Clients suddenly losing connection Wifi
  • 1.  Clients suddenly losing connection Wifi
    Posted Sep 21, 2022 11:06 PM
    Hi All,
    I'm running an 3x IAP-207 with version 8.10.0.3 LSR. Mostly phones but other clients as well will randomly drop connection from the AP but still showup in the AP admin interface. Am I misconfiguring something that would be causing this sort of issue. I'm using the default settings for the networks.
    My configuration :
    Attachment(s)
    txt
    conf.txt   3 KB 1 version
  • 2.  RE: Clients suddenly losing connection Wifi
    Posted Sep 22, 2022 04:49 AM
    Are those drops on both of your SSIDs?
    Do you see something in the logs around the time that you experience those disconnects?
  • 3.  RE: Clients suddenly losing connection Wifi
    Posted Sep 22, 2022 09:53 AM
    Try turning off dynamic multicast optimization on both SSIDs.  That could allow random local broadcasts under limited circumstances.
