Clients getting disconnected regularly from AP 115
  • 1.  Clients getting disconnected regularly from AP 115
    Posted Jun 23, 2020 07:48 PM
     6/23/2020 19:41:13 PM    Target:     Command: show log system
    Jun 23 22:37:59  cli[2446]: <341004> <WARN> |AP ac:a3:1e:ca:b5:68@192.168.0.11 cli|  /etc/setup_ip_swarm Ethernet 1
    Jun 23 22:37:59  cli[2446]: <341166> <WARN> |AP ac:a3:1e:ca:b5:68@192.168.0.11 cli|  Get interface br0 ip: 192.168.0.11/255.255.255.0.
    Jun 23 22:37:59  cli[2446]: <341185> <WARN> |AP ac:a3:1e:ca:b5:68@192.168.0.11 cli|  Retrieving ip address from br0, ip 192.168.0.11, mask 255.255.255.0.
    Jun 23 22:37:59  cli[2446]: <341274> <WARN> |AP ac:a3:1e:ca:b5:68@192.168.0.11 cli|  Update election ip from br0, election ip 192.168.0.11/255.255.255.0.
    Jun 23 22:37:59  cli[2446]: <341004> <WARN> |AP ac:a3:1e:ca:b5:68@192.168.0.11 cli|  build_my_ip_address: old ip and new ip same; skipping
    Jun 23 22:37:59  cli[2446]: <341006> <CRIT> |AP ac:a3:1e:ca:b5:68@192.168.0.11 cli|  Sending uplink_up msg to sapd
    Jun 23 22:37:59  cli[2446]: <341006> <CRIT> |AP ac:a3:1e:ca:b5:68@192.168.0.11 cli|  trap uplink info.
    Jun 23 22:37:59  cli[2446]: <341004> <WARN> |AP ac:a3:1e:ca:b5:68@192.168.0.11 cli|  last uplink is null, it's the first uplink, ignore this trap.
    Jun 23 22:37:59  cli[2446]: <341264> <WARN> |AP ac:a3:1e:ca:b5:68@192.168.0.11 cli|  disable uplink .
    Jun 23 22:37:59  cli[2446]: <341167> <WARN> |AP ac:a3:1e:ca:b5:68@192.168.0.11 cli|  Uplink  type Dummy, state PROBE->DOWN.
    Jun 23 22:37:59  cli[2446]: <341004> <WARN> |AP ac:a3:1e:ca:b5:68@192.168.0.11 cli|  disable dummy uplink
    Jun 23 22:37:59  cli[2446]: <341004> <WARN> |AP ac:a3:1e:ca:b5:68@192.168.0.11 cli|  enable SSID[arb
    Jun 23 22:38:02  cli[2446]: <341004> <WARN> |AP ac:a3:1e:ca:b5:68@192.168.0.11 cli|  recv non-3g setup_uplink finished from sapd
    Jun 23 22:38:10  nanny[2397]: <303073> <ERRS> |AP ac:a3:1e:ca:b5:68@192.168.0.11 nanny|  Process /aruba/bin/ntpclient [pid 7659] died: got signal SIGTERM
    Jun 23 22:38:10  nanny[2397]: <303079> <ERRS> |AP ac:a3:1e:ca:b5:68@192.168.0.11 nanny|  Restarted process /aruba/bin/ntpclient, new pid 9038
    Jun 23 23:12:50  cli[2446]: <341271> <ERRS> |AP ac:a3:1e:ca:b5:68@192.168.0.11 cli|  ethernet uplink bond0 link down.
    Jun 23 23:12:50  cli[2446]: <341004> <WARN> |AP ac:a3:1e:ca:b5:68@192.168.0.11 cli|  stopping DHCP on bond0
    Jun 23 23:12:50  cli[2446]: <341185> <WARN> |AP ac:a3:1e:ca:b5:68@192.168.0.11 cli|  Retrieving ip address from br0, ip 192.168.0.11, mask 255.255.255.0.
    Jun 23 23:12:50  cli[2446]: <341274> <WARN> |AP ac:a3:1e:ca:b5:68@192.168.0.11 cli|  Update election ip from br0, election ip 192.168.0.11/255.255.255.0.
