Client stops sending packets
  • 1.  Client stops sending packets
    Posted Jul 02, 2015 12:03 PM
    Hi all.
    in the last period some clients (osx 10.10.3) in my network show a strange issue.
    Just after connecting the wifi they send about 10 pckts then the ping stops working but the client appears to be still connected to the network.
    I have a mixed environment of AP105 and AP 135 (in the same ap group) and and in 2 adiacent building I have 2 more ap group and an ap 105 per building.
    In all the ap group there is a capus wifi (802.1x - CAMPUS in the log) and a “local” wifi per AP group using WPA2 (COMPANY in the log).
    I have 2x3400 controller in master-local setup, client match disabled, arm scanning enabled, band steering on all band in “prefer-5GHz” mode and all wifi in tunnel mode.
    This the software release
    Name: Aruba Operating System Software.
    Model: Aruba3400
    Version: 6.4.2.4
    I added a client showing this issue to the client-debug and in attachment you can find the log filtered by mac address (using splunk).
    I can’t understand what is happening.
    Any advice?
    Attachment(s)
    txt
    raw_log.txt   43 KB 1 version
  • 2.  RE: Client stops sending packets
    Posted Jul 02, 2015 01:02 PM
    Alder,
    I don't have anything to make sense of these CSV logs, so I did not read them.
    How long have those clients been having this problem?
  • 3.  RE: Client stops sending packets
    Posted Jul 03, 2015 03:26 AM
    Hi cjoseph,
    you are right, I updated the attachment with the raw log filtered by mac.
    We are having the problem since about two weeks (no change in the infrastructure nor in the configuration in the meanwhile). Maybe the problem has manifested before, but I was not aware of it.
  • 4.  RE: Client stops sending packets
    Posted Jul 03, 2015 03:31 AM
    Nothing stands out in the logs.
    Are these the only clients that do not work? Can you upgrade one of them?.
  • 5.  RE: Client stops sending packets
    Posted Jul 03, 2015 03:49 AM
    Do you have the output of "show ap active" on the controller?
  • 6.  RE: Client stops sending packets
    Posted Jul 03, 2015 03:53 AM
    Here you are with the result of the command issued on both the controllers
    (LOCAL Controller) #show ap active
    Active AP Table
    Name                 Group                     IP Address   11g Clients  11g Ch/EIRP/MaxEIRP  11a Clients  11a Ch/EIRP/MaxEIRP  AP Type  Flags  Uptime           Outer IP
    Serra_EE             Serra                     10.1.97.128  5            AP:HT:1/19/19        5            AP:HT:36+/22/22      135      Aa     5d:3h:13m:44s    N/A
    Serra_SW             Serra                     10.1.97.129  4            AP:HT:1/19/19        22           AP:HT:44+/22/22      135      Aa     5d:3h:13m:44s    N/A
    Serra_SE             Serra                     10.1.97.130  16           AP:HT:1/19/19        11           AP:HT:44+/22/22      135      Aa     5d:3h:13m:44s    N/A
    Serra_NW             Serra                     10.1.97.131  2            AP:HT:6/19/19        2            AP:HT:60+/22/22      135      Aa     5d:3h:13m:44s    N/A
    Operation_SW         Tacchinodromo_operativo   10.1.97.142  5            AP:HT:11/19/19       0            AP:HT:40-/22/22      135      Aa     30d:14h:38m:38s  N/A
    Giardino_Pad-C       Esterni_Farm              10.1.97.145  3            AP:HT:11/19/19       2            AP:HT:60+/20/20      134      Aa     5d:3h:13m:45s    N/A
    Foresteria-P0_S      Foresteria                10.1.97.148  5            AP:HT:6/19/19        1            AP:HT:40-/22/22      135      Aa     5d:3h:13m:41s    N/A
    Operation_SE         Tacchinodromo_operativo   10.1.97.150  5            AP:HT:6/19/19        39           AP:HT:44+/22/22      135      Aa     30d:14h:38m:43s  N/A
    Operation_NE         Tacchinodromo_operativo   10.1.97.151  2            AP:HT:11/19/19       15           AP:HT:60+/22/22      135      Aa     30d:14h:38m:39s  N/A
    Tenuta_Casetta       Tenuta                    10.1.97.152  0            AP:HT:11/19/19       0            AP:HT:36+/22/22      135      Aa     1d:9h:39m:1s     N/A
    Operation_NW         Tacchinodromo_operativo   10.1.97.153  3            AP:HT:11/19/19       36           AP:HT:40-/22/22      135      Aa     30d:14h:38m:36s  N/A
    Tenuta_P0            Tenuta                    10.1.97.154  0            AP:HT:11/19/19       0            AP:HT:40-/22/22      135      Aa     1d:9h:39m:1s     N/A
    Tenuta_P1            Tenuta                    10.1.97.155  0            AP:HT:1/19/19        1            AP:HT:52+/22/22      135      Aa     1d:9h:36m:52s    N/A
    Direzionale_NN       Tacchinodromo_direzione   10.1.97.158  17           AP:HT:1/19/19        4            AP:VHT:60+/20/20     205      a      30d:14h:38m:27s  N/A
    Direzionale_SW       Tacchinodromo_direzione   10.1.97.159  4            AP:HT:1/19/19        2            AP:VHT:36+/22/22     205      a      30d:14h:38m:29s  N/A
    Direzionale_SE       Tacchinodromo_direzione   10.1.97.160  4            AP:HT:6/19/19        1            AP:VHT:44+/20/20     205      a      30d:14h:38m:30s  N/A
    Conference_SE        Tacchinodromo_Conference  10.1.97.161  0            AP:HT:1/19/19        0            AP:HT:36+/22/22      135      Aa     14d:23h:18m:13s  N/A
    Conference_SW        Tacchinodromo_Conference  10.1.97.164  0            AP:HT:11/19/19       1            AP:HT:52+/22/22      135      Aa     14d:23h:15m:2s   N/A
    Conference_NW        Tacchinodromo_Conference  10.1.97.165  0            AP:HT:6/19/19        0            AP:HT:36+/22/22      135      Aa     14d:23h:6m:27s   N/A
    Conference_NE        Tacchinodromo_Conference  10.1.97.166  0            AP:HT:11/19/19       0            AP:HT:40-/22/22      135      Aa     14d:23h:1m:50s   N/A
    Conference_Ingresso  Tacchinodromo_Conference  10.1.97.167  1            AP:HT:1/19/19        0            AP:HT:52+/22/22      135      Aa     14d:22h:55m:34s  N/A
    Pad-H_SW             Padiglione_H              10.1.97.103  1            AP:HT:1/19/19        16           AP:HT:36+/22/22      135      Aa     76d:17h:26m:16s  N/A
    Pad-H_NE             Padiglione_H              10.1.97.105  1            AP:HT:6/19/19        3            AP:HT:52+/22/22      135      Aa     76d:17h:27m:3s   N/A
    Casone_P2_WW         Casone_P2                 10.1.97.110  4            AP:HT:6/19/19        6            AP:VHT:52+/22/22     205      a      132d:5h:20m:12s  N/A
    Pad-H_SE             Padiglione_H              10.1.97.111  4            AP:HT:11/19/19       19           AP:HT:44+/22/22      135      Aa     73d:23h:35m:17s  N/A
    Giardino_Pad-G       Esterni_Farm              10.1.97.114  0            AP:HT:1/19/19        0            AP:HT:44+/20/20      134      Aa     76d:16h:51m:7s   N/A
    Pad-H_NW             Padiglione_H              10.1.97.116  1            AP:HT:1/19/19        5            AP:HT:60+/22/22      135      Aa     76d:17h:27m:11s  N/A
    Casone_P2_EST        Casone_P2                 10.1.97.125  10           AP:HT:1/19/19        11           AP:HT:40-/22/22      135      Aa     36d:18h:14m:34s  N/A
    Flags: 1 = 802.1x authenticated AP; 2 = Using IKE version 2;
           A = Enet1 in active/standby mode;  B = Battery Boost On; C = Cellular;
           D = Disconn. Extra Calls On; E = Wired AP enabled; F = AP failed 802.1x authentication;
           H = Hotspot Enabled; K = 802.11K Enabled; L = Client Balancing Enabled; M = Mesh;
           N = 802.11b protection disabled; P = PPPOE; R = Remote AP;
           S = AP connected as standby; X = Maintenance Mode;
           a = Reduce ARP packets in the air; d = Drop Mcast/Bcast On; u = Custom-Cert RAP;
           r = 802.11r Enabled
    Channel followed by "*" indicates channel selected due to unsupported configured channel.
    "Spectrum" followed by "^" indicates Local Spectrum Override in effect.
