What would be your use-case for large RAP clusters? For RAP, your controllers typically need to be reachable over the internet, so you will need a public IP for each of them, and as RAP typically has single AP sites, you could easily create multiple clusters to do the horizontally scaling.
I did not hear that ask before.
