CLP Audit SNMP trap and or SYSLOG Email notifcation
  • 1.  CLP Audit SNMP trap and or SYSLOG Email notifcation
    Posted May 15, 2024 06:30 PM
    Hello, I have doing research on creating a email notification process to send audit viewer logs and change differences in email form. I assume CLP does not have the same snmp config trap the same way Cisco switches do after reading the KBs about CLP specific snmp traps and MIBs. Therefore I can't use SolarWinds to send NCM emails with snmp traps.  I assume I cannot create a custom export filter  that will go through the email SMTP messaging service on CLP. I am assuming that I have work within a syslog configuration and the audit record template. I don't have a paid license for SolarWinds Kiwi syslog server. I do have Stellar which I could try to get setup to be a syslog server if possible to send those notification emails. I was wondering if anyone has anything kind of custom workaround to get audit records actions by admins to be sent by email without external syslog server in the middle.
    Best.
