cluster L3-connected issue - implications for clients
  • 1.  cluster L3-connected issue - implications for clients
    Posted Oct 15, 2020 07:11 AM
    AOS 8.6.0.5
    10 MCs in cluster
    MM and standy MM
    We realised this morning that our cluster has been running in L3-Connected state. We're not sure for how long, but it could have been at least a week. It is fixed now (though I cannot explain how it ended up in L3 in the first place).
    My question is what kinds of issues would end users experience with the cluster in this state? We have the usual start of term noise with people having problems, but would like to get a feel for which kinds of problems we can put down as probably being caused by the cluster issue.
    Thank you,
    Guy
  • 2.  RE: cluster L3-connected issue - implications for clients
    Posted Oct 15, 2020 08:38 AM
    This typically happens when a VLAN or VLANs is not properly defined on the controller(s) or the VLAN is not properly defined on the uplink switch
    All cluster members will probe each VLAN for connectivity. If they do not see each other on every VLAN, except those configured here, they will only form a L3 cluster
    You can run the “ show lc-cluster vlan-probe status”
    Thank you
    Victor Fabian
    Pardon typos sent from Mobile
  • 3.  RE: cluster L3-connected issue - implications for clients
    Posted Oct 15, 2020 08:42 AM
    Thanks Victor,
    Actually we've already fixed the issue. My query was more about what kinds of issues it would have caused clients while in the L3 state. We have had a fair number of reports of poor wireless experience recently (though this isn't unusual at the start of term!) but what we wanted was to know what kinds of problems clients might have experienced as a result of the L3-Connected cluster issues (which have probably been going on for at least a week)?
    Thanks for your help with this,
    Guy
  • 4.  RE: cluster L3-connected issue - implications for clients
    Posted Oct 15, 2020 08:47 AM
    In an L3 state your cluster will not be capable of doing hitless failover
    Thank you
    Victor Fabian
  • 5.  RE: cluster L3-connected issue - implications for clients
    Posted Oct 15, 2020 08:52 AM
    Ah ok, so is this the only side-effect? ie clients shouldn't be affected in normal usage (outside of a failover)?
