I am trying to set up a Cloud Guest based authentication for my Guest SSID. I have the exact same configuration in all my GUEST SSIDs. However, only one of them works. I have checked the configuration summary and here is what I have found:
**Working:
** Not Working:
I am not able to find these parameters and change them to match the working one, I checked many times and I have the exact same config. Please note that both SSIDs are using the same Splash page.
Thanks in advance for your help.
Sinda FKAIER