    Num APs:28
    (MASTER Controller) #show ap active
    Active AP Table
    Village_10       Village_10    10.1.97.132  4            AP:HT:11/19/19       0            AP:HT:52+/22/22      105      a      3d:16h:31m:6s    N/A
    Reception        Reception     10.1.97.133  0            AP:HT:6/19/19        2            AP:HT:40-/22/22      105      a      5d:3h:12m:54s    N/A
    Pollaio_P0_WW    Pollaio_P0    10.1.97.134  4            AP:HT:1/19/19        10           AP:VHT:40-/20/20     205      a      5d:3h:12m:39s    N/A
    Convivium_1      Convivium     10.1.97.135  0            AP:HT:11/19/19       1            AP:HT:48-/22/22      135      Aa     5d:3h:13m:12s    N/A
    Pollaio_P1_WW    Pollaio_P1    10.1.97.136  9            AP:HT:11/19/19       14           AP:VHT:44+/20/20     205      a      5d:3h:12m:41s    N/A
    Pollaio_P1_EE    Pollaio_P1    10.1.97.137  0            AP:HT:1/19/19        6            AP:VHT:52+/22/22     205      a      5d:3h:12m:40s    N/A
    Pollaio_P0_EE    Pollaio_P0    10.1.97.138  0            AP:HT:11/19/19       0            AP:VHT:60+/20/20     205      a      5d:3h:12m:38s    N/A
    Pad-I_NW         Padiglione_I  10.1.97.139  3            AP:HT:1/19/19        14           AP:HT:36+/22/22      135      Aa     5d:3h:13m:15s    N/A
    Pad-I_EE         Padiglione_I  10.1.97.140  9            AP:HT:11/19/19       21           AP:HT:48-/22/22      135      Aa     5d:3h:13m:16s    N/A
    Pad-C_WW         Padiglione_C  10.1.97.141  2            AP:HT:6/19/19        10           AP:HT:52+/22/22      135      Aa     5d:3h:13m:14s    N/A
    Pad-I_SW         Padiglione_I  10.1.97.143  5            AP:HT:6/19/19        14           AP:HT:60+/22/22      135      Aa     5d:3h:13m:15s    N/A
    Pad-C_NN         Padiglione_C  10.1.97.144  5            AP:HT:1/19/19        4            AP:HT:44+/22/22      135      Aa     5d:3h:13m:14s    N/A
    Pad-C_SS         Padiglione_C  10.1.97.146  2            AP:HT:6/19/19        7            AP:HT:36+/22/22      135      Aa     5d:3h:13m:13s    N/A
    Pad-C_EE         Padiglione_C  10.1.97.147  7            AP:HT:11/19/19       20           AP:HT:60+/22/22      135      Aa     19h:22m:47s      N/A
    Village_6_       Village_6     10.1.97.149  1            AP:HT:6/19/19        4            AP:HT:52+/22/22      105      a      19d:23h:53m:48s  N/A
    Village_8        Village_8     10.1.97.100  2            AP:HT:6/19/19        5            AP:HT:48-/22/22      105      a      19d:23h:53m:48s  N/A
    Village_11       Village_11    10.1.97.101  2            AP:HT:11/19/19       1            AP:HT:40-/22/22      105      a      19d:23h:53m:45s  N/A
    Pad-G_WW         Padiglione_G  10.1.97.102  3            AP:HT:11/19/19       1            AP:HT:52+/22/22      135      Aa     38d:22h:52m:55s  N/A
    Casone_P1_NW     Casone_P1     10.1.97.104  1            AP:HT:1/19/19        3            AP:VHT:60+/22/22     205      a      132d:5h:18m:2s   N/A
    Casone_P1_WW     Casone_P1     10.1.97.106  7            AP:HT:6/19/19        0            AP:VHT:44+/20/20     205      a      132d:5h:17m:54s  N/A
    Casone_P1_Silos  Casone_P1     10.1.97.107  4            AP:HT:1/19/19        8            AP:VHT:52+/22/22     205      a      9d:22h:44m:41s   N/A
    Village_4        Village_4     10.1.97.108  3            AP:HT:1/19/19        7            AP:HT:40-/22/22      105      a      2d:18h:26m:57s   N/A
    Casone_P0_WW     Casone_P0     10.1.97.109  1            AP:HT:11/19/19       7            AP:VHT:36+/22/22     205      a      98d:23h:41m:57s  N/A
    Village_1        Village_1     10.1.97.112  1            AP:HT:11/19/19       2            AP:HT:48-/22/22      105      a      3d:17h:2m:29s    N/A
    Village_5        Village_5     10.1.97.113  0            AP:HT:1/19/19        0            AP:HT:60+/22/22      105      a      3d:16h:52m:51s   N/A
    Village_13       Village_13    10.1.97.115  0            AP:HT:1/19/19        0            AP:HT:60+/22/22      105      a      19d:23h:53m:44s  N/A
    Village_12       Village_12    10.1.97.117  0            AP:HT:6/19/19        0            AP:HT:44+/22/22      105      a      3d:16h:44m:27s   N/A
    Village_2        Village_2     10.1.97.118  0            AP:HT:1/19/19        6            AP:HT:52+/22/22      105      a      3d:16h:14m:59s   N/A
    Pad-G_SE         Padiglione_G  10.1.97.119  3            AP:HT:6/19/19        1            AP:HT:40-/22/22      135      Aa     38d:23h:12m:54s  N/A
    Pad-G_NE         Padiglione_G  10.1.97.120  6            AP:HT:11/19/19       5            AP:HT:36+/22/22      135      Aa     38d:23h:53m:0s   N/A
    Pad-G_NN         Padiglione_G  10.1.97.121  5            AP:HT:6/19/19        13           AP:HT:48-/22/22      105      a      76d:16h:40m:34s  N/A
    Village_3        Village_3     10.1.97.123  0            AP:HT:11/19/19       3            AP:HT:48-/22/22      105      a      19d:23h:53m:50s  N/A
    Village_9        Village_9     10.1.97.124  1            AP:HT:1/19/19        0            AP:HT:52+/22/22      105      a      19d:23h:53m:45s  N/A
    Casone_P1_EE     Casone_P1     10.1.97.126  4            AP:HT:11/19/19       40           AP:HT:52+/22/22      135      Aa     38d:23h:56m:43s  N/A
    Casone_P0_EST    Casone_P0     10.1.97.127  7            AP:HT:1/19/19        10           AP:HT:44+/22/22      135      Aa     79d:15h:45m:59s  N/A
           r = 802.11r Enabled
    Num APs:35
  • 7.  RE: Client stops sending packets
    Posted Jul 03, 2015 04:01 AM
    You have one big problem:
    - Your access points are at full power, so you will have considerable roaming issues
    - You have 80mhz channels enabled, so you have significant RF issues.
    Here is how to fix this:
    Go to configuration> Wireless> AP Configuration.  Click on one ap-group.
    Expand RF Mangement.  Expand 802.11a radio.  Click on Adaptive Radio Management.
    In the center pane, make the adjustments like below and click on apply:
  • 8.  RE: Client stops sending packets
    Posted Jul 03, 2015 04:20 AM
    Ok, done, below my actual configuration for A band. I have the same arm A radio profile for all the campus.
    below the G radio profile, do you think is that ok? Considering the minor propagation in 5GHz band
  • 9.  RE: Client stops sending packets
    Posted Jul 03, 2015 04:22 AM
    Change the G ARM profile to the same settings.  After you do that, please send the output of "show ap active"
  • 10.  RE: Client stops sending packets
    Posted Jul 03, 2015 04:37 AM
    Ok, done!
    Active AP Table
    Serra_EE             Serra                     10.1.97.128  2            AP:HT:1/18/19        1            AP:HT:56/18/22       135      Aa     5d:3h:56m:35s    N/A
    Serra_SW             Serra                     10.1.97.129  6            AP:HT:1/18/19        7            AP:HT:52/15/22       135      Aa     5d:3h:56m:35s    N/A
    Serra_SE             Serra                     10.1.97.130  8            AP:HT:1/18/19        5            AP:HT:36/18/22       135      Aa     5d:3h:56m:35s    N/A
    Serra_NW             Serra                     10.1.97.131  3            AP:HT:6/18/19        3            AP:HT:36/15/22       135      Aa     5d:3h:56m:35s    N/A
    Operation_SW         Tacchinodromo_operativo   10.1.97.142  4            AP:HT:11/18/19       33           AP:HT:48/18/22       135      Aa     30d:15h:21m:29s  N/A
    Giardino_Pad-C       Esterni_Farm              10.1.97.145  5            AP:HT:11/18/19       4            AP:HT:64/18/20       134      Aa     5d:3h:56m:36s    N/A
    Foresteria-P0_S      Foresteria                10.1.97.148  3            AP:HT:6/18/19        1            AP:HT:48/18/22       135      Aa     5d:3h:56m:32s    N/A
    Operation_SE         Tacchinodromo_operativo   10.1.97.150  24           AP:HT:6/18/19        12           AP:HT:52/18/22       135      Aa     30d:15h:21m:34s  N/A
    Operation_NE         Tacchinodromo_operativo   10.1.97.151  30           AP:HT:11/18/19       8            AP:HT:52/15/22       135      Aa     30d:15h:21m:30s  N/A
    Tenuta_Casetta       Tenuta                    10.1.97.152  0            AP:HT:11/18/19       0            AP:HT:48/18/22       135      Aa     1d:10h:21m:52s   N/A
    Operation_NW         Tacchinodromo_operativo   10.1.97.153  21           AP:HT:11/12/19       3            AP:HT:36/18/22       135      Aa     30d:15h:21m:27s  N/A
    Tenuta_P0            Tenuta                    10.1.97.154  0            AP:HT:1/18/19        0            AP:HT:36/18/22       135      Aa     1d:10h:21m:52s   N/A
    Tenuta_P1            Tenuta                    10.1.97.155  0            AP:HT:6/18/19        0            AP:HT:48/18/22       135      Aa     1d:10h:19m:43s   N/A
    Direzionale_NN       Tacchinodromo_direzione   10.1.97.158  12           AP:HT:1/18/19        4            AP:VHT:52/18/21      205      a      30d:15h:21m:18s  N/A
    Direzionale_SW       Tacchinodromo_direzione   10.1.97.159  7            AP:HT:1/18/19        3            AP:VHT:36/18/21      205      a      30d:15h:21m:20s  N/A
    Direzionale_SE       Tacchinodromo_direzione   10.1.97.160  6            AP:HT:6/18/19        1            AP:VHT:52/18/21      205      a      30d:15h:21m:21s  N/A
    Conference_SE        Tacchinodromo_Conference  10.1.97.161  1            AP:HT:1/18/19        1            AP:HT:40/18/22       135      Aa     15d:0h:1m:4s     N/A
    Conference_SW        Tacchinodromo_Conference  10.1.97.164  0            AP:HT:11/18/19       0            AP:HT:56/18/22       135      Aa     14d:23h:57m:53s  N/A
