Clients seem to randomly lose access
  • 1.  Clients seem to randomly lose access
    Posted Oct 28, 2015 05:03 PM
    I have some stationary computers that are losing their connection to the AP.   It has the latest firmware on it.
  • 2.  RE: Clients seem to randomly lose access
    Posted Oct 28, 2015 06:47 PM
    If your clients are running Intel 7260 cards, you might take a look at this thread.  It has quite a bit of information about the issues that peopel are seeing with those specific cards.
    If it's not that, adding a bit more detail might help diagnose the issue.  What AP's?  What clients?
  • 3.  RE: Clients seem to randomly lose access
    Posted Oct 28, 2015 11:25 PM
    I'm going onsite tomorrow to see if I can gather any info.  They are all AP225s.   The workstations are 90% macbooks pro and air.   My guess is no station is more than two years old.  I don't know if the macbooks have any intel nics in them as I usually support PCs.
  • 4.  RE: Clients seem to randomly lose access
    Posted Oct 29, 2015 10:53 AM
    boe,
    Recent macbook pros have Broadcom NICs in them, NOT Intel nics.  If you are having problems, you should open up a TAC case in parallel, so that they can give you ideas about what needs to be done prior to your visit.
  • 5.  RE: Clients seem to randomly lose access
    Posted Oct 29, 2015 11:22 AM
    boe,
    If you  can ssh into the controller, please post the output of "show ap radio-summary"
  • 6.  RE: Clients seem to randomly lose access
    Posted Oct 29, 2015 11:22 PM
    Thanks I just Puttied in and that is not an option on my units - there is Show ap, ap-alert, ap-env, app-services, aps.
    I can do show radio  (not sure if that is close enough)
    94:b4:0f:c8:87:fc  IAP6# show radio
    2.4 GHz:
    Legacy Mode:disable
    Single Chain Legacy:disable
    Beacon Interval:100
    802.11d/802.11h:disable
    Interference Immunity Level:2
    Channel Switch Announcement Count:0
    MAX Distance:600
    Channel Reuse Type:disable
    Channel Reuse Threshold:0
    Background Spectrum Monitor:disable
    Max Tx Power:0
    Min Tx Power:0
    5.0 GHz:
    Legacy Mode:disable
    Beacon Interval:100
    MAX Distance:600
    Standalone Spectrum Band:5ghz-upper
    Max Tx Power:0
    Min Tx Power:0
    I do notice the TX power - I think mine are set for 12 to max not sure what this is saying.
  • 7.  RE: Clients seem to randomly lose access
    Posted Oct 30, 2015 08:55 AM
    try "show ap arm history"
  • 8.  RE: Clients seem to randomly lose access
    Posted Oct 30, 2015 10:03 AM
    Interface :wifi0
    ARM History
    Time of Change       Old Channel  New Channel  Old Power  New Power  Reason
    2015-10-30 13:55:57  36+          132+         24         24         Q
    2015-10-30 13:53:48  100+         36+          24         24         M
    2015-10-30 13:47:24  108+         100+         24         24         I
    2015-10-30 11:22:51  60+          108+         24         24         I
    2015-10-30 11:18:36  36+          60+          24         24         Q
    2015-10-30 11:16:33  132+         36+          24         24         I
    2015-10-30 10:57:27  36+          132+         24         24         Q
    2015-10-30 10:55:20  140+         36+          24         24         M
    2015-10-30 06:49:17  36+          140+         24         24         Q
    2015-10-30 06:47:10  100+         36+          24         24         M
    2015-10-30 06:39:39  140+         100+         24         24         I
    2015-10-30 02:59:53  149+         140+         24         24         I
    2015-10-30 02:51:59  157+         149+         24         24         M
    2015-10-30 01:31:04  157+         157+         Max        24         P-
    Interface :wifi1
    ARM History
    2015-10-30 01:33:36  6            6            15         12         P-
    2015-10-30 01:32:37  6            6            18         15         P-
    2015-10-30 01:31:57  6            6            21         18         P-
    2015-10-30 01:31:46  6            6            24         21         P-
    2015-10-30 01:31:05  6            6            Max        24         P-
    I: Interference, R: Radar detection, N: Noise exceeded, Q: Bad Channel Quality E: Error threshold exceeded, INV: Invalid Channel, G: Rogue AP Containment, M: Empty Channel, P+: Increase Power, P-: Decrease Power, 40INT: 40MHZ intol detected on 2.4G, NO40INT: 40MHz intol cleared on 2.4G, OFF: Turn off Radio, ON: Turn on Radio
  • 9.  RE: Clients seem to randomly lose access
    Posted Oct 30, 2015 10:14 AM
    It seems like your ARM power is too high.  You need to go into ARM and set the Minimum and max to 9 and 15 respectively.  Click on RF> Advanced and then change the parameters like in the highlighted portion of this screenshot:
  • 10.  RE: Clients seem to randomly lose access
    Posted Oct 30, 2015 11:02 AM
    Thanks - I had tried that a few days ago but it didn't seem to help so I put it back.  I'll set it back again.