    Jun 23 23:12:50  cli[2446]: <341004> <WARN> |AP ac:a3:1e:ca:b5:68@192.168.0.11 cli|  build_my_ip_address: old ip and new ip same; skipping
    Jun 23 23:12:50  cli[2446]: <341167> <WARN> |AP ac:a3:1e:ca:b5:68@192.168.0.11 cli|  Uplink bond0 type Ethernet, state UP->DOWN.
    Jun 23 23:12:50  cli[2446]: <341263> <WARN> |AP ac:a3:1e:ca:b5:68@192.168.0.11 cli|  enable uplink .
    Jun 23 23:12:50  cli[2446]: <341167> <WARN> |AP ac:a3:1e:ca:b5:68@192.168.0.11 cli|  Uplink  type Dummy, state DOWN->PROBE.
    Jun 23 23:12:50  cli[2446]: <341004> <WARN> |AP ac:a3:1e:ca:b5:68@192.168.0.11 cli|  enable dummy uplink
    Jun 23 23:12:50  cli[2446]: <341004> <WARN> |AP ac:a3:1e:ca:b5:68@192.168.0.11 cli|  disable SSID[arb
    Jun 23 23:12:53  cli[2446]: <341272> <ERRS> |AP ac:a3:1e:ca:b5:68@192.168.0.11 cli|  ethernet uplink bond0 link up.
    Jun 23 23:12:53  cli[2446]: <341167> <WARN> |AP ac:a3:1e:ca:b5:68@192.168.0.11 cli|  Uplink bond0 type Ethernet, state DOWN->UP.
    Jun 23 23:12:53  cli[2446]: <341166> <WARN> |AP ac:a3:1e:ca:b5:68@192.168.0.11 cli|  Get interface br0 ip: 192.168.0.11/255.255.255.0.
    Jun 23 23:12:53  cli[2446]: <341005> <ERRS> |AP ac:a3:1e:ca:b5:68@192.168.0.11 cli|  wired reset detected, setup ip now
    Jun 23 23:12:53  cli[2446]: <341181> <WARN> |AP ac:a3:1e:ca:b5:68@192.168.0.11 cli|  Uplink bond0, setup ip for uplink - Ethernet.
    Jun 23 23:12:53  cli[2446]: <341004> <WARN> |AP ac:a3:1e:ca:b5:68@192.168.0.11 cli|  bring up dhcp client for ethernet uplink
    Jun 23 23:12:54  cli[2446]: <341004> <WARN> |AP ac:a3:1e:ca:b5:68@192.168.0.11 cli|  /etc/setup_ip_swarm Ethernet 1
    Jun 23 23:12:54  cli[2446]: <341166> <WARN> |AP ac:a3:1e:ca:b5:68@192.168.0.11 cli|  Get interface br0 ip: 192.168.0.11/255.255.255.0.
    Jun 23 23:12:54  cli[2446]: <341185> <WARN> |AP ac:a3:1e:ca:b5:68@192.168.0.11 cli|  Retrieving ip address from br0, ip 192.168.0.11, mask 255.255.255.0.
    Jun 23 23:12:54  cli[2446]: <341274> <WARN> |AP ac:a3:1e:ca:b5:68@192.168.0.11 cli|  Update election ip from br0, election ip 192.168.0.11/255.255.255.0.
    Jun 23 23:12:54  cli[2446]: <341004> <WARN> |AP ac:a3:1e:ca:b5:68@192.168.0.11 cli|  build_my_ip_address: old ip and new ip same; skipping
    Jun 23 23:12:54  cli[2446]: <341006> <CRIT> |AP ac:a3:1e:ca:b5:68@192.168.0.11 cli|  Sending uplink_up msg to sapd
    Jun 23 23:12:54  cli[2446]: <341006> <CRIT> |AP ac:a3:1e:ca:b5:68@192.168.0.11 cli|  trap uplink info.
    Jun 23 23:12:54  cli[2446]: <341004> <WARN> |AP ac:a3:1e:ca:b5:68@192.168.0.11 cli|  last uplink is null, it's the first uplink, ignore this trap.
    Jun 23 23:12:54  cli[2446]: <341264> <WARN> |AP ac:a3:1e:ca:b5:68@192.168.0.11 cli|  disable uplink .