    Conference_NW        Tacchinodromo_Conference  10.1.97.165  0            AP:HT:6/18/19        0            AP:HT:64/18/22       135      Aa     14d:23h:49m:18s  N/A
    Conference_NE        Tacchinodromo_Conference  10.1.97.166  0            AP:HT:11/18/19       0            AP:HT:36/18/22       135      Aa     14d:23h:44m:41s  N/A
    Conference_Ingresso  Tacchinodromo_Conference  10.1.97.167  1            AP:HT:1/18/19        0            AP:HT:48/18/22       135      Aa     14d:23h:38m:25s  N/A
    Pad-H_SW             Padiglione_H              10.1.97.103  10           AP:HT:1/18/19        7            AP:HT:36/18/22       135      Aa     76d:18h:9m:7s    N/A
    Pad-H_NE             Padiglione_H              10.1.97.105  4            AP:HT:6/18/19        3            AP:HT:56/18/22       135      Aa     76d:18h:9m:54s   N/A
    Casone_P2_WW         Casone_P2                 10.1.97.110  4            AP:HT:6/18/19        4            AP:VHT:48/18/21      205      a      132d:6h:3m:3s    N/A
    Pad-H_SE             Padiglione_H              10.1.97.111  3            AP:HT:11/18/19       19           AP:HT:48/18/22       135      Aa     74d:0h:18m:8s    N/A
    Giardino_Pad-G       Esterni_Farm              10.1.97.114  1            AP:HT:1/18/19        0            AP:HT:44/18/20       134      Aa     76d:17h:33m:58s  N/A
    Pad-H_NW             Padiglione_H              10.1.97.116  3            AP:HT:1/18/19        3            AP:HT:64/18/22       135      Aa     76d:18h:10m:2s   N/A
    Casone_P2_EST        Casone_P2                 10.1.97.125  15           AP:HT:1/18/19        8            AP:HT:36/18/22       135      Aa     36d:18h:57m:25s  N/A
           r = 802.11r Enabled
    Num APs:28
    Active AP Table
    Village_10       Village_10    10.1.97.132  1            AP:HT:11/18/19       0            AP:HT:56/18/22       105      a      3d:17h:14m:14s   N/A
    Reception        Reception     10.1.97.133  0            AP:HT:6/18/19        3            AP:HT:48/18/22       105      a      5d:3h:56m:2s     N/A
    Pollaio_P0_WW    Pollaio_P0    10.1.97.134  4            AP:HT:1/18/19        6            AP:VHT:36/18/21      205      a      5d:3h:55m:47s    N/A
    Convivium_1      Convivium     10.1.97.135  2            AP:HT:11/18/19       1            AP:HT:52/18/22       135      Aa     5d:3h:56m:20s    N/A
    Pollaio_P1_WW    Pollaio_P1    10.1.97.136  12           AP:HT:11/18/19       17           AP:VHT:48/18/21      205      a      5d:3h:55m:49s    N/A
    Pollaio_P1_EE    Pollaio_P1    10.1.97.137  0            AP:HT:1/18/19        2            AP:VHT:36/18/21      205      a      5d:3h:55m:48s    N/A
    Pollaio_P0_EE    Pollaio_P0    10.1.97.138  6            AP:HT:11/18/19       4            AP:VHT:64/18/21      205      a      5d:3h:55m:46s    N/A
    Pad-I_NW         Padiglione_I  10.1.97.139  1            AP:HT:1/18/19        18           AP:HT:40/18/22       135      Aa     5d:3h:56m:23s    N/A
    Pad-I_EE         Padiglione_I  10.1.97.140  15           AP:HT:11/18/19       22           AP:HT:52/18/22       135      Aa     5d:3h:56m:24s    N/A
    Pad-C_WW         Padiglione_C  10.1.97.141  3            AP:HT:6/18/19        21           AP:HT:48/18/22       135      Aa     5d:3h:56m:22s    N/A
    Pad-I_SW         Padiglione_I  10.1.97.143  9            AP:HT:6/18/19        16           AP:HT:56/18/22       135      Aa     5d:3h:56m:23s    N/A
    Pad-C_NN         Padiglione_C  10.1.97.144  1            AP:HT:11/18/19       3            AP:HT:40/18/22       135      Aa     5d:3h:56m:22s    N/A
    Pad-C_SS         Padiglione_C  10.1.97.146  1            AP:HT:6/18/19        4            AP:HT:40/18/22       135      Aa     5d:3h:56m:21s    N/A
    Pad-C_EE         Padiglione_C  10.1.97.147  16           AP:HT:11/18/19       10           AP:HT:64/18/22       135      Aa     20h:5m:55s       N/A
    Village_6_       Village_6     10.1.97.149  3            AP:HT:6/18/19        1            AP:HT:60/18/22       105      a      20d:0h:36m:56s   N/A
    Village_8        Village_8     10.1.97.100  5            AP:HT:6/18/19        1            AP:HT:36/18/22       105      a      20d:0h:36m:56s   N/A
    Village_11       Village_11    10.1.97.101  2            AP:HT:11/18/19       4            AP:HT:56/18/22       105      a      20d:0h:36m:53s   N/A
    Pad-G_WW         Padiglione_G  10.1.97.102  1            AP:HT:11/18/19       2            AP:HT:56/18/22       135      Aa     38d:23h:36m:3s   N/A
    Casone_P1_NW     Casone_P1     10.1.97.104  7            AP:HT:1/18/19        1            AP:VHT:56/18/21      205      a      132d:6h:1m:10s   N/A
    Casone_P1_WW     Casone_P1     10.1.97.106  5            AP:HT:11/18/19       11           AP:VHT:40/18/21      205      a      132d:6h:1m:2s    N/A
    Casone_P1_Silos  Casone_P1     10.1.97.107  5            AP:HT:1/18/19        8            AP:VHT:48/18/21      205      a      9d:23h:27m:49s   N/A
    Village_4        Village_4     10.1.97.108  3            AP:HT:1/18/19        8            AP:HT:36/18/22       105      a      2d:19h:10m:5s    N/A
    Casone_P0_WW     Casone_P0     10.1.97.109  10           AP:HT:11/18/19       8            AP:VHT:52/18/21      205      a      99d:0h:25m:5s    N/A
    Village_1        Village_1     10.1.97.112  1            AP:HT:11/18/19       2            AP:HT:48/18/22       105      a      3d:17h:45m:37s   N/A
    Village_5        Village_5     10.1.97.113  0            AP:HT:1/18/19        0            AP:HT:36/18/22       105      a      3d:17h:35m:59s   N/A
    Village_13       Village_13    10.1.97.115  0            AP:HT:1/18/19        0            AP:HT:52/18/22       105      a      20d:0h:36m:52s   N/A
    Village_12       Village_12    10.1.97.117  0            AP:HT:6/18/19        0            AP:HT:36/18/22       105      a      3d:17h:27m:35s   N/A
    Village_2        Village_2     10.1.97.118  0            AP:HT:1/18/19        5            AP:HT:36/18/22       105      a      3d:16h:58m:7s    N/A
    Pad-G_SE         Padiglione_G  10.1.97.119  5            AP:HT:6/18/19        3            AP:HT:64/18/22       135      Aa     38d:23h:56m:2s   N/A
    Pad-G_NE         Padiglione_G  10.1.97.120  10           AP:HT:11/18/19       2            AP:HT:64/18/22       135      Aa     39d:0h:36m:8s    N/A
    Pad-G_NN         Padiglione_G  10.1.97.121  6            AP:HT:6/18/19        10           AP:HT:36/18/22       105      a      76d:17h:23m:42s  N/A
    Village_3        Village_3     10.1.97.123  2            AP:HT:11/18/19       4            AP:HT:36/18/22       105      a      20d:0h:36m:58s   N/A
    Village_9        Village_9     10.1.97.124  1            AP:HT:1/18/19        4            AP:HT:48/18/22       105      a      20d:0h:36m:53s   N/A
    Casone_P1_EE     Casone_P1     10.1.97.126  5            AP:HT:11/18/19       44           AP:HT:48/18/22       135      Aa     39d:0h:39m:51s   N/A
    Casone_P0_EST    Casone_P0     10.1.97.127  11           AP:HT:1/18/19        4            AP:HT:36/18/22       135      Aa     79d:16h:29m:7s   N/A
           r = 802.11r Enabled
    Num APs:35
  • 11.  RE: Client stops sending packets
    Posted Jul 03, 2015 04:44 AM
    Okay.  You should test the roaming.  How many SSIDs do you have?  (show ap essid)
  • 12.  RE: Client stops sending packets
    Posted Jul 03, 2015 05:26 AM
    I Have 24 ESSID on the master and 11 in the local controller.
    I tried moving from my desk (AP 135) to another office (AP 205) in the same building and same floor (2 ap at all, same ap group) and I lost connection and had to disable and re-enable the wifi to reconnect. Just after beeing reconnected I stopped making traffic as you can see in the screenshot below from the ping:
    I also tried to disconnect and reconnect a few times with the same result.
    The fourth time I tried I finally got a stable connection.
    When I moved back to my desk instead the roaming worked fine.
    It seems the problem is related to areas covered by access point model Ap 105 and AP 205
  • 13.  RE: Client stops sending packets
    Posted Jul 03, 2015 05:30 AM
    Do you have "Drop Broadcast and Multicast" enabled on all of your Virtual APs?
    What is the output of "show ap radio-summary"?
  • 14.  RE: Client stops sending packets
    Posted Jul 03, 2015 06:09 AM
    No (this is the 802.1x vap)
    and this the output of show ap radio-summary
    LOCAL
    APs Radios information
    Name                 Group                     AP Type  IP Address   Band  Mode       EIRP/MaxEIRP  NF/U/I     TD                 TM           TC
    Tenuta_P1            Tenuta                    135      10.1.97.155  2.4   AP:HT:11   18/19         -91/1/0    0/0/0/0/0/0        0/0/0/0/0/0  0/0/0/0/0/0
    Tenuta_P0            Tenuta                    135      10.1.97.154  2.4   AP:HT:1    18/19         -95/1/1    0/0/0/0/0/0        0/0/0/0/0/0  0/0/0/0/0/0
    Tenuta_Casetta       Tenuta                    135      10.1.97.152  2.4   AP:HT:11   18/19         -88/7/7    0/0/0/0/0/0        0/0/0/0/0/0  0/0/0/0/0/0
    Foresteria-P0_S      Foresteria                135      10.1.97.148  2.4   AP:HT:6    18/19         -88/1/1    0/0/0/0/0/0        0/0/0/0/0/0  0/0/0/0/0/0
    Serra_NW             Serra                     135      10.1.97.131  2.4   AP:HT:6    18/19         -91/1/0    0/0/0/0/0/0        0/0/0/0/0/0  0/0/0/0/0/0
    Serra_SE             Serra                     135      10.1.97.130  2.4   AP:HT:1    12/19         -94/3/1    2/0/0/0/0/0        0/0/0/0/0/0  0/0/0/2/0/0
