Clients doesnt roam properly / Doesnt connect to best AP
  • 1.  Clients doesnt roam properly / Doesnt connect to best AP
    Posted Mar 21, 2016 07:06 AM
    we've just deployed 10 IAP (215 and 205) Accesspoints running the latest GA Firmware in our office and the clients doesnt roam properly. If i reconnect with my laptop, it doesnt connects me to the best one.
    Thanks in advance
    Simon
    wlan ssid-profile ************
     enable
     index 0
     type employee
     essid  ************
     opmode wpa2-aes
     max-authentication-failures 0
     vlan 50
     auth-server  ************
     rf-band all
     captive-portal disable
     dtim-period 1
     inactivity-timeout 1000
     broadcast-filter all
     g-min-tx-rate 11
     a-min-tx-rate 12
     dmo-channel-utilization-threshold 90
     local-probe-req-thresh 0
     max-clients-threshold 64
     okc
     dot11k
     dot11v
    arm
     wide-bands 5ghz
     80mhz-support
     min-tx-power 12
     max-tx-power 18
     band-steering-mode force-5ghz
     air-time-fairness-mode default-access
     client-aware
     scanning
     client-match
     client-match nb-matching 90
     client-match calc-threshold 2
     client-match calc-interval 10
     client-match slb-mode 2
     client-match debug 0
     client-match holdtime 1
    arubawifi01# show version
    ArubaOS (MODEL: 215), Version 6.4.2.6-4.1.1.11
    Website: http://www.arubanetworks.com
    Copyright (c) 2002-2015, Aruba Networks, Inc.
    Compiled on 2015-11-22 at 16:41:06 PST (build 52666) by p4build
    Client Match Action Table
    Station            Old State  New State  Reason             Radio  Time
    88:63:df:  Normal     Normal     Client left        1      11:53:17
    c8:1e:e7:  Normal     Normal     Client associated  1      11:53:30
    c8:1e:e7:  Normal     Normal     Client left        1      11:53:37
    8c:3a:e3: Normal     Normal     Client associated  0      11:54:54
    88:c9:d0:  Normal     Normal     Client left        1      11:56:00
    Virtual Beacon Table
    Station            CM State  Triggered  Succeeded  Owner  AP                           RSSI  Received
    84:8e:df:ff  Normal    0          0          No     40:e3:d6 (Local 0)  7     15s
                       Normal                          No     40:e3:d6:41:e0:40 (Local 1)  8     16s
                                                       No     40:e3:d6:            16    10s
                                                       No     40:e3:d6:            13    2s
                                                       No     04:bd:88:            40    6s
                                                       No     40:e3:d6:           25    2s
                                                       No     04:bd:88          32    6s
                                                       No     40:e3:d6:            30    2s
                                                       No     40:e3:d6:            26    7s
                                                       Yes    40:e3:d6:            20    2s
    Client Match Neighbor Table
    MAC                Channel  RSSI  Clients  Threshold  Channel Util (%)  VC Key    Flags  Received
    40:e3:d6:  100E     -     6        5          1                 -         -      -
    40:e3:d6:  6        -     13       255        18                -         -      -
    40:e3:d6:  36E      0     3        255        2                 fe9c75c3  VRIC   0s
    40:e3:d6: 1        0     1        255        53                fe9c75c3  VIC    1s
    40:e3:d6: 6        0     5        255        31                fe9c75c3  VICS   1s
    40:e3:d6:  36E      0     2        5          2                 fe9c75c3  VIC    0s
    04:bd:88:  116E     0     5        4          1                 fe9c75c3  VICB   0s
    04:bd:88:  11       0     4        255        16                fe9c75c3  VIC    1s
    40:e3:d6:  1        0     4        255        47                fe9c75c3  VIC    1s
    40:e3:d6:  116E     0     3        4          1                 fe9c75c3  VIC    0s
    40:e3:d6:  52E      0     4        4          0                 fe9c75c3  VICB   0s
    40:e3:d6:  1        0     2        255        24                fe9c75c3  VIC    0s
    40:e3:d6:  1        0     9        255        17                fe9c75c3  VIC    1s
    40:e3:d6:0  36E      0     5        5          1                 fe9c75c3  VICB   0s
    Neighbor Flags:      V - Valid;       R - In RF Neighborhood;      S - Same Channel;
                         B - Balancing;   C - Client Match Enabled;    I - In Same Swarm
    Total 14 Neighbors
  • 2.  RE: Clients doesnt roam properly / Doesnt connect to best AP
    Posted Mar 21, 2016 07:11 AM
    - What is your regulatory domain?
    - Please uncheck Client Match--- in Version 4.2.x.x it is hardened, but it is not as effective in 4.1.1.11
    - What are the clients with the problems?
    - How far apart are your access points and how are the mounted? (on the ceiling or on the wall)
  • 3.  RE: Clients doesnt roam properly / Doesnt connect to best AP
    Posted Mar 21, 2016 07:22 AM
    Thanks for your really fast answer!
    Reg Domain is RW.
