clients are disconnecting and Access point power change is I
  • 1.  clients are disconnecting and Access point power change is I
    Posted Jun 15, 2015 05:58 AM
    Clients are disconnecting frequently in IAP integrated with Airwave.
    EIRP settings are Min and  Max are 18.
    In ARM summery it shows that reason for power change is I (Interference) or M(invalid channel ).
    I have changed EIRP min from 18 to 3 will it work is there any solution ?
    Regards
    Siva.
  • 2.  RE: clients are disconnecting and Access point power change is I
    Posted Jun 15, 2015 06:51 AM
    You should make the ARM minimum 12 and Maximum 18.  Having a low of 3 is too much of a range.
    You should enable "Broadcast Filter ALL" on all of your SSIDs.
    Make sure you are using 20 mhz channels, so you can have as much channel reuse as possible (disable Wide and 80 mhz channels)
  • 3.  RE: clients are disconnecting and Access point power change is I
    Posted Jun 15, 2015 07:05 AM
    Hi ,
    Please find the attached Logs reports and
    i think there is a interference at site and how can i resolve this issue.
    this cluster manages the other aps.
    please help for resolution and how i can verify this.
    regards
    Siva.
  • 4.  RE: clients are disconnecting and Access point power change is I
    Posted Jun 15, 2015 07:09 AM
    There are no logs attached.