    Serra_SW             Serra                     135      10.1.97.129  2.4   AP:HT:1    18/19         -95/3/1    1/2/0/0/0/0        0/0/0/0/0/0  0/0/0/0/2/0
    Serra_EE             Serra                     135      10.1.97.128  2.4   AP:HT:11   18/19         -89/4/1    0/2/0/0/0/0        0/0/0/0/1/0  1/2/2/1/1/1
    Giardino_Pad-C       Esterni_Farm              134      10.1.97.145  2.4   AP:HT:11   18/19         -91/14/2   6/4/3/1/2/1        4/5/5/4/4/4  4/4/5/3/4/4
    Conference_NW        Tacchinodromo_Conference  135      10.1.97.165  2.4   AP:HT:6    18/19         -95/0/0    0/0/0/0/0/0        0/0/0/0/0/0  0/0/0/0/0/0
    Conference_SE        Tacchinodromo_Conference  135      10.1.97.161  2.4   AP:HT:1    18/19         -94/1/1    0/0/0/0/0/0        0/0/0/0/0/0  0/0/0/0/0/0
    Conference_Ingresso  Tacchinodromo_Conference  135      10.1.97.167  2.4   AP:HT:1    18/19         -93/1/1    0/0/0/0/0/0        0/0/0/0/0/0  0/0/0/0/0/0
    Conference_NE        Tacchinodromo_Conference  135      10.1.97.166  2.4   AP:HT:11   18/19         -85/1/1    0/0/0/0/0/0        0/0/0/0/0/0  0/0/0/0/0/0
    Conference_SW        Tacchinodromo_Conference  135      10.1.97.164  2.4   AP:HT:6    18/19         -88/1/1    0/0/0/0/0/0        0/0/0/0/0/0  0/0/0/0/0/0
    Direzionale_SE       Tacchinodromo_direzione   205      10.1.97.160  2.4   AP:HT:6    18/19         -97/7/2    2/1/1/0/1/5        0/0/0/0/0/1  4/5/0/1/2/1
    Casone_P2_WW         Casone_P2                 205      10.1.97.110  2.4   AP:HT:6    18/19         -97/5/2    0/1/0/0/0/0        0/1/1/0/1/0  0/0/0/0/0/0
    Pad-H_NE             Padiglione_H              135      10.1.97.105  2.4   AP:HT:6    18/19         -94/14/2   44/15/0/0/0/0      0/0/0/0/0/0  1/0/0/0/0/0
    Pad-H_NW             Padiglione_H              135      10.1.97.116  2.4   AP:HT:1    18/19         -94/20/4   3/4/20/22/2/2      1/1/1/2/1/2  1/1/6/5/1/1
    Operation_SE         Tacchinodromo_operativo   135      10.1.97.150  2.4   AP:HT:6    18/19         -94/25/8   14/23/2/3/5/8      1/1/1/1/1/1  5/7/0/1/3/1
    Direzionale_NN       Tacchinodromo_direzione   205      10.1.97.158  2.4   AP:HT:1    18/19         -97/60/10  18/21/17/18/17/17  1/1/1/1/1/1  9/7/8/9/9/8
    Direzionale_SW       Tacchinodromo_direzione   205      10.1.97.159  2.4   AP:HT:1    18/19         -97/53/7   23/32/33/33/36/36  1/1/1/1/1/1  7/10/12/17/15/10
    Pad-H_SW             Padiglione_H              135      10.1.97.103  2.4   AP:HT:1    18/19         -96/20/2   2/3/4/7/5/1        1/1/1/2/1/1  2/2/8/9/5/2
    Operation_SW         Tacchinodromo_operativo   135      10.1.97.142  2.4   AP:HT:11   18/19         -88/23/4   5/2/3/2/5/4        3/4/2/3/4/4  9/7/7/5/7/7
    Operation_NE         Tacchinodromo_operativo   135      10.1.97.151  2.4   AP:HT:11   18/19         -87/25/6   12/7/6/8/9/6       2/2/2/2/2/2  8/5/4/5/3/4
    Operation_NW         Tacchinodromo_operativo   135      10.1.97.153  2.4   AP:HT:11   12/19         -89/24/2   12/6/4/6/7/7       2/2/2/1/2/1  12/6/4/9/5/7
    Pad-H_SE             Padiglione_H              135      10.1.97.111  2.4   AP:HT:11   18/19         -89/13/7   4/2/0/0/0/0        3/2/2/2/2/2  1/2/0/0/0/0
    Casone_P2_EST        Casone_P2                 135      10.1.97.125  2.4   AP:HT:1    18/19         -94/86/5   70/72/70/70/71/71  0/0/0/1/1/0  3/3/3/3/3/3
    Giardino_Pad-G       Esterni_Farm              134      10.1.97.114  2.4   AP:HT:1    18/19         -95/0/0    0/0/0/0/0/0        0/0/0/0/0/0  0/0/0/0/0/0
    Tenuta_P1            Tenuta                    135      10.1.97.155  5     AP:HT:48   18/22         -96/0/0    0/0/0/0/0/0        0/0/0/0/0/0  0/0/0/0/0/0
    Tenuta_P0            Tenuta                    135      10.1.97.154  5     AP:HT:36   18/22         -96/0/0    0/0/0/0/0/0        0/0/0/0/0/0  0/0/0/0/0/0
    Tenuta_Casetta       Tenuta                    135      10.1.97.152  5     AP:HT:48   18/22         -91/0/0    0/0/0/0/0/0        0/0/0/0/0/0  0/0/0/0/0/0
    Foresteria-P0_S      Foresteria                135      10.1.97.148  5     AP:HT:48   18/22         -96/0/0    0/0/0/0/0/0        0/0/0/0/0/0  0/0/0/0/0/0
    Serra_NW             Serra                     135      10.1.97.131  5     AP:HT:64   18/22         -95/0/0    0/0/0/0/0/0        0/0/0/0/0/0  0/0/0/0/0/0
    Serra_SE             Serra                     135      10.1.97.130  5     AP:HT:36   18/22         -95/1/0    1/0/0/0/0/0        0/0/0/0/0/0  0/0/0/0/2/0
    Serra_SW             Serra                     135      10.1.97.129  5     AP:HT:48   18/22         -96/5/1    1/3/0/0/0/0        0/0/0/0/0/0  1/3/3/3/3/3
    Serra_EE             Serra                     135      10.1.97.128  5     AP:HT:56   18/22         -87/0/0    0/0/0/0/0/0        0/0/0/0/0/0  0/0/0/0/0/0
    Giardino_Pad-C       Esterni_Farm              134      10.1.97.145  5     AP:HT:64   18/20         -96/11/0   1/2/2/0/0/0        1/4/2/5/4/1  2/2/2/4/3/0
    Conference_NW        Tacchinodromo_Conference  135      10.1.97.165  5     AP:HT:64   18/22         -96/0/0    0/0/0/0/0/0        0/0/0/0/0/0  0/0/0/0/0/0
    Conference_SE        Tacchinodromo_Conference  135      10.1.97.161  5     AP:HT:40   18/22         -94/1/0    0/0/0/0/0/0        0/0/0/0/0/0  0/0/0/0/0/0
    Conference_Ingresso  Tacchinodromo_Conference  135      10.1.97.167  5     AP:HT:48   18/22         -92/0/0    0/0/0/0/0/0        0/0/0/0/0/0  0/0/0/0/0/0
    Conference_NE        Tacchinodromo_Conference  135      10.1.97.166  5     AP:HT:36   18/22         -95/0/0    0/0/0/0/0/0        0/0/0/0/0/0  0/0/0/0/0/0
    Conference_SW        Tacchinodromo_Conference  135      10.1.97.164  5     AP:HT:56   18/22         -95/0/0    0/0/0/0/0/0        0/0/0/0/0/0  0/0/0/0/0/0
    Direzionale_SE       Tacchinodromo_direzione   205      10.1.97.160  5     AP:VHT:52  18/21         -97/54/3   3/1/2/11/20/25     0/0/0/0/0/0  1/0/4/5/6/6
    Casone_P2_WW         Casone_P2                 205      10.1.97.110  5     AP:VHT:48  18/21         -97/4/0    0/0/0/0/0/0        0/0/0/0/0/0  0/0/0/0/0/0
    Pad-H_NE             Padiglione_H              135      10.1.97.105  5     AP:HT:52   18/22         -94/1/0    0/0/0/0/0/0        0/0/0/0/0/0  0/0/0/0/0/0
    Pad-H_NW             Padiglione_H              135      10.1.97.116  5     AP:HT:64   18/22         -96/1/0    0/0/0/0/0/0        0/0/0/0/0/0  0/0/0/0/0/0
    Operation_SE         Tacchinodromo_operativo   135      10.1.97.150  5     AP:HT:52   18/22         -95/25/2   12/23/26/12/5/7    0/0/0/0/0/0  2/4/9/6/1/4
    Direzionale_NN       Tacchinodromo_direzione   205      10.1.97.158  5     AP:VHT:52  18/21         -85/58/37  4/20/22/2/1/1      0/0/0/0/0/0  3/6/10/9/12/12
    Direzionale_SW       Tacchinodromo_direzione   205      10.1.97.159  5     AP:VHT:36  18/21         -97/1/0    0/0/0/0/0/0        0/0/0/0/0/0  0/0/0/0/0/0
    Pad-H_SW             Padiglione_H              135      10.1.97.103  5     AP:HT:36   18/22         -94/7/1    11/2/4/3/2/0       0/0/0/0/0/0  2/0/1/1/0/0
    Operation_SW    	 Tacchinodromo_operativo   135      10.1.97.142  5     AP:HT:48  18/22          -94/25/3   9/13/13/7/10/15    0/0/0/0/0/0  5/4/7/3/3/8
    Operation_NE    	 Tacchinodromo_operativo   135      10.1.97.151  5     AP:HT:60  18/22          -96/0/0    0/0/0/0/0/0        0/0/0/0/0/0  0/0/0/0/0/0
    Operation_NW    	 Tacchinodromo_operativo   135      10.1.97.153  5     AP:HT:36  18/22          -96/41/3   35/34/36/37/6/7    0/0/0/0/0/0  8/8/8/9/2/2
    Pad-H_SE        	 Padiglione_H              135      10.1.97.111  5     AP:HT:48  18/22          -96/13/2   4/5/3/3/4/5        0/0/0/0/0/0  2/3/2/2/3/3
    Casone_P2_EST   	 Casone_P2                 135      10.1.97.125  5     AP:HT:36  18/22          -96/5/1    3/0/1/0/2/1        0/0/0/0/0/0  0/0/0/0/0/0
    Giardino_Pad-G  	 Esterni_Farm              134      10.1.97.114  5     AP:HT:44  18/20          -94/1/0    0/0/0/0/0/0        0/0/0/0/0/0  0/0/0/0/0/0
    AP followed by "^" indicates that spectrum monitoring is enabled on the radio in AP mode
    NF: Noise Floor(dBm); U: Utilization(%); I: Interference(%)
    Mode: HT or VHT mode followed by Key Word "SCH" indicates that single chain mode is enabled on this radio
    TD/TM/TC(*/*/*/*/*/*): "*" is the time used by Data/Mgmt/Ctrl Frames(%) in a 10 seconds time slot in the past 1 minute
    Total Radios:56
    MASTER
    Pad-C_EE         Padiglione_C  135      10.1.97.147  2.4   AP:HT:11   15/19         -90/17/4   2/2/5/5/5/5        4/3/3/3/3/3  3/3/3/3/4/3
    Reception        Reception     105      10.1.97.133  2.4   AP:HT:6    18/19         -92/1/1    0/0/0/0/0/0        0/0/0/0/0/0  0/0/0/0/0/0
    Village_4        Village_4     105      10.1.97.108  2.4   AP:HT:1    18/19         -94/7/2    0/0/0/0/0/0        3/4/4/5/2/3  0/0/0/0/0/0
    Village_2        Village_2     105      10.1.97.118  2.4   AP:HT:1    18/19         -94/5/2    0/0/0/0/0/0        2/2/1/1/2/1  0/0/0/0/0/0
    Village_10       Village_10    105      10.1.97.132  2.4   AP:HT:11   18/19         -94/37/18  0/0/0/0/0/0        0/0/0/0/0/0  0/0/0/0/0/0
    Village_5        Village_5     105      10.1.97.113  2.4   AP:HT:1    18/19         -94/4/2    0/0/0/0/0/0        2/1/1/2/2/1  0/0/0/0/0/0
    Pollaio_P0_EE    Pollaio_P0    205      10.1.97.138  2.4   AP:HT:6    18/19         -95/3/1    0/0/0/0/0/0        0/1/1/1/1/0  0/0/0/0/0/0
    Pollaio_P1_WW    Pollaio_P1    205      10.1.97.136  2.4   AP:HT:11   18/19         -97/44/42  0/0/0/0/0/0        0/0/0/0/0/0  0/0/0/0/0/0
    Pollaio_P0_WW    Pollaio_P0    205      10.1.97.134  2.4   AP:HT:1    18/19         -97/2/0    0/0/0/0/0/0        0/0/0/0/0/0  0/0/0/0/0/0
