Not sure if I'm doing something wrong or if my syntax is just off. I'm trying to run a client session report on 3 individual MAC addresses for a specific timeframe. If I select to Filter on "Clients/Users" then I can use the "Client Search Filter". I've tried to enter multiple MAC Addresses in this line without any luck. I've tried separating by spaces, Commas or semi-colons with the same results every time. Single MAC Addresses work fine, but I can't get the right expression for multiple.
Is this even possible? I would think so but I am starting to question it.
If it makes a difference, I am on 7.6.2 currently, with plans to upgrade next week.
Any ideas or hints would be greatly appreciated. Thanks.
