Clembo,
    As per your suggestion i have added ge-0/1 interface IP into radius server profile as a NAS IP but still we are getting client request from MGMT IP address on radius server.
    As discussed with TAC, This may be the issue of AOS version 6.5.4.3
    Can anybody test NAS IP configuration on AOS 6.5.4.3 and share the result.
    Thank you...
  • 4.  RE: Client request with different source IP on radius
    Posted Mar 01, 2018 05:20 PM
    Can you check to see if you have a line in your config for the following:
    ip radius nas-ip [controller IP]
    If so, this is probably overriding the server specific setting that I recommended.   Try removing this line from the config and see if there is any change in the behavior.
    Chris