    Pollaio_P1_EE    Pollaio_P1    205      10.1.97.137  2.4   AP:HT:1    18/19         -97/3/1    0/0/0/0/0/0        1/1/1/0/1/0  0/0/0/0/0/0
    Convivium_1      Convivium     135      10.1.97.135  2.4   AP:HT:11   18/19         -89/3/1    0/0/0/0/0/0        0/0/0/0/0/0  0/0/0/0/0/0
    Pad-C_SS         Padiglione_C  135      10.1.97.146  2.4   AP:HT:6    18/19         -93/4/1    0/0/0/0/0/0        1/1/1/1/1/1  0/1/0/0/0/0
    Pad-C_WW         Padiglione_C  135      10.1.97.141  2.4   AP:HT:6    18/19         -91/4/1    0/0/0/0/0/1        1/1/1/1/1/1  0/1/0/0/0/0
    Pad-C_NN         Padiglione_C  135      10.1.97.144  2.4   AP:HT:11   18/19         -87/14/2   4/5/4/6/5/6        1/1/1/3/1/1  2/2/2/3/2/3
    Pad-I_SW         Padiglione_I  135      10.1.97.143  2.4   AP:HT:6    18/19         -92/19/8   1/3/1/1/2/3        3/3/4/4/3/2  1/2/1/0/1/2
    Pad-I_NW         Padiglione_I  135      10.1.97.139  2.4   AP:HT:1    18/19         -94/9/5    0/0/0/0/0/0        2/2/2/2/3/2  0/0/0/0/0/0
    Pad-I_EE         Padiglione_I  135      10.1.97.140  2.4   AP:HT:11   18/19         -88/11/9   0/0/0/0/0/0        0/0/0/0/0/0  0/0/0/0/0/0
    Casone_P1_Silos  Casone_P1     205      10.1.97.107  2.4   AP:HT:1    18/19         -97/3/1    8/0/0/0/0/0        1/0/0/0/0/0  0/0/0/0/0/0
    Casone_P0_WW     Casone_P0     205      10.1.97.109  2.4   AP:HT:11   18/19         -97/5/2    0/0/0/0/0/0        2/1/1/2/1/1  0/0/0/0/0/0
    Casone_P1_WW     Casone_P1     205      10.1.97.106  2.4   AP:HT:11   18/19         -97/9/2    6/0/0/0/0/0        4/4/4/4/4/4  1/0/0/0/0/0
    Pad-G_WW         Padiglione_G  135      10.1.97.102  2.4   AP:HT:11   18/19         -90/4/1    0/0/0/0/0/0        1/1/1/1/1/1  0/0/0/0/0/0
    Pad-G_SE         Padiglione_G  135      10.1.97.119  2.4   AP:HT:6    18/19         -94/6/4    1/0/1/0/0/0        1/1/1/0/0/0  1/0/0/0/0/0
    Village_13       Village_13    105      10.1.97.115  2.4   AP:HT:1    18/19         -94/6/1    0/0/0/0/0/0        3/3/4/4/4/3  0/0/0/0/0/0
    Casone_P0_EST    Casone_P0     135      10.1.97.127  2.4   AP:HT:1    18/19         -95/61/2   9/58/52/51/56/50   0/5/7/3/7/4  0/2/2/3/2/2
    Casone_P1_NW     Casone_P1     205      10.1.97.104  2.4   AP:HT:1    18/19         -97/2/1    1/1/0/0/0/0        0/0/1/1/0/0  0/0/0/0/0/0
    Casone_P1_EE     Casone_P1     135      10.1.97.126  2.4   AP:HT:11   18/19         -91/8/5    0/0/0/0/4/0        0/0/0/0/0/0  0/0/0/0/0/0
    Pad-G_NN         Padiglione_G  105      10.1.97.121  2.4   AP:HT:6    18/19         -96/5/2    0/0/1/0/0/0        0/1/0/0/1/0  1/0/0/0/0/0
    Pad-G_NE         Padiglione_G  135      10.1.97.120  2.4   AP:HT:11   18/19         -89/4/2    0/0/0/0/0/0        1/1/1/1/1/1  0/0/0/0/0/0
    Reception        Reception     105      10.1.97.133  5     AP:HT:48   18/22         -95/1/0    0/0/0/0/0/0        0/0/0/0/0/0  0/0/0/0/0/0
    Village_4        Village_4     105      10.1.97.108  5     AP:HT:36   18/22         -94/5/1    6/2/3/2/0/4        0/0/0/0/0/0  1/0/0/0/0/0
    Village_2        Village_2     105      10.1.97.118  5     AP:HT:36   18/22         -94/2/1    2/0/2/0/1/0        0/0/0/0/0/0  0/0/1/0/0/0
    Village_10       Village_10    105      10.1.97.132  5     AP:HT:56   18/22         -95/1/1    0/0/0/0/0/0        0/0/0/0/0/0  0/0/0/0/0/0
    Village_5        Village_5     105      10.1.97.113  5     AP:HT:48   18/22         -95/4/4    0/0/0/0/0/0        0/0/0/0/0/0  0/0/0/0/0/0
    Village_13       Village_13    105      10.1.97.115  5     AP:HT:52   18/22         -95/1/1    0/0/0/0/0/0        0/0/0/0/0/0  0/0/0/0/0/0
    Pad-G_NN         Padiglione_G  105      10.1.97.121  5     AP:HT:36   18/22         -94/4/1    0/1/3/0/1/1        0/0/0/0/0/0  0/0/0/0/0/0
    Pad-C_EE         Padiglione_C  135      10.1.97.147  5     AP:HT:64   18/22         -96/13/2   2/18/19/3/4/4      0/0/0/0/0/0  1/11/5/2/5/1
    Village_12       Village_12    105      10.1.97.117  2.4   AP:HT:6    18/19         -94/2/1    0/0/0/0/0/0        0/0/0/0/0/0  0/0/0/0/0/0
    Village_1        Village_1     105      10.1.97.112  2.4   AP:HT:11   18/19         -94/5/1    0/0/0/0/0/1        2/2/2/2/2/2  0/0/0/0/0/0
    Pollaio_P0_EE    Pollaio_P0    205      10.1.97.138  5     AP:VHT:64  18/21         -97/1/0    0/0/0/0/0/0        0/0/0/0/0/0  0/0/0/0/0/0
    Pollaio_P1_WW    Pollaio_P1    205      10.1.97.136  5     AP:VHT:48  18/21         -97/10/1   1/0/1/1/0/4        0/0/0/0/0/0  0/0/0/0/0/0
    Pollaio_P0_WW    Pollaio_P0    205      10.1.97.134  5     AP:VHT:36  18/21         -97/29/1   9/7/10/13/1/6      0/0/0/0/0/0  0/1/0/1/0/2
    Pollaio_P1_EE    Pollaio_P1    205      10.1.97.137  5     AP:VHT:36  18/21         -97/1/0    0/0/0/0/0/0        0/0/0/0/0/0  0/0/0/0/0/0
    Convivium_1      Convivium     135      10.1.97.135  5     AP:HT:52   18/22         -95/0/0    0/0/0/0/0/0        0/0/0/0/0/0  0/0/0/0/0/0
    Pad-C_SS         Padiglione_C  135      10.1.97.146  5     AP:HT:40   18/22         -93/3/1    0/0/0/0/0/0        0/1/0/1/0/0  0/0/0/0/0/1
    Pad-C_WW         Padiglione_C  135      10.1.97.141  5     AP:HT:48   18/22         -96/6/1    2/1/3/3/2/2        0/0/0/0/0/0  0/0/1/1/0/0
    Pad-C_NN         Padiglione_C  135      10.1.97.144  5     AP:HT:40   18/22         -96/3/1    0/2/0/1/0/0        0/0/0/0/0/0  0/0/0/0/0/1
    Pad-I_SW         Padiglione_I  135      10.1.97.143  5     AP:HT:56   18/22         -95/60/3   32/50/48/48/42/42  0/0/0/0/0/0  7/5/5/5/7/5
    Pad-I_NW         Padiglione_I  135      10.1.97.139  5     AP:HT:40   18/22         -95/29/3   8/16/12/19/12/8    0/0/0/0/0/0  4/9/6/7/8/4
    Pad-I_EE         Padiglione_I  135      10.1.97.140  5     AP:HT:48   18/22         -96/2/1    0/0/0/0/0/0        0/0/0/0/0/0  0/0/0/0/0/0
    Casone_P1_Silos  Casone_P1     205      10.1.97.107  5     AP:VHT:48  18/21         -97/2/0    0/0/2/0/0/0        0/0/0/0/0/0  0/0/0/0/0/0
    Casone_P0_WW   	 Casone_P0     205      10.1.97.109  5     AP:VHT:52  18/21         -97/1/0   0/0/0/0/0/0     	  0/0/0/0/0/0  0/0/0/0/0/0
    Village_9        Village_9     105      10.1.97.124  2.4   AP:HT:1    18/19         -94/1/1   0/0/0/0/0/0     	  0/0/0/0/0/0  0/0/0/0/0/0
    Village_11       Village_11    105      10.1.97.101  2.4   AP:HT:11   18/19         -88/1/1   0/0/0/0/0/0     	  0/0/0/0/0/0  0/0/0/0/0/0
    Casone_P1_WW     Casone_P1     205      10.1.97.106  5     AP:VHT:40  18/21         -97/6/0   1/0/1/1/1/1     	  0/0/0/0/0/0  0/0/0/0/0/0
    Pad-G_WW         Padiglione_G  135      10.1.97.102  5     AP:HT:56   18/22         -96/7/1   3/3/3/3/3/3     	  0/0/0/0/0/0  0/1/1/1/1/1
    Pad-G_SE         Padiglione_G  135      10.1.97.119  5     AP:HT:64   18/22         -96/4/1   1/0/1/0/2/1     	  0/0/0/0/0/0  0/0/0/0/0/0
    Village_3        Village_3     105      10.1.97.123  2.4   AP:HT:11   18/19         -94/5/1   0/0/0/0/0/0     	  2/2/3/4/3/3  0/0/0/0/0/0
    Casone_P0_EST    Casone_P0     135      10.1.97.127  5     AP:HT:36   18/22         -96/2/1   0/0/0/0/0/0     	  0/0/0/0/0/0  0/0/0/0/0/0
    Casone_P1_NW     Casone_P1     205      10.1.97.104  5     AP:VHT:56  18/21         -97/1/0   0/1/0/0/1/0     	  0/0/0/0/0/0  0/1/0/0/1/0
    Village_6_       Village_6     105      10.1.97.149  2.4   AP:HT:6    18/19         -96/6/1   0/0/0/0/0/0     	  2/3/1/2/2/2  1/1/0/1/0/1
    Casone_P1_EE     Casone_P1     135      10.1.97.126  5     AP:HT:48   18/22         -93/24/3  7/8/10/19/17/6  	  0/0/0/0/0/0  4/4/4/7/6/2
    Village_8        Village_8     105      10.1.97.100  2.4   AP:HT:6    18/19         -94/17/3  15/7/10/8/8/7   	  0/1/1/1/0/1  2/1/3/1/2/3
    Pad-G_NE         Padiglione_G  135      10.1.97.120  5     AP:HT:64   18/22         -95/4/0   0/1/1/0/0/2     	  0/0/0/0/0/0  0/2/0/0/0/2
    Village_12       Village_12    105      10.1.97.117  5     AP:HT:36   18/22         -94/2/2   0/0/0/0/0/0     	  0/0/0/0/0/0  0/0/0/0/0/0
    Village_1        Village_1     105      10.1.97.112  5     AP:HT:48   18/22         -95/1/0   0/3/0/0/0/0     	  0/0/0/0/0/0  0/0/0/0/0/0
    Village_9        Village_9     105      10.1.97.124  5     AP:HT:48   18/22         -95/0/0   0/0/0/0/0/0     	  0/0/0/0/0/0  0/0/0/0/0/0
    Village_11       Village_11    105      10.1.97.101  5     AP:HT:56   18/22         -95/2/1   1/0/0/0/0/0     	  0/0/0/0/0/0  0/0/0/0/0/0
    Village_3        Village_3     105      10.1.97.123  5     AP:HT:36   18/22         -94/2/0   0/0/0/0/1/0     	  0/0/0/0/0/0  0/0/0/0/0/0
    Village_6_       Village_6     105      10.1.97.149  5     AP:HT:60   18/22         -95/0/0   0/0/0/0/0/0     	  0/0/0/0/0/0  0/0/0/0/0/0
    Village_8        Village_8     105      10.1.97.100  5     AP:HT:36   18/22         -94/2/1   0/0/1/1/2/0     	  0/0/0/0/0/0  0/0/0/0/0/0
  • 15.  RE: Client stops sending packets
    Posted Jul 03, 2015 06:31 AM
    No, I don't.
    and here the result of show ap-radio summary
    LOCAL
    Total Radios:56
    MASTER
  • 16.  RE: Client stops sending packets
    Posted Jul 03, 2015 06:34 AM
    No, I don't.
    LOCAL
    Total Radios:56
    MASTER
  • 17.  RE: Client stops sending packets
    Posted Jul 03, 2015 06:36 AM
    No, I don't.
    and in attach the result of show ap-radio summary
    Attachment(s)
    txt
    show ap-radio summary.txt   19 KB 1 version
  • 18.  RE: Client stops sending packets
    Posted Jul 03, 2015 06:40 AM
    You should enable "drop broadcast and multicast" on all of your Virtual APs, so that broadcast traffic does not consume your usable bandwidth.
    In the radio-summary output, there are some access points that have high utilization (>40) and turning on drop broadcasts and multicast on all of your Virtual APs will definitely help improve the experience.