    It doesnt matter what clients are used. Following are we using Android, iPhone, Linux iwlwifi, Mac OS
    APs are mounted at the ceiling
    First will upgrade to Release 6.4.4.3-4.2.2.0 and check if problems are still happening. Are there other things to improve or take a look of? Can i supply you with more infos?
  • 4.  RE: Clients doesnt roam properly / Doesnt connect to best AP
    Posted Mar 21, 2016 07:45 AM
    - The regulatory domain matters (there is no RW regulatory domain), because you are using DFS channels.  Not all clients can "see" DFS channels, so that would contribute to poor roaming.  You should only use channels 36 40 44 48 149 153 157 161 165 (EDIT: and 1 6 11) to ensure that is not what is happening.
    - You are using 80mhz channels, which many clients do not support as of yet, so combined with using DFS channels, your clients might not be seeing all of the access points they can see.  In the ARM profile, I would uncheck 80mhz channels and set "Wide Channels" to "None"
    - How far apart are your access points?
    - Upgrading to 4.2.x.x will not change things much.  If you have the problems above, client match will not help clients connect to channels they do not support.
  • 5.  RE: Clients doesnt roam properly / Doesnt connect to best AP
    Posted Mar 21, 2016 08:09 AM
    How to find out regularity Domain? Is this what your're asking for? I'm in Germany.
    virtual-controller-country DE
     Is my channel set okay, according to my reg. domain?
    Wide channels disabled for now. 80mhz also.
    Access Points are 20-30meters apart and every serves up to 25 Users
  • 6.  RE: Clients doesnt roam properly / Doesnt connect to best AP
    Posted Mar 21, 2016 08:12 AM
    You should only enable channels 1 6 11 36 40 44 48 149 153 157 161 165 for now.
    Distance seems fine.  Is this an office environment, or an open space?
  • 7.  RE: Clients doesnt roam properly / Doesnt connect to best AP
    Posted Mar 21, 2016 08:31 AM
    Following channels doesnt show up in list: 149 153 157 161 165
    Now i've enabled following channels:
    1 6 11 36 40 44 48
    Is that correct?
    It's an open space, seperated through fire protection doors and walls. I've attached a plan. arubawifi04 is an 205. Blue doors are fire protection doors. All other walls are "plasterboard". The APs are at the ceiling, which has a ~2,7m height.
  • 8.  RE: Clients doesnt roam properly / Doesnt connect to best AP
    Posted Mar 21, 2016 08:37 AM
    Can you see more than one AP in each room?
  • 9.  RE: Clients doesnt roam properly / Doesnt connect to best AP
    Posted Mar 21, 2016 08:42 AM
    Yes! Depending on the position i can see ~2-5 APs with my Laptop.
  • 10.  RE: Clients doesnt roam properly / Doesnt connect to best AP
    Posted Mar 21, 2016 08:43 AM
    At what signal strength?  What application are you using?  Please post a sample screenshot.
  • 11.  RE: Clients doesnt roam properly / Doesnt connect to best AP
    Posted Mar 21, 2016 09:28 AM
    I'm using iw.
    I just walked around and did a scan underneath the AP and in the middlebetween two.
    Starting from arubawifi01 to arubawifi06. - arubawifi08 isnt deployed yet. Therefore it doestn show up
    sudo iw wlp3s0 scan | grep -v Guest | grep eDarling -B09 | grep -E 'SSID|signal|BSS|freq: 5'
    under arubawifi01:
    BSS 40:e3:d6:41:df:10 (arubawifi02)(on wlp3s0)
    	freq: 5240
    	signal: -79.00 dBm
    	SSID: eDarling
    BSS 40:e3:d6:41:e0:50 (arubawifi01)(on wlp3s0)
    	freq: 5200
    	signal: -45.00 dBm
    	SSID: eDarling
    between arubawifi01/02:
    	freq: 5240
    	signal: -52.00 dBm
    	SSID: eDarling
    	freq: 5200
    	signal: -58.00 dBm
    	SSID: eDarling
    BSS 40:e3:d6:41:e0:40(on wlp3s0)
    	signal: -56.00 dBm
    	SSID: eDarling
    under arubawifi02:
    	freq: 5240
    	signal: -51.00 dBm
    	SSID: eDarling
    	freq: 5200
    	signal: -81.00 dBm
    	SSID: eDarling
    BSS 04:bd:88:5f:f2:10 (arubawifi03)(on wlp3s0)
    	freq: 5180
    	signal: -81.00 dBm
    	SSID: eDarling
    between arubawifi02/3
    	freq: 5240
    	signal: -56.00 dBm
    	SSID: eDarling
    	freq: 5200
    	signal: -81.00 dBm
    	SSID: eDarling
    	freq: 5180
    	signal: -73.00 dBm
    	SSID: eDarling
    BSS 40:e3:d6:41:de:30 (arubawifi05)(on wlp3s0)
    	freq: 5220
    	signal: -90.00 dBm
    	SSID: eDarling
    under arubawifi03
        freq: 5240
