Clients lose connectivity with Big file transfers.
  • 1.  Clients lose connectivity with Big file transfers.
    Posted Feb 18, 2013 11:10 PM
    Hi.
    My problem is that when I try to share files of 8 Gb or above with 5-8 machines at the same time in different APs the transfer starts OK but at certain time the user get disconnected from the AP and the transfer couldn't finish.
    After the disconnection the user reconnects again normally and this only occurs in this scenario.
    I don't have any bandwidth contracts or black list policies.
    These machines are new and the files are tools  shared from some internal servers.
    Any Ideas about why these machines are getting disconnected from the wireless in these case?.
    Thanks in advance.
  • 2.  RE: Clients lose connectivity with Big file transfers.
    Posted Feb 19, 2013 12:55 AM
    Contention.
  • 3.  RE: Clients lose connectivity with Big file transfers.
    Posted Feb 19, 2013 08:50 AM
    Contention? where can I read about this to can understand it?
    Thanks.
  • 4.  RE: Clients lose connectivity with Big file transfers.
    Posted Feb 19, 2013 04:41 AM
    have you tried  to enable Air Time Fairness?
    What it's the error loks like from the controller side?  Look for the discconect event
  • 5.  RE: Clients lose connectivity with Big file transfers.
    Posted Feb 19, 2013 08:53 AM
    No I don´t have the Air Time Fairness activated  but I will try it today.
    Thanks.
  • 6.  RE: Clients lose connectivity with Big file transfers.
    Posted Feb 19, 2013 08:54 AM
    If you have a device that is demanding a lot of limited bandwidth, other devices will suffer.
  • 7.  RE: Clients lose connectivity with Big file transfers.
    Posted Feb 19, 2013 09:56 AM
    But there are not other devices suffering, There are only disconnections from devices that are doing the file transfer.
    Other devices works normally.
  • 8.  RE: Clients lose connectivity with Big file transfers.
    Posted Feb 19, 2013 09:57 AM
    Please open a support case.  They will dig into your details and determine what is going on.
  • 9.  RE: Clients lose connectivity with Big file transfers.
    Posted Feb 19, 2013 10:15 AM
    Ok I will do it.
    Thanks cjoseph.
  • 10.  RE: Clients lose connectivity with Big file transfers.
    Posted Feb 20, 2013 07:14 AM
    Did the airtime fairness helped?
    One of our costumers suffered the same problem but it was due the Wireless Adapters they used.
  • 11.  RE: Clients lose connectivity with Big file transfers.
    Posted Feb 21, 2013 11:34 AM
    Thanks. The problem was the adapter parameters. This equips was new and they doesn´t have enough battery.
    the problem was solved charging first the battery at 100% after that the equip works good. The adaptor is Dell 1540.