    Your screenshot of your mac's Airport shows that it had a strong signal, but the TX rate was very, very low.  This could be because of congestion.  Turning on "Drop Broadcasts" could help.
  • 19.  RE: Client stops sending packets
    Posted Jul 03, 2015 07:00 AM
    Wouldn't this impact air-play and bonjour on mac devices (the 98% of our devices are Apple)?
    When I took that screenshot there was not much client connected to both ap:
    Active AP Table
    And also the utilization is low
  • 20.  RE: Client stops sending packets
    Posted Jul 03, 2015 07:05 AM
    If Airgroup is on (it is on by default), it will pass bonjour traffic.
    The utilization on the 2.4ghz is at 61%, so it will certainly help that.  It will also lower the utilization across the board and give your clients a better chance to connect.
  • 21.  RE: Client stops sending packets
    Posted Jul 03, 2015 09:58 AM
    Ok, I'll try to enable and configure air group, the last time I enabled it none was able to print...I definetly need to carefully read the documentation.
    Thanks a lot, i'll give you an update soon!
  • 22.  RE: Client stops sending packets
    Posted Jul 03, 2015 10:01 AM
    Consider upgrading to 6.4.3.1 or above. There are airgroup printing fixes where you would not have to configure anything.
  • 23.  RE: Client stops sending packets
    Posted Jul 06, 2015 10:06 AM
    Ok, today I tried enabling also the airgroup, but I'm still having the same issue.
    It doesn't seem to be a load problem, but something else, even if I can't understand what is happening.
    In attachment you can find the log from a mac (wifi debugging enabled) and the log from the controller.
    Below the result of "show ap radio-summary" of that ap group (highlighted the ap and band to which the client is connected)
    Attachment(s)
    txt
    log_mac.txt   81 KB 1 version
  • 24.  RE: Client stops sending packets
    Posted Jul 06, 2015 10:12 AM
    Have you opened a TAC case in parallel?  If not, please do, because they can leverage information that you cannot post here.
    Did you turn on broadcast filtering on all your Virtual APs in that AP group?  Did you also try to upgrade any of the MACs?  What kind of encryption are the macs using?  How many SSIDs are you broadcasting in that AP group?
  • 25.  RE: Client stops sending packets
    Posted Jul 06, 2015 10:43 AM
    Yes I did on July the 2nd, but I'm looking for a solution while waiting for an official response.
    Answer inline
    Yes
    Yes, included mine. Nothing changes
    Doesn't mind, I tried with all our SSID: WPA2, WPA2 Enterprise, Open
    Three: CAMPUS (802.1x), COMPANY (WPA 2 psk), Guests (Open)
  • 26.  RE: Client stops sending packets
    Posted Jul 06, 2015 10:51 AM
    It is only the macs that are exhibiting this issue, right?
  • 27.  RE: Client stops sending packets
    Posted Jul 06, 2015 11:18 AM
    I only have mac here and don't know how to test from android or phones in general.
    My mac is showing the issue in this moment.
    It says it's connected to the wifi, but after 10 packets it stops replying the ping.
    I can't see nothing strange from the logs:
    Jul  6 16:35:15 10.1.0.101 Jul  6 16:35:23 2015 10.1.97.127 stm[1144]: <501105> <NOTI> |AP Casone_P0_EST@10.1.97.127 stm|  Deauth from sta: 20:c9:d0:c3:1e:25: AP 10.1.97.127-6c:f3:7f:b4:1f:f2-Casone_P0_EST Reason AAA Deauthenticate
    Jul  6 16:35:15 10.1.0.101 Jul  6 16:35:23 2015 MASTER Controller authmgr[1731]: <124003> <INFO> <MASTER Controller 10.1.0.101>  Authentication result=Authentication Successful(0), method=radius-accounting, server=Civetta, user=20:c9:d0:c3:1e:25
    Jul  6 16:35:15 10.1.0.101 Jul  6 16:35:23 2015 MASTER Controller authmgr[1731]: <522038> <INFO> <MASTER Controller 10.1.0.101>  username=console MAC=20:c9:d0:c3:1e:25 IP=10.1.1.102 Authentication result=Authentication Successful method=radius-accounting server=Civetta
    Jul  6 16:35:15 10.1.0.101 Jul  6 16:35:23 2015 MASTER Controller mdns[1798]: <527004> <INFO> <MASTER Controller 10.1.0.101>  mdns_parse_auth_useridle_message 169 Auth User Idle Timeout: MAC:20:c9:d0:c3:1e:25
    Jul  6 16:35:15 10.1.0.101 Jul  6 16:35:23 2015 MASTER Controller authmgr[2053]: <522036> <INFO> <MASTER Controller 10.1.0.101>  MAC=20:c9:d0:c3:1e:25 Station DN: BSSID=6c:f3:7f:b4:1f:f2 ESSID=CAMPUS VLAN=100 AP-name=Casone_P0_EST
    Jul  6 16:35:15 10.1.0.101 Jul  6 16:35:23 2015 MASTER Controller <MASTER Controller 10.1.0.101> fpcli: USER:aaldrigo@10.1.1.101 COMMAND:<aaa user delete mac 20:c9:d0:c3:1e:25 > -- command executed successfully
    Jul  6 16:35:15 10.1.0.101 Jul  6 16:35:23 2015 MASTER Controller authmgr[1731]: <522050> <INFO> <MASTER Controller 10.1.0.101>  MAC=20:c9:d0:c3:1e:25,IP=N/A User data downloaded to datapath, new Role=authenticated/119, bw Contract=0/0, reason=Station resetting role, idle-timeout=300
    Jul  6 16:35:15 10.1.0.101 Jul  6 16:35:23 2015 MASTER Controller authmgr[1731]: <522005> <INFO> <MASTER Controller 10.1.0.101>  MAC=20:c9:d0:c3:1e:25 IP=10.1.1.102 User entry deleted: reason=user request
    Jul  6 16:35:15 10.1.0.101 Jul  6 16:35:23 2015 MASTER Controller stm[2143]: <501080> <NOTI> <MASTER Controller 10.1.0.101>  Deauth to sta: 20:c9:d0:c3:1e:25: Ageout AP 10.1.97.127-6c:f3:7f:b4:1f:f2-Casone_P0_EST AAA Deauthenticate
    Jul  6 16:35:15 10.1.0.101 Jul  6 16:35:23 2015 MASTER Controller stm[2143]: <501106> <NOTI> <MASTER Controller 10.1.0.101>  Deauth to sta: 20:c9:d0:c3:1e:25: Ageout AP 10.1.97.127-6c:f3:7f:b4:1f:f2-Casone_P0_EST wifi_deauth_sta
    Jul  6 16:35:21 10.1.0.101 Jul  6 16:35:29 2015 10.1.97.127 stm[1144]: <501044> <NOTI> |AP Casone_P0_EST@10.1.97.127 stm|  Station 20:c9:d0:c3:1e:25: No authentication found trying to de-authenticate to BSSID 6c:f3:7f:b4:1f:f2 on AP Casone_P0_EST
    Jul  6 16:35:21 10.1.0.101 Jul  6 16:35:29 2015 10.1.97.127 stm[1144]: <501105> <NOTI> |AP Casone_P0_EST@10.1.97.127 stm|  Deauth from sta: 20:c9:d0:c3:1e:25: AP 10.1.97.127-6c:f3:7f:b4:1f:f2-Casone_P0_EST Reason Denied: AP Ageout
    Jul  6 16:35:21 10.1.0.101 Jul  6 16:35:29 2015 MASTER Controller stm[1732]: <501080> <NOTI> <MASTER Controller 10.1.0.101>  Deauth to sta: 20:c9:d0:c3:1e:25: Ageout AP 10.1.97.127-6c:f3:7f:b4:1f:f2-Casone_P0_EST Denied: AP Ageout
    Jul  6 16:35:25 10.1.0.101 Jul  6 16:35:33 2015 MASTER Controller authmgr[2053]: <522050> <INFO> <MASTER Controller 10.1.0.101>  MAC=20:c9:d0:c3:1e:25,IP=N/A User data downloaded to datapath, new Role=logon/2, bw Contract=0/0, reason=layer 2 event driven download, idle-timeout=300
    Jul  6 16:35:25 10.1.0.101 Jul  6 16:35:33 2015 MASTER Controller authmgr[2053]: <522035> <INFO> <MASTER Controller 10.1.0.101>  MAC=20:c9:d0:c3:1e:25 Station UP: BSSID=6c:f3:7f:b4:1f:f2 ESSID=CAMPUS VLAN=997 AP-name=Casone_P0_EST
    Jul  6 16:35:25 10.1.0.101 Jul  6 16:35:33 2015 MASTER Controller stm[1732]: <501100> <NOTI> <MASTER Controller 10.1.0.101>  Assoc success @ 16:35:33.660091: 20:c9:d0:c3:1e:25: AP 10.1.97.127-6c:f3:7f:b4:1f:f2-Casone_P0_EST
    Jul  6 16:35:25 10.1.0.101 Jul  6 16:35:33 2015 MASTER Controller stm[1732]: <501100> <NOTI> <MASTER Controller 10.1.0.101>  Assoc success @ 16:35:33.659686: 20:c9:d0:c3:1e:25: AP 10.1.97.127-6c:f3:7f:b4:1f:f2-Casone_P0_EST
    Jul  6 16:35:25 10.1.0.101 Jul  6 16:35:33 2015 10.1.97.127 stm[1144]: <501100> <NOTI> |AP Casone_P0_EST@10.1.97.127 stm|  Assoc success @ 16:35:33.634992: 20:c9:d0:c3:1e:25: AP 10.1.97.127-6c:f3:7f:b4:1f:f2-Casone_P0_EST
    Jul  6 16:35:25 10.1.0.101 Jul  6 16:35:33 2015 10.1.97.127 stm[1144]: <501100> <NOTI> |AP Casone_P0_EST@10.1.97.127 stm|  Assoc success @ 16:35:33.633471: 20:c9:d0:c3:1e:25: AP 10.1.97.127-6c:f3:7f:b4:1f:f2-Casone_P0_EST
    Jul  6 16:35:25 10.1.0.101 Jul  6 16:35:33 2015 10.1.97.127 stm[1144]: <501095> <NOTI> |AP Casone_P0_EST@10.1.97.127 stm|  Assoc request @ 16:35:33.632239: 20:c9:d0:c3:1e:25 (SN 3397): AP 10.1.97.127-6c:f3:7f:b4:1f:f2-Casone_P0_EST
    Jul  6 16:35:25 10.1.0.101 Jul  6 16:35:33 2015 10.1.97.127 stm[1144]: <501095> <NOTI> |AP Casone_P0_EST@10.1.97.127 stm|  Assoc request @ 16:35:33.632027: 20:c9:d0:c3:1e:25 (SN 3397): AP 10.1.97.127-6c:f3:7f:b4:1f:f2-Casone_P0_EST