        signal: -79.00 dBm
        SSID: eDarling
        freq: 5200
        signal: -81.00 dBm
        SSID: eDarling
        freq: 5180
        signal: -45.00 dBm
        SSID: eDarling
        freq: 5220
        signal: -90.00 dBm
        SSID: eDarling
    BSS 40:e3:d6:3e:ee:d0 (arubawifi04) (arubawifi04)(on wlp3s0)
        freq: 5180
        signal: -67.00 dBm
        SSID: eDarling
    between arubawifi03/04:
    	freq: 5240
    	signal: -78.00 dBm
    	SSID: eDarling
    	freq: 5180
    	signal: -54.00 dBm
    	SSID: eDarling
    	freq: 5220
    	signal: -82.00 dBm
    	SSID: eDarling
    	freq: 5180
    	signal: -61.00 dBm
    	SSID: eDarling
    under arubawifi04:
    	freq: 5240
    	signal: -78.00 dBm
    	SSID: eDarling
    	freq: 5180
    	signal: -67.00 dBm
    	SSID: eDarling
    	freq: 5220
    	signal: -73.00 dBm
    	SSID: eDarling
    	freq: 5180
    	signal: -39.00 dBm
    	SSID: eDarling
    BSS 40:e3:d6:3c:01:d0 (arubawifi06)(on wlp3s0)
    	freq: 5220
    	signal: -80.00 dBm
    	SSID: eDarling
    between arubawifi04/5
    	freq: 5240
    	signal: -86.00 dBm
    	SSID: eDarling
    	freq: 5180
    	signal: -81.00 dBm
    	SSID: eDarling
    	freq: 5220
    	signal: -48.00 dBm
    	SSID: eDarling
    	freq: 5180
    	signal: -54.00 dBm
    	SSID: eDarling
    	freq: 5220
    	signal: -72.00 dBm
    	SSID: eDarling
    BSS 40:e3:d6:41:e0:90 (arubawifi07)(on wlp3s0)
    	freq: 5200
    	signal: -91.00 dBm
    	SSID: eDarling
    under arubawifi05:
    	freq: 5180
    	signal: -90.00 dBm
    	SSID: eDarling
    	freq: 5220
    	signal: -39.00 dBm
    	SSID: eDarling
    	freq: 5180
    	signal: -80.00 dBm
    	SSID: eDarling
    	freq: 5220
    	signal: -59.00 dBm
    	SSID: eDarling
    	freq: 5200
    	signal: -83.00 dBm
    	SSID: eDarling
    between arubawifi05/06:
    	freq: 5180
    	signal: -90.00 dBm
    	SSID: eDarling
    	freq: 5220
    	signal: -59.00 dBm
    	SSID: eDarling
    	freq: 5180
    	signal: -80.00 dBm
    	SSID: eDarling
    	freq: 5220
    	signal: -53.00 dBm
    	SSID: eDarling
    	freq: 5200
    	signal: -69.00 dBm
    	SSID: eDarling
    under arubawifi06:
    	freq: 5180
    	signal: -90.00 dBm
    	SSID: eDarling
    	freq: 5220
    	signal: -71.00 dBm
    	SSID: eDarling
    	freq: 5180
    	signal: -80.00 dBm
    	SSID: eDarling
    	freq: 5220
    	signal: -37.00 dBm
    	SSID: eDarling
    	freq: 5200
    	signal: -69.00 dBm
    	SSID: eDarling
  • 12.  RE: Clients doesnt roam properly / Doesnt connect to best AP
    Posted Mar 21, 2016 10:08 AM
    Okay.  It seems that under APs, you really cannot see more than one access point in most circumstances; so you don't have alot of density.  Most Clients will look to roam when the AP they are connecting to drops to -75.
    When did you make the change below?
    g-min-tx-rate 11
     a-min-tx-rate 12
     You might want to change those back to the defaults, if things don't improve.  You would typically increase those values greater than the defaults when you have enough density, and it seems like there is not alot of density; just coverage.
  • 13.  RE: Clients doesnt roam properly / Doesnt connect to best AP
    Posted Mar 21, 2016 10:24 AM
    I did this change some days ago to force roaming faster, but this didnt realy helped.
    With the new firmware version and settings client match and roaming at all seems to work better. I now can see that the APs try to match the clients. But very often CM is failing because all other APs are denying in some cases, even they report a much better rssi.
    Are there things to fine tune there?
  • 14.  RE: Clients doesnt roam properly / Doesnt connect to best AP
    Posted Mar 21, 2016 10:38 AM
    You can put the rates back to their defaults:
    g-min-tx-rate 11
     a-min-tx-rate 12
    If clientmatch tries to steer a client and it cannot connect because the minimum rates are too high, that could be the reason for the failures.
  • 15.  RE: Clients doesnt roam properly / Doesnt connect to best AP
    Posted Mar 21, 2016 11:05 AM
    I've set them back to defaults.
    Thank you very much for your help! It seems the Problem is fixed. I'll verify this and then may mark this topic as fixed.
  • 16.  RE: Clients doesnt roam properly / Doesnt connect to best AP
    Posted Mar 21, 2016 08:38 AM
    1 6 11 36 40 44 48
    Is that correct?
    Your channels are correct for DE, yes.
