client session timeout
This thread has been viewed 32 times
  • 1.  client session timeout
    Posted Jul 23, 2014 10:18 PM
    hi all,
    is there any mechanism/setting to force the client disconnect after connected 30min from aruba controller side?
    my controller model is 7210. OS is 6.3.1.2
    thanks for your advices.
    #7210
  • 2.  RE: client session timeout
    Posted Jul 24, 2014 08:27 AM
    The user idle timeout will clear the user from the user table if they are inactive for 3600 seconds by default.  This is configurable under Security > Authentication > Advanced.
    6.3 User Guide explanation:
    Maximum period after which a client is considered idle if there is no wireless traffic from the client.The timeout period is reset if there is wireless traffic. If there is no wireless traffic in the timeout period, the client is aged out. Once the timeout period has expired, the user is removed. If the keyword seconds is not specified, the value defaults to minutes at the command line.
    Range: 1 to 255 minutes (30 to 15300seconds)
    Default: 5 minutes (300 seconds)
  • 3.  RE: client session timeout
    Posted Jul 24, 2014 08:36 AM
    thx for reply.
    but is there a way force the client disconnect/reconnect again even there is wireless traffic from the client ?
  • 4.  RE: client session timeout
    Posted Jul 24, 2014 08:39 AM
    What type of network is this?
    Open, open w/ captive portal, 802.1X, PSK?
  • 5.  RE: client session timeout
    Posted Jul 24, 2014 08:44 AM
    just open
  • 6.  RE: client session timeout
    Posted Jul 25, 2014 12:33 PM
    no way force the client disconnect from aruba controller side, am i right ?
  • 7.  RE: client session timeout
    Posted Jul 25, 2014 12:49 PM
    aurbafresher what exactly do you want to do?  How do you want this to work?
  • 8.  RE: client session timeout
    Posted Jul 25, 2014 12:50 PM
    i just wait to give 30mins free wifi usage to user...then force the user disconnect...
  • 9.  RE: client session timeout
    Posted Aug 21, 2014 11:08 AM
    nope, don't think this possible without something like clearpass.