    Jun 23 23:12:54  cli[2446]: <341167> <WARN> |AP ac:a3:1e:ca:b5:68@192.168.0.11 cli|  Uplink  type Dummy, state PROBE->DOWN.
    Jun 23 23:12:54  cli[2446]: <341004> <WARN> |AP ac:a3:1e:ca:b5:68@192.168.0.11 cli|  disable dummy uplink
    Jun 23 23:12:54  cli[2446]: <341004> <WARN> |AP ac:a3:1e:ca:b5:68@192.168.0.11 cli|  enable SSID[arb
    Jun 23 23:12:57  cli[2446]: <341004> <WARN> |AP ac:a3:1e:ca:b5:68@192.168.0.11 cli|  recv non-3g setup_uplink finished from sapd
    Jun 23 23:13:07  nanny[2397]: <303073> <ERRS> |AP ac:a3:1e:ca:b5:68@192.168.0.11 nanny|  Process /aruba/bin/ntpclient [pid 9038] died: got signal SIGTERM
    Jun 23 23:13:07  nanny[2397]: <303079> <ERRS> |AP ac:a3:1e:ca:b5:68@192.168.0.11 nanny|  Restarted process /aruba/bin/ntpclient, new pid 12923
    Jun 23 23:13:41  nanny[2397]: <303073> <ERRS> |AP ac:a3:1e:ca:b5:68@192.168.0.11 nanny|  Process /aruba/bin/radiusd-term [pid 12976] died: got signal SIGTERM
    Jun 23 23:13:41  nanny[2397]: <303079> <ERRS> |AP ac:a3:1e:ca:b5:68@192.168.0.11 nanny|  Restarted process /aruba/bin/radiusd-term, new pid 13023
    Jun 23 23:38:55  cli[2446]: <341271> <ERRS> |AP ac:a3:1e:ca:b5:68@192.168.0.11 cli|  ethernet uplink bond0 link down.
    Jun 23 23:38:55  cli[2446]: <341004> <WARN> |AP ac:a3:1e:ca:b5:68@192.168.0.11 cli|  stopping DHCP on bond0
    Jun 23 23:38:55  cli[2446]: <341185> <WARN> |AP ac:a3:1e:ca:b5:68@192.168.0.11 cli|  Retrieving ip address from br0, ip 192.168.0.11, mask 255.255.255.0.
    Jun 23 23:38:55  cli[2446]: <341274> <WARN> |AP ac:a3:1e:ca:b5:68@192.168.0.11 cli|  Update election ip from br0, election ip 192.168.0.11/255.255.255.0.
    Jun 23 23:38:55  cli[2446]: <341004> <WARN> |AP ac:a3:1e:ca:b5:68@192.168.0.11 cli|  build_my_ip_address: old ip and new ip same; skipping
    Jun 23 23:38:55  cli[2446]: <341167> <WARN> |AP ac:a3:1e:ca:b5:68@192.168.0.11 cli|  Uplink bond0 type Ethernet, state UP->DOWN.
    Jun 23 23:38:55  cli[2446]: <341263> <WARN> |AP ac:a3:1e:ca:b5:68@192.168.0.11 cli|  enable uplink .
    Jun 23 23:38:55  cli[2446]: <341167> <WARN> |AP ac:a3:1e:ca:b5:68@192.168.0.11 cli|  Uplink  type Dummy, state DOWN->PROBE.
    Jun 23 23:38:55  cli[2446]: <341004> <WARN> |AP ac:a3:1e:ca:b5:68@192.168.0.11 cli|  enable dummy uplink
    Jun 23 23:38:55  cli[2446]: <341004> <WARN> |AP ac:a3:1e:ca:b5:68@192.168.0.11 cli|  disable SSID[arb
    Jun 23 23:38:58  cli[2446]: <341272> <ERRS> |AP ac:a3:1e:ca:b5:68@192.168.0.11 cli|  ethernet uplink bond0 link up.
    Jun 23 23:38:58  cli[2446]: <341167> <WARN> |AP ac:a3:1e:ca:b5:68@192.168.0.11 cli|  Uplink bond0 type Ethernet, state DOWN->UP.
    Jun 23 23:38:58  cli[2446]: <341166> <WARN> |AP ac:a3:1e:ca:b5:68@192.168.0.11 cli|  Get interface br0 ip: 192.168.0.11/255.255.255.0.
