Cloud Portal is Down
  • 1.  Cloud Portal is Down
    Posted Jan 30, 2014 03:04 AM
    CUrrently trying to setup something on using Central but the login portal is down.
    502 Bad Gateway.
  • 2.  RE: Cloud Portal is Down
    Posted Jan 30, 2014 03:42 AM
    Seems like it is back up and running. Fast but it should have a redundancy in place right?
  • 3.  RE: Cloud Portal is Down
    Posted Jan 30, 2014 07:34 AM
    Did you call support when it happened ?
  • 4.  RE: Cloud Portal is Down
    Posted Jan 30, 2014 12:45 PM
    Nope, but I can confirm it is down from where I am staying. Using 3 different ISP, I get the same error as mentioned. But before I can log a call after posting on AIrheads, it went back to normal. Strange, most likely someone is doing some sort of maintenance,
