Cloud Guest with IAP-93s
  • 1.  Cloud Guest with IAP-93s
    Posted Apr 15, 2016 03:33 AM
    Hi everybody,
    Can I use Cloud Guest with IAP-93s? The current firmware of the IAP-93s is 6.4.2.6-4.1.1.11_52666. According to Aruba Central this is the latest available version, but for Cloud Guest IAP 4.1.2.x or higher is needed. We have a valide evaluation subscription key. At another location we have another virtual controller with IAP-103 and they have the latest firmware 6.4.4.3-4.2.2.0_53034 and I can select Cloud Guest. Any idea why there's no newer firmware showing up for the IAP-93? Can I initiate a firmware check via CLI?
    Thanks in advance.
    Best regards,
    Sven
  • 2.  RE: Cloud Guest with IAP-93s
    Posted Apr 15, 2016 01:36 PM
    No Support for IAP-92/93 Starting with 6.4.3.1-4.2.0.0 release, Instant does not support IAP-92/93 devices. Do not upgrade an IAP cluster containing IAP-92/93 devices to Instant 6.4.3.1-4.2.0.0 or later version. In case of an accidental upgrade, the IAPs will be automatically downgraded most of the time. You can also manually downgrade IAPs to an Instant 4.0 or 4.1 release, without losing the existing configuration.
    The above is from release notes of first 4.2 release, which supports cloud guest.
