Cluster join stuck at "Restore local node config failed."
  • 1.  Cluster join stuck at "Restore local node config failed."
    Posted 5 days ago
    Clearpass Cluster join stuck at "Restore local node config failed."
    Looks like the same as here: Airheads Community but down-sizing the MTU on both ends does not help.
    Trying with 6.12.0 and 6.12.2 - Joining from different sites. (Same Subnet -> no issue)
  • 2.  RE: Cluster join stuck at "Restore local node config failed."
    Posted 5 days ago
    Hi
    I have not run into this issue, but on the other hand we run all customers on 6.11. Just using 6.12 on some lab servers so far.
    In your case I would open a TAC case to get help in the troubleshooting.
    Best Regards
    Jonas Hammarbäck
    Aranya AB
  • 3.  RE: Cluster join stuck at "Restore local node config failed."
    Posted 5 days ago
    Okay - this does not help me out in any way...
  • 4.  RE: Cluster join stuck at "Restore local node config failed."
    Posted 2 days ago
    I ran into this same issue while migrating to 6.11 from 6.10. Found out I had to make sure within clusterwide parameters > standby publisher tab > Enable Publisher Failover =FALSE before taking the backup.
  • 5.  RE: Cluster join stuck at "Restore local node config failed."
    Posted 4 hours ago
    Okay - indeed i had a standby publisher before.
    Disabled that but still no luck.
    In the meantime i resetted the database on both ends (as this is not in production yet) - still no change.
    So at the moment I point it as network issue!? But how could I be sure?
