Cluster management by controller
  • 1.  Cluster management by controller
    Posted Dec 17, 2014 08:02 AM
    Greetings dear colleges,
    Have plans to make such schema: few Instant clusters connected to controller as a RAP.
    Who knows what function will be possible to managed from the the controller on the cluster?
    Thanks in advance
  • 2.  RE: Cluster management by controller
    Posted Dec 17, 2014 08:04 AM
    You would manage the Instants via AirWave or Central. The controller simply handles the VPN tunnel termination and policy enforcement for tunneled traffic.
  • 3.  RE: Cluster management by controller
    Posted Dec 17, 2014 08:05 AM
    so as i understend all claster function could be managed from the controller as a single point of managemetn?!
  • 4.  RE: Cluster management by controller
    Posted Dec 17, 2014 08:22 AM
    No, you can manage the configuration locally on the instant vc, AirWave, or Central.
  • 5.  RE: Cluster management by controller
    Posted Dec 17, 2014 08:34 AM
    thanks for your help.
    Looks like it's absolutely the opposite to the opinion of tsd25108
  • 6.  RE: Cluster management by controller
    Posted Dec 17, 2014 08:20 AM
    No. The controller would only control the traffic that would traverse a VPN they terminates on it. All other settings must be controlled at the virtual controller on the IAP or via Airwave.
