ClientMatch Issue
  • 1.  ClientMatch Issue
    Posted Mar 02, 2015 12:26 PM
    Hi folks,
    i have the Sticky client issue in a WLAN , and i'm using 6.4 firmware, so my question si :
     do client match works with all AP or with new Generation AP2XX only.
    Regards.
  • 2.  RE: ClientMatch Issue
    Posted Mar 02, 2015 12:29 PM
    ClientMatch works with 11n and 11ac access points.
  • 3.  RE: ClientMatch Issue
    Posted Mar 02, 2015 12:33 PM
    and in the two band (2.4 and 5 Ghz)
  • 4.  RE: ClientMatch Issue
    Posted Mar 02, 2015 12:38 PM
    Yes
  • 5.  RE: ClientMatch Issue
    Posted Mar 02, 2015 04:44 PM
    If your AP power is too high, (more than 18dbm), Clientmatch will probably not help, because your clients will continue to hang onto the same AP.  If you have not done so, please try to constrain your MIN TX to 12 and your max tx to 18 in your ARM profile.