    Jul  6 16:35:25 10.1.0.101 Jul  6 16:35:33 2015 10.1.97.127 stm[1144]: <501093> <NOTI> |AP Casone_P0_EST@10.1.97.127 stm|  Auth success: 20:c9:d0:c3:1e:25: AP 10.1.97.127-6c:f3:7f:b4:1f:f2-Casone_P0_EST
    Jul  6 16:35:25 10.1.0.101 Jul  6 16:35:33 2015 10.1.97.127 stm[1144]: <501109> <NOTI> |AP Casone_P0_EST@10.1.97.127 stm|  Auth request: 20:c9:d0:c3:1e:25: AP 10.1.97.127-6c:f3:7f:b4:1f:f2-Casone_P0_EST auth_alg 0
    Jul  6 16:35:26 10.1.0.101 Jul  6 16:35:34 2015 MASTER Controller authmgr[1731]: <124003> <INFO> <MASTER Controller 10.1.0.101>  Authentication result=Authentication Successful(0), method=radius-accounting, server=Civetta, user=20:c9:d0:c3:1e:25
    Jul  6 16:35:26 10.1.0.101 Jul  6 16:35:34 2015 MASTER Controller authmgr[1731]: <522038> <INFO> <MASTER Controller 10.1.0.101>  username=console MAC=20:c9:d0:c3:1e:25 IP=10.1.1.102 Authentication result=Authentication Successful method=radius-accounting server=Civetta
    Jul  6 16:35:26 10.1.0.101 Jul  6 16:35:34 2015 MASTER Controller authmgr[1731]: <522050> <INFO> <MASTER Controller 10.1.0.101>  MAC=20:c9:d0:c3:1e:25,IP=10.1.1.102 User data downloaded to datapath, new Role=authenticated/119, bw Contract=0/0, reason=New user IP processing, idle-timeout=300
    Jul  6 16:35:26 10.1.0.101 Jul  6 16:35:34 2015 MASTER Controller authmgr[1731]: <522008> <NOTI> <MASTER Controller 10.1.0.101>  User Authentication Successful: username=console MAC=20:c9:d0:c3:1e:25 IP=10.1.1.102 role=authenticated VLAN=100 AP=Casone_P0_EST SSID=CAMPUS AAA profile=CAMPUS-aaa_prof auth method=802.1x auth server=Civetta
    Jul  6 16:35:26 10.1.0.101 Jul  6 16:35:34 2015 MASTER Controller authmgr[1731]: <522049> <INFO> <MASTER Controller 10.1.0.101>  MAC=20:c9:d0:c3:1e:25,IP=10.1.1.102 User role updated, existing Role=authenticated/logon, new Role=authenticated/authenticated, reason=User authenticated with auth type:4 role derivation:1 l3 assigned role:authenticated
    Jul  6 16:35:26 10.1.0.101 Jul  6 16:35:34 2015 MASTER Controller mdns[1798]: <527004> <INFO> <MASTER Controller 10.1.0.101>  mdns_parse_auth_useradd_message 226 Auth User ADD: MAC:20:c9:d0:c3:1e:25, IP:10.1.1.102, VLAN:997, Role:logon Name:console APName:Casone_P0_EST Type:1. Groups:
    Jul  6 16:35:26 10.1.0.101 Jul  6 16:35:34 2015 MASTER Controller authmgr[1731]: <522006> <INFO> <MASTER Controller 10.1.0.101>  MAC=20:c9:d0:c3:1e:25 IP=10.1.1.102 User entry added: reason=Sibtye
    Jul  6 16:35:26 10.1.0.101 Jul  6 16:35:34 2015 MASTER Controller authmgr[1731]: <522049> <INFO> <MASTER Controller 10.1.0.101>  MAC=20:c9:d0:c3:1e:25,IP=0.0.0.0 User role updated, existing Role=authenticated/none, new Role=authenticated/logon, reason=First IP user created
    Jul  6 16:35:26 10.1.0.101 Jul  6 16:35:34 2015 MASTER Controller authmgr[1731]: <522026> <INFO> <MASTER Controller 10.1.0.101>  MAC=20:c9:d0:c3:1e:25 IP=10.1.1.102 User miss: ingress=0x10071, VLAN=100 flags=0xc040
    Jul  6 16:35:26 10.1.0.101 Jul  6 16:35:33 2015 MASTER Controller authmgr[1731]: <522029> <INFO> <MASTER Controller 10.1.0.101>  MAC=20:c9:d0:c3:1e:25 Station authenticate: method=802.1x, role=authenticated///logon, VLAN=997/100, Derivation=1/15, Value Pair=1
    Jul  6 16:35:26 10.1.0.101 Jul  6 16:35:33 2015 MASTER Controller authmgr[1731]: <522023> <INFO> <MASTER Controller 10.1.0.101>  MAC=20:c9:d0:c3:1e:25 Derived VLAN 100 from server rules: server-group=Civetta
    Jul  6 16:35:26 10.1.0.101 Jul  6 16:35:33 2015 MASTER Controller authmgr[1731]: <522050> <INFO> <MASTER Controller 10.1.0.101>  MAC=20:c9:d0:c3:1e:25,IP=N/A User data downloaded to datapath, new Role=authenticated/119, bw Contract=0/0, reason=Download driven by user role setting, idle-timeout=300
    Jul  6 16:35:26 10.1.0.101 Jul  6 16:35:33 2015 MASTER Controller authmgr[1731]: <522049> <INFO> <MASTER Controller 10.1.0.101>  MAC=20:c9:d0:c3:1e:25,IP=N/A User role updated, existing Role=logon/none, new Role=authenticated/none, reason=Station Authenticated with auth type: 4
    Jul  6 16:35:26 10.1.0.101 Jul  6 16:35:33 2015 MASTER Controller authmgr[1731]: <522044> <INFO> <MASTER Controller 10.1.0.101>  MAC=20:c9:d0:c3:1e:25 Station authenticate(start): method=802.1x, role=logon///logon, VLAN=997/997, Derivation=0/0, Value Pair=1, flags=0x8
    Jul  6 16:35:26 10.1.0.101 Jul  6 16:35:33 2015 MASTER Controller authmgr[1731]: <124003> <INFO> <MASTER Controller 10.1.0.101>  Authentication result=Authentication Successful(0), method=802.1x, server=Civetta, user=20:c9:d0:c3:1e:25
    Jul  6 16:35:26 10.1.0.101 Jul  6 16:35:33 2015 MASTER Controller authmgr[1731]: <522038> <INFO> <MASTER Controller 10.1.0.101>  username=console MAC=20:c9:d0:c3:1e:25 IP=0.0.0.0 Authentication result=Authentication Successful method=802.1x server=Civetta
    Jul  6 16:36:05 10.1.0.101 Jul  6 16:36:13 2015 10.1.97.127 stm[1144]: <501093> <NOTI> |AP Casone_P0_EST@10.1.97.127 stm|  Auth success: 20:c9:d0:c3:1e:25: AP 10.1.97.127-6c:f3:7f:b4:1f:f2-Casone_P0_EST
    Jul  6 16:36:05 10.1.0.101 Jul  6 16:36:13 2015 10.1.97.127 stm[1144]: <501109> <NOTI> |AP Casone_P0_EST@10.1.97.127 stm|  Auth request: 20:c9:d0:c3:1e:25: AP 10.1.97.127-6c:f3:7f:b4:1f:f2-Casone_P0_EST auth_alg 0
    Jul  6 16:36:15 10.1.0.101 Jul  6 16:36:23 2015 MASTER Controller authmgr[1731]: <522008> <NOTI> <MASTER Controller 10.1.0.101>  User Authentication Successful: username=console MAC=20:c9:d0:c3:1e:25 IP=10.1.1.102 role=authenticated VLAN=100 AP=Casone_P0_EST SSID=CAMPUS AAA profile=CAMPUS-aaa_prof auth method=802.1x auth server=Civetta
    Jul  6 16:36:15 10.1.0.101 Jul  6 16:36:23 2015 MASTER Controller authmgr[1731]: <522029> <INFO> <MASTER Controller 10.1.0.101>  MAC=20:c9:d0:c3:1e:25 Station authenticate: method=802.1x, role=authenticated/authenticated//logon, VLAN=100/100, Derivation=1/15, Value Pair=1
    Jul  6 16:36:15 10.1.0.101 Jul  6 16:36:23 2015 MASTER Controller authmgr[1731]: <522023> <INFO> <MASTER Controller 10.1.0.101>  MAC=20:c9:d0:c3:1e:25 Derived VLAN 100 from server rules: server-group=Civetta
    Jul  6 16:36:15 10.1.0.101 Jul  6 16:36:23 2015 MASTER Controller authmgr[1731]: <522050> <INFO> <MASTER Controller 10.1.0.101>  MAC=20:c9:d0:c3:1e:25,IP=N/A User data downloaded to datapath, new Role=authenticated/119, bw Contract=0/0, reason=Download driven by user role setting, idle-timeout=300
    Jul  6 16:36:15 10.1.0.101 Jul  6 16:36:23 2015 MASTER Controller authmgr[1731]: <522049> <INFO> <MASTER Controller 10.1.0.101>  MAC=20:c9:d0:c3:1e:25,IP=N/A User role updated, existing Role=authenticated/authenticated, new Role=authenticated/authenticated, reason=Station Authenticated with auth type: 4
    Jul  6 16:36:15 10.1.0.101 Jul  6 16:36:23 2015 MASTER Controller authmgr[1731]: <522044> <INFO> <MASTER Controller 10.1.0.101>  MAC=20:c9:d0:c3:1e:25 Station authenticate(start): method=802.1x, role=authenticated/authenticated//logon, VLAN=100/100, Derivation=1/15, Value Pair=1, flags=0x8
    Jul  6 16:36:15 10.1.0.101 Jul  6 16:36:23 2015 MASTER Controller authmgr[1731]: <124003> <INFO> <MASTER Controller 10.1.0.101>  Authentication result=Authentication Successful(0), method=802.1x, server=Civetta, user=20:c9:d0:c3:1e:25
    Jul  6 16:36:15 10.1.0.101 Jul  6 16:36:23 2015 MASTER Controller authmgr[1731]: <522038> <INFO> <MASTER Controller 10.1.0.101>  username=console MAC=20:c9:d0:c3:1e:25 IP=0.0.0.0 Authentication result=Authentication Successful method=802.1x server=Civetta
    Jul  6 16:36:15 10.1.0.101 Jul  6 16:36:23 2015 MASTER Controller authmgr[2053]: <522035> <INFO> <MASTER Controller 10.1.0.101>  MAC=20:c9:d0:c3:1e:25 Station UP: BSSID=6c:f3:7f:b4:1f:f2 ESSID=CAMPUS VLAN=100 AP-name=Casone_P0_EST
    Jul  6 16:36:15 10.1.0.101 Jul  6 16:36:23 2015 MASTER Controller stm[1732]: <501100> <NOTI> <MASTER Controller 10.1.0.101>  Assoc success @ 16:36:23.184245: 20:c9:d0:c3:1e:25: AP 10.1.97.127-6c:f3:7f:b4:1f:f2-Casone_P0_EST
    Jul  6 16:36:15 10.1.0.101 Jul  6 16:36:23 2015 MASTER Controller stm[1732]: <501100> <NOTI> <MASTER Controller 10.1.0.101>  Assoc success @ 16:36:23.183824: 20:c9:d0:c3:1e:25: AP 10.1.97.127-6c:f3:7f:b4:1f:f2-Casone_P0_EST