    Jun 23 23:38:58  cli[2446]: <341005> <ERRS> |AP ac:a3:1e:ca:b5:68@192.168.0.11 cli|  wired reset detected, setup ip now
    Jun 23 23:38:58  cli[2446]: <341181> <WARN> |AP ac:a3:1e:ca:b5:68@192.168.0.11 cli|  Uplink bond0, setup ip for uplink - Ethernet.
    :38:59  cli[2446]: <341004> <WARN> |AP ac:a3:1e:ca:b5:68@192.168.0.11 cli|  /etc/setup_ip_swarm Ethernet 1
    Jun 23 23:38:59  cli[2446]: <341166> <WARN> |AP ac:a3:1e:ca:b5:68@192.168.0.11 cli|  Get interface br0 ip: 192.168.0.11/255.255.255.0.
    Jun 23 23:38:59  cli[2446]: <341185> <WARN> |AP ac:a3:1e:ca:b5:68@192.168.0.11 cli|  Retrieving ip address from br0, ip 192.168.0.11, mask 255.255.255.0.
    Jun 23 23:38:59  cli[2446]: <341274> <WARN> |AP ac:a3:1e:ca:b5:68@192.168.0.11 cli|  Update election ip from br0, election ip 192.168.0.11/255.255.255.0.
    Jun 23 23:38:59  cli[2446]: <341004> <WARN> |AP ac:a3:1e:ca:b5:68@192.168.0.11 cli|  build_my_ip_address: old ip and new ip same; skipping
    Jun 23 23:38:59  cli[2446]: <341006> <CRIT> |AP ac:a3:1e:ca:b5:68@192.168.0.11 cli|  Sending uplink_up msg to sapd
    Jun 23 23:38:59  cli[2446]: <341006> <CRIT> |AP ac:a3:1e:ca:b5:68@192.168.0.11 cli|  trap uplink info.
    Jun 23 23:38:59  cli[2446]: <341004> <WARN> |AP ac:a3:1e:ca:b5:68@192.168.0.11 cli|  last uplink is null, it's the first uplink, ignore this trap.
    Jun 23 23:38:59  cli[2446]: <341264> <WARN> |AP ac:a3:1e:ca:b5:68@192.168.0.11 cli|  disable uplink .
    Jun 23 23:38:59  cli[2446]: <341167> <WARN> |AP ac:a3:1e:ca:b5:68@192.168.0.11 cli|  Uplink  type Dummy, state PROBE->DOWN.
    Jun 23 23:38:59  cli[2446]: <341004> <WARN> |AP ac:a3:1e:ca:b5:68@192.168.0.11 cli|  disable dummy uplink
    Jun 23 23:38:59  cli[2446]: <341004> <WARN> |AP ac:a3:1e:ca:b5:68@192.168.0.11 cli|  enable SSID[arb
    Jun 23 23:39:02  cli[2446]: <341004> <WARN> |AP ac:a3:1e:ca:b5:68@192.168.0.11 cli|  recv non-3g setup_uplink finished from sapd
    Jun 23 23:39:10  nanny[2397]: <303073> <ERRS> |AP ac:a3:1e:ca:b5:68@192.168.0.11 nanny|  Process /aruba/bin/ntpclient [pid 12923] died: got signal SIGTERM
    Jun 23 23:39:10  nanny[2397]: <303079> <ERRS> |AP ac:a3:1e:ca:b5:68@192.168.0.11 nanny|  Restarted process /aruba/bin/ntpclient, new pid 15836
  • 2.  RE: Clients getting disconnected regularly from AP 115
    Posted Jul 10, 2020 04:08 AM
    Looks like your AP Uplink connection is not stable.
  • 3.  RE: Clients getting disconnected regularly from AP 115
    Posted Jul 10, 2020 09:06 PM
    Sometimes i also get "Access point temporarily full". I dont think that is related.
    is there something i can do to fix both the issues?
  • 4.  RE: Clients getting disconnected regularly from AP 115
    Posted Jul 13, 2020 11:20 AM
    How many Clients did you have connected on the AP?
    Did you checked the Switch Port Counters like Port errors etc.?
    If you see same issue on the switch I would suggest to exchange the Patch Cable.
    Your Uplink Port is flapping.
