Cloud service controllers don't need Instant AP in Remote Site?
  • 1.  Cloud service controllers don't need Instant AP in Remote Site?
    Posted Sep 17, 2014 08:51 AM
    Hello. I wonder the network deployment using cloud service controllers.
    If cloud service controllers(7005/7010) will be deployed in branch sites,
    can I install general APs for remote service, not instant APs ?
  • 2.  RE: Cloud service controllers don't need Instant AP in Remote Site?
    Posted Sep 17, 2014 09:23 AM
    Yes, I deploy smaller 7005/7010 controllers in branch offices for some situations (heavy Lync, etc). I do regular campus APs though since they're terminated on that controller.
  • 3.  RE: Cloud service controllers don't need Instant AP in Remote Site?
    Posted Sep 18, 2014 04:11 AM
    Thanks.
    I have another question.
    When 7005/7010 controllers will be installed in Branch offices, does it need to put mobility controller in HQ?
    In case of that, controllers in branch offices are operating as slave, and a controller in HQ operates as Master, is it right ?
    (Master means that it can config other controller(slave))
    Or, If not, are 7005/7010 controllers configured by Management System(Airwave in Center) ?
  • 4.  RE: Cloud service controllers don't need Instant AP in Remote Site?
    Posted Sep 23, 2014 04:39 AM
    Hi Jeewson!
    That depends on your needs. If you have common configuration on the branches I'd probably use a dedicated master in a central site, make it redundant if budget allows, and configure the branchcontrollers as locals(slave).
    Give each location their own AP-group where you specify them to terminate on the local controller in the AP system profile.
    The other option you're mentioning is running an "all-master" deployment where each location will operate as a standalone master, they could be centrally configured through Airwave. This is a less common way to do it, I'd say personally.