  • 11.  RE: Clients seem to randomly lose access
    Posted Oct 31, 2015 07:45 AM
    If you look at the ARM history you'll see that a lot of channel-switches are occuring (by ARM), those can be disruptive.
    Questions:
    - Are there muching AP's on the same channel active?
    - What is the noise-floor the AP's are reporting?
    If you have lots AP's on the same channel (at least for 5GHz), you could consider moving to 20MHz channels (instead of 40MHz as it seems to be know).
  • 12.  RE: Clients seem to randomly lose access
    Posted Nov 02, 2015 12:33 PM
    Where do I check the noise floor?
    We have a dozen APs so yes they are all on 1, 6 or 11.   There isn't a lot of switching between channels but there is some.
    Can you let me know where to go to change from 20 to 40hz?
  • 13.  RE: Clients seem to randomly lose access
    Posted Nov 02, 2015 12:39 PM
    @boe wrote:
    The noise should be a column on the AP display in the GUI.
    You can change from 40 to 20 by going to RF> Advanced and Change "Wide Channel Bands" to "None".  Did you change the "Min Transmit Power" on that page to 9?
  • 14.  RE: Clients seem to randomly lose access
    Posted Nov 02, 2015 12:54 PM
    In the RF Dashboard section I see
    All access points - utilization, noise and errors with only 1 green bar at the bottom of each.
    In RF advanced, ARM, I see
    Band steering mode - prefer 5GHz
    Airtime fairness - fair access
    Client match - enabled
    CM Calculating interval 3 sec
    CM neighboring match 75%
    CM threshold 5
    SLB mode Channel,
    min transmit 3
    Max 21
    Client Aware disabled
    Scanning Enabled
    Wide Channel bands and my choices are 5GHz, none, all, 2.4GHz
    I have 80MHz support and my choices are disabled, enabled
    RADIO
    2.4GHz band
    legacy only diabled
    802.11d/802.11h disabled
    beacon interval 100ms
    Interference immunity level 2
    Channel switch announcement 0
    Background spectrum monitoring disabled
    Custom Arm power range (unchecked)
    5GHz band
    legacy only disabled
  • 15.  RE: Clients seem to randomly lose access
    Posted Nov 02, 2015 12:58 PM
    Why is max transmit as high as 21?  That causes roaming issues an disconnects..
    On the SSID portion of that SSID, do you have "Broadcast Filter ARP" enabled?
  • 16.  RE: Clients seem to randomly lose access
    Posted Nov 02, 2015 01:20 PM
    Someone recommended I set a max earlier to help with the disconnects.  I'm happy to try anything to stop the clients from having issues.
    Currently ARP broadcast filtering is set for disabled - would you suggest enabling it?
    Currently I have
    Broadcast filtering disabled
    DTIM interval 1 beacon
    Multicast transmission optimization disabled
    Dynamic multicast optimization disabled
    DMO Channel utilization threshold 90%
    Transmit Rates
    2.4GHz min 12, max 54
    5GHz min 12, max 54
  • 17.  RE: Clients seem to randomly lose access
    Posted Nov 02, 2015 01:33 PM
    They recommended a max of 15 or 18. Power is logarothmic, so the power at 18 is half that of 21. 15 is a quarter of that.
  • 18.  RE: Clients seem to randomly lose access
    Posted Nov 02, 2015 01:40 PM
    I tried setting it to 18 and the clients complained they had even more issues.
  • 19.  RE: Clients seem to randomly lose access
    Posted Nov 02, 2015 01:42 PM
    I would open a tac case in parallel, because it seems we are not getting the full picture.
  • 20.  RE: Clients seem to randomly lose access
    Posted Nov 02, 2015 01:50 PM
    Thanks - I've opened a case... Trying to get any info at all from the client e.g. computer name, when they drop, are they stationary or moving...
    In the mean time would you suggest turning on arp filtering?
  • 21.  RE: Clients seem to randomly lose access
    Posted Nov 02, 2015 02:15 PM
    Broadcast filter ARP both suppresses broadcasts and does proxy ARP.  Unwanted Broadcasts decrease performance considerably, especially if you have wired and wireless clients in the same VLAN.
  • 22.  RE: Clients seem to randomly lose access
    Posted Nov 02, 2015 02:17 PM
    Good to know.
    The Wired and Wireless are on seperate vlans.
