cloning exisitng AP-group to new group
  • 1.  cloning exisitng AP-group to new group
    Posted Sep 19, 2019 06:48 AM
    While cloning an ap-group to new  does it copy all exisiting group config to new AP-group ?  that is , all virtual AP attached to old group will get copy to new ?
    Also can i then add new virtual AP to new ap-group which is containing all old group configuration ?
  • 2.  RE: cloning exisitng AP-group to new group
    Posted Sep 19, 2019 07:22 AM
    Hi Pawan,
    Yes all the profiles will be copied when you clone.
    A new profile can be added later on in addition to the existing profiles or to replace an existing one.