    Jul  6 16:36:15 10.1.0.101 Jul  6 16:36:23 2015 10.1.97.127 stm[1144]: <501100> <NOTI> |AP Casone_P0_EST@10.1.97.127 stm|  Assoc success @ 16:36:23.163979: 20:c9:d0:c3:1e:25: AP 10.1.97.127-6c:f3:7f:b4:1f:f2-Casone_P0_EST
    Jul  6 16:36:15 10.1.0.101 Jul  6 16:36:23 2015 10.1.97.127 stm[1144]: <501100> <NOTI> |AP Casone_P0_EST@10.1.97.127 stm|  Assoc success @ 16:36:23.163763: 20:c9:d0:c3:1e:25: AP 10.1.97.127-6c:f3:7f:b4:1f:f2-Casone_P0_EST
    Jul  6 16:36:15 10.1.0.101 Jul  6 16:36:23 2015 10.1.97.127 stm[1144]: <501095> <NOTI> |AP Casone_P0_EST@10.1.97.127 stm|  Assoc request @ 16:36:23.160542: 20:c9:d0:c3:1e:25 (SN 3604): AP 10.1.97.127-6c:f3:7f:b4:1f:f2-Casone_P0_EST
    Jul  6 16:36:15 10.1.0.101 Jul  6 16:36:23 2015 10.1.97.127 stm[1144]: <501095> <NOTI> |AP Casone_P0_EST@10.1.97.127 stm|  Assoc request @ 16:36:23.160069: 20:c9:d0:c3:1e:25 (SN 3604): AP 10.1.97.127-6c:f3:7f:b4:1f:f2-Casone_P0_EST
    Jul  6 16:36:15 10.1.0.101 Jul  6 16:36:23 2015 10.1.97.127 stm[1144]: <501093> <NOTI> |AP Casone_P0_EST@10.1.97.127 stm|  Auth success: 20:c9:d0:c3:1e:25: AP 10.1.97.127-6c:f3:7f:b4:1f:f2-Casone_P0_EST
    Jul  6 16:36:15 10.1.0.101 Jul  6 16:36:23 2015 10.1.97.127 stm[1144]: <501109> <NOTI> |AP Casone_P0_EST@10.1.97.127 stm|  Auth request: 20:c9:d0:c3:1e:25: AP 10.1.97.127-6c:f3:7f:b4:1f:f2-Casone_P0_EST auth_alg 0
    Jul  6 16:39:25 10.1.0.101 Jul  6 16:39:33 2015 MASTER Controller authmgr[1731]: <124003> <INFO> <MASTER Controller 10.1.0.101>  Authentication result=Authentication Successful(0), method=radius-accounting, server=Civetta, user=20:c9:d0:c3:1e:25
    Jul  6 16:39:25 10.1.0.101 Jul  6 16:39:33 2015 MASTER Controller authmgr[1731]: <522038> <INFO> <MASTER Controller 10.1.0.101>  username=console MAC=20:c9:d0:c3:1e:25 IP=10.1.1.102 Authentication result=Authentication Successful method=radius-accounting server=Civetta
    Jul  6 16:47:45 10.1.0.85 Jul  6 16:47:53 2015 LOCAL Controller wms[1720]: <316096> <INFO> <LOCAL Controller 10.1.0.85>  Ageing STA tree node  MAC 20:c9:d0:c3:1e:25 Monitor 6c:f3:7f:ce:20:b2
    Jul  6 16:47:45 10.1.0.85 Jul  6 16:47:53 2015 LOCAL Controller wms[1720]: <316096> <INFO> <LOCAL Controller 10.1.0.85>  Ageing STA tree node  MAC 20:c9:d0:c3:1e:25 Monitor 24:de:c6:c6:1f:d0
    Jul  6 16:47:45 10.1.0.85 Jul  6 16:47:53 2015 LOCAL Controller wms[1720]: <316095> <INFO> <LOCAL Controller 10.1.0.85>  Ageing STA 20:c9:d0:c3:1e:25
    Jul  6 16:50:03 10.1.0.101 Jul  6 16:50:11 2015 MASTER Controller authmgr[1731]: <124003> <INFO> <MASTER Controller 10.1.0.101>  Authentication result=Authentication Successful(0), method=radius-accounting, server=Civetta, user=20:c9:d0:c3:1e:25
    Jul  6 16:50:03 10.1.0.101 Jul  6 16:50:11 2015 MASTER Controller authmgr[1731]: <522038> <INFO> <MASTER Controller 10.1.0.101>  username=console MAC=20:c9:d0:c3:1e:25 IP=10.1.1.102 Authentication result=Authentication Successful method=radius-accounting server=Civetta
    Jul  6 16:52:50 10.1.0.101 Jul  6 16:52:58 2015 10.1.97.126 sapd[1129]: <326274> <NOTI> |AP Casone_P1_EE@10.1.97.126 sapd| |ap| AM: Inactive Node Detected  = 20:c9:d0:c3:1e:25 SSID = CAMPUS BSSID 6c:f3:7f:b4:1f:f2
    Jul  6 16:52:55 10.1.0.101 Jul  6 16:53:03 2015 10.1.97.126 sapd[1129]: <326107> <NOTI> |AP Casone_P1_EE@10.1.97.126 sapd| |ap| AM: RSTA Type set to 0 for STA 20:c9:d0:c3:1e:25
    Jul  6 16:53:21 10.1.0.101 Jul  6 16:53:29 2015 10.1.97.109 sapd[1041]: <326274> <NOTI> |AP Casone_P0_WW@10.1.97.109 sapd| |ap| AM: Inactive Node Detected  = 20:c9:d0:c3:1e:25 SSID = CAMPUS BSSID 6c:f3:7f:b4:1f:f2
    Jul  6 16:53:27 10.1.0.101 Jul  6 16:53:35 2015 10.1.97.109 sapd[1041]: <326107> <NOTI> |AP Casone_P0_WW@10.1.97.109 sapd| |ap| AM: RSTA Type set to 0 for STA 20:c9:d0:c3:1e:25
    Jul  6 16:53:27 10.1.0.101 Jul  6 16:53:35 2015 10.1.97.126 sapd[1129]: <326278> <NOTI> |AP Casone_P1_EE@10.1.97.126 sapd| |ap| AM: STA 20:c9:d0:c3:1e:25 Authenticated with AP 6c:f3:7f:b4:1f:f2
    Jul  6 16:53:29 10.1.0.101 Jul  6 16:53:36 2015 10.1.97.109 sapd[1041]: <326278> <NOTI> |AP Casone_P0_WW@10.1.97.109 sapd| |ap| AM: STA 20:c9:d0:c3:1e:25 Authenticated with AP 6c:f3:7f:b4:1f:f2
    Jul  6 17:00:41 10.1.0.101 Jul  6 17:00:49 2015 MASTER Controller authmgr[1731]: <124003> <INFO> <MASTER Controller 10.1.0.101>  Authentication result=Authentication Successful(0), method=radius-accounting, server=Civetta, user=20:c9:d0:c3:1e:25
    Jul  6 17:00:41 10.1.0.101 Jul  6 17:00:49 2015 MASTER Controller authmgr[1731]: <522038> <INFO> <MASTER Controller 10.1.0.101>  username=console MAC=20:c9:d0:c3:1e:25 IP=10.1.1.102 Authentication result=Authentication Successful method=radius-accounting server=Civetta
    Jul  6 17:03:33 10.1.0.101 Jul  6 17:03:41 2015 10.1.97.109 sapd[1041]: <326274> <NOTI> |AP Casone_P0_WW@10.1.97.109 sapd| |ap| AM: Inactive Node Detected  = 20:c9:d0:c3:1e:25 SSID = CAMPUS BSSID 6c:f3:7f:b4:1f:f2
    Jul  6 17:04:18 10.1.0.101 Jul  6 17:04:26 2015 10.1.97.109 sapd[1041]: <326107> <NOTI> |AP Casone_P0_WW@10.1.97.109 sapd| |ap| AM: RSTA Type set to 0 for STA 20:c9:d0:c3:1e:25
    I'm having the issue since I moved from another building (the one from which I posted the log).
    I also tried clearing my sessions issuing these comands from the CLI
    aaa user delete mac aa:aa:aa:aa:aa:aa
    aaa user clear-sessions <ip-addr>
    but nothing changed.
  • 28.  RE: Client stops sending packets
    Posted Jul 06, 2015 11:28 AM
    You could execute the following on one of your macs to get an idea of what is happening:
    sudo /usr/libexec/airportd debug +alluserland +alldriver +allvendor
    You will then be able to see if the mac offers any clues as to what is happening.
    Please PM me your TAC ticket number.
  • 29.  RE: Client stops sending packets
    Posted Jul 07, 2015 08:38 AM
  • 30.  RE: Client stops sending packets
    You mean upgrading the version of the OS? I'll try, an upgrade was relased a few days ago.
    No, I noticed the same issue also with my client when I move in that area.
    In attach the log of my computer (a few days ago). In first lines I added my station to the debug and in the lasts I moved back to my desk in another building (Casone)
    I was concerned about these lines of the first log i posted (I omitted some of them) It seems that the client moves from an ap to another (very far from the area where the client is located)
    Jul  2 15:00:05 10.1.0.101 Jul  2 15:00:25 2015 10.1.97.143 sapd[1126]: <326278> <NOTI> |AP Pad-I_SW@10.1.97.143 sapd| |ap| AM: STA a8:66:7f:01:eb:d1 Authenticated with AP 6c:f3:7f:61:cd:d3
    Jul  2 15:00:05 10.1.0.101 Jul  2 15:00:24 2015 10.1.97.143 sapd[1126]: <326271> <NOTI> |AP Pad-I_SW@10.1.97.143 sapd| |ap| AM: New Node Detected Node = a8:66:7f:01:eb:d1 SSID = COMPANY BSSID 6c:f3:7f:61:cd:d3
    Jul  2 15:00:05 10.1.0.101 Jul  2 15:00:24 2015 10.1.97.143 stm[1139]: <501100> <NOTI> |AP Pad-I_SW@10.1.97.143 stm|  Assoc success @ 15:00:24.976900: a8:66:7f:01:eb:d1: AP 10.1.97.143-6c:f3:7f:61:cd:d3-Pad-I_SW
    Jul  2 15:00:05 10.1.0.101 Jul  2 15:00:24 2015 10.1.97.143 stm[1139]: <501080> <NOTI> |AP Pad-I_SW@10.1.97.143 stm|  Deauth to sta: a8:66:7f:01:eb:d1: Ageout AP 10.1.97.143-6c:f3:7f:61:cd:d2-Pad-I_SW STA has roamed to another AP
    Jul  2 15:00:05 10.1.0.101 Jul  2 15:00:24 2015 10.1.97.143 stm[1139]: <501095> <NOTI> |AP Pad-I_SW@10.1.97.143 stm|  Assoc request @ 15:00:24.971032: a8:66:7f:01:eb:d1 (SN 44): AP 10.1.97.143-6c:f3:7f:61:cd:d3-Pad-I_SW
    Jul  2 15:00:05 10.1.0.101 Jul  2 15:00:24 2015 10.1.97.143 stm[1139]: <501093> <NOTI> |AP Pad-I_SW@10.1.97.143 stm|  Auth success: a8:66:7f:01:eb:d1: AP 10.1.97.143-6c:f3:7f:61:cd:d3-Pad-I_SW
    Jul  2 15:00:05 10.1.0.101 Jul  2 15:00:24 2015 10.1.97.143 stm[1139]: <501109> <NOTI> |AP Pad-I_SW@10.1.97.143 stm|  Auth request: a8:66:7f:01:eb:d1: AP 10.1.97.143-6c:f3:7f:61:cd:d3-Pad-I_SW auth_alg 0
    Jul  2 14:59:33 10.1.0.101 Jul  2 14:59:52 2015 10.1.97.112 sapd[834]: <326274> <NOTI> |AP Village_1@10.1.97.112 sapd| |ap| AM: Inactive Node Detected  = a8:66:7f:01:eb:d1 SSID = COMPANY BSSID 6c:f3:7f:61:cd:d3
    Attachment(s)
    txt
    log2.txt   21 KB 1 version
