last person joined: 8 hours ago
Clients on Aruba Instant cant reach network resources, Can get IP
  • 1.  Clients on Aruba Instant cant reach network resources, Can get IP
    Posted Mar 25, 2015 12:18 PM
    Thanks in advance for the help, I'm broadcasting two SSID's. I can connect to each of them and get an IP address but then i cant get to any of the resources on the domain.
    ac:a3:1e:c0:5f:2a# show run
    version 6.4.0.0-4.1.0
    virtual-controller-country US
    virtual-controller-key fbae5e0901a27461ca6b12122b5dd9499bf2a5c330300143ee
    name instant-C0:5F:2A
    terminal-access
    telnet-server
    clock timezone none 00 00
    rf-band all
    allow-new-aps
    allowed-ap ac:a3:1e:c0:5f:2a
    arm
    wide-bands 5ghz
    80mhz-support
    min-tx-power 18
    max-tx-power 127
    band-steering-mode prefer-5ghz
    air-time-fairness-mode fair-access
    client-aware
    scanning
    ip dhcp pool
    subnet 10.1.62.0
    subnet-mask 255.255.255.0
    dns-server 10.1.20.10
    domain-name tecu.local
    lease-time 43200
    syslog-level warn ap-debug
    syslog-level warn network
    syslog-level warn security
    syslog-level warn system
    syslog-level warn user
    syslog-level warn user-debug
    syslog-level warn wireless
    extended-ssid
    mgmt-user admin 237877e24f8d38a157c737773101457c
    wlan access-rule default_wired_port_profile
    index 0
    rule any any match any any any permit
    wlan access-rule wired-instant
    index 1
    rule masterip 0.0.0.0 match tcp 80 80 permit
    rule masterip 0.0.0.0 match tcp 4343 4343 permit
    rule any any match udp 67 68 permit
    rule any any match udp 53 53 permit
    wlan access-rule Outdoor
    index 2
    wlan access-rule Test
    index 3
    wlan ssid-profile Outdoor
    enable
    index 0
    type employee
    essid Outdoor
    wpa-passphrase 3572d4a30955935610d93f6553035a61e637151861f47bb2
    opmode wpa2-psk-aes
    max-authentication-failures 0
    vlan 1
    auth-server InternalServer
    rf-band all
    captive-portal disable
    dtim-period 1
    inactivity-timeout 10000
    broadcast-filter arp
    dmo-channel-utilization-threshold 90
    local-probe-req-thresh 0
    max-clients-threshold 64
    wlan ssid-profile Test
    enable
    index 1
    type employee
    essid Test
    wpa-passphrase b97adbc4930eade35fd5ec0a5865b61e207d8b5f4932aabf
    opmode wpa2-psk-aes
    vlan 200
    rf-band all
    dtim-period 1
    auth-survivability cache-time-out 24
    dpi
    wlan external-captive-portal
    server localhost
    port 80
    url "/"
    auth-text "Authenticated"
    auto-whitelist-disable
    https
    blacklist-time 3600
    auth-failure-blacklist-time 3600
    ids
    wireless-containment none
    ip dhcp 62
    server-type Distributed,L2
    server-vlan 62
    ip-range 10.1.62.220 10.1.62.239
    lease-time 60000
    default-router 10.1.62.1
    client-count 4
    ip dhcp Test
    server-type Local
    server-vlan 200
    subnet 10.1.200.1
    exclude-address 10.1.200.1
    lease-time 60000
    wired-port-profile wired-instant
    switchport-mode access
    allowed-vlan all
    native-vlan guest
    no shutdown
    access-rule-name wired-instant
    speed auto
    duplex auto
    no poe
    type guest
    no dot1x
    wired-port-profile default_wired_port_profile
    switchport-mode trunk
    allowed-vlan all
    native-vlan 1
    shutdown
    access-rule-name default_wired_port_profile
    speed auto
    duplex full
    no poe
    type employee
    no dot1x
    enet0-port-profile default_wired_port_profile
    uplink
    preemption
    enforce none
    failover-internet-pkt-lost-cnt 10
    failover-internet-pkt-send-freq 30
    failover-vpn-timeout 180
    airgroup
    disable
    airgroupservice airplay
    disable
    description AirPlay
    airgroupservice airprint
    disable
    description AirPrint
  • 2.  RE: Clients on Aruba Instant cant reach network resources, Can get IP
    Posted Mar 25, 2015 12:46 PM
    HI,
    Do you have any IAP VPN with the Controller ?? if so please check the status of the tunnel.
    Please free for any further help on this.
  • 3.  RE: Clients on Aruba Instant cant reach network resources, Can get IP
    Posted Mar 25, 2015 12:49 PM
    This is my first IAP and will probably be the only one. So it is the controller i guess. I dont have any type of VPN setup on it.
  • 4.  RE: Clients on Aruba Instant cant reach network resources, Can get IP
    Posted Mar 26, 2015 05:24 AM
    How do you want to provide IP address to clients ? IAP or through external DHCP ?
    In the above config I'm seeing L2 distributed DHCP which is required when you want to have VPN tunnel with the Controller and DHCP in the IAP. please remove that if you do not have any VPN with the controller.
    Please comeback with the above asked information, we can fix the issue.
  • 5.  RE: Clients on Aruba Instant cant reach network resources, Can get IP
    Posted Mar 26, 2015 07:20 AM
    Does you network know how to route back the IP blocks for the DHCP addresses to the IAP?
  • 6.  RE: Clients on Aruba Instant cant reach network resources, Can get IP
    Posted Mar 30, 2015 12:13 PM
    How would i go about doing that? on the switch? or inside the IAP?
  • 7.  RE: Clients on Aruba Instant cant reach network resources, Can get IP
    Posted Apr 08, 2015 10:24 AM
    It seems that you have your uplink port on trunk. Are you doing that by choice or you need the iAP to do a sourceNAT ?
