Cluster Reference Could Not Be Released
  • 1.  Cluster Reference Could Not Be Released
    Posted Mar 25, 2019 01:47 PM
    Attempting to rebuild my cluster for CoA. I can't remove my second Cluster member..WHY. I'll be blowing it away I guess but I'd like to know for future the reasoning..
  • 2.  RE: Cluster Reference Could Not Be Released
    Posted Mar 25, 2019 02:40 PM
    Was it first removed from the cluster config above it?
  • 3.  RE: Cluster Reference Could Not Be Released
    Posted Mar 25, 2019 02:46 PM
    I can't delete it from the Cluster config in the group.
    Error: Can not delete cluster profile as cluster group-membership with profile 'Cluster1' exists at node Managed Network > The-Beatles > Cluster-1 > 00:0c:29:c1:fc:36
    So I attempt to remove the Cluster membership config from the MC itself...
    Cluster reference could not be released.
  • 4.  RE: Cluster Reference Could Not Be Released
    Posted Jul 15, 2019 03:07 AM
    Any solutions for this? I have the same issue.
  • 5.  RE: Cluster Reference Could Not Be Released
    Posted Jul 15, 2019 10:18 AM
    For all who may have the same issue:
    The reason is a change of the group names in the Managed Devices section. If you change the group name after assigning a mobility controller to that group where the mobility controller is part of a cluster, the cluster configuration of the controller cannot be changed anymore.
    Changing the group name back will enable you to change the Mobility controller cluster configuration.
    For this reason, I highly recommend to think about the group naming in advance.
    Moreover it would be nice to have a mechanism implemented that prevents to change the group name.
  • 6.  RE: Cluster Reference Could Not Be Released
    Posted Aug 14, 2019 01:42 PM
    This is not the case with my setup.  Are there any other possible solutions to this error.  1 cluster member I can remove, the other I cannot.
  • 7.  RE: Cluster Reference Could Not Be Released
    Posted Aug 15, 2019 02:50 PM
    Hey,
    Having the same problem here, running 8.4.0.0 in a lab. Can't find a solution (CLI or GUI).
    It is not possible to delete the controller from the MM because it is in the cluster...
    appreciate any thoughts.
  • 8.  RE: Cluster Reference Could Not Be Released
    Posted Aug 15, 2019 02:55 PM
    I was able to resolve this be rebooting the MM controllers.  It was just a lab setup so no big deal.
  • 9.  RE: Cluster Reference Could Not Be Released
    Posted Aug 15, 2019 02:58 PM
    Thanks! I will try!
  • 10.  RE: Cluster Reference Could Not Be Released
    Posted Aug 15, 2019 05:12 PM
    That worked! although I had to boot both MMs at the same time. Previous attempts with one at a time did not solve the issue. Thanks again!
