cluster upgrade from 6.3.0 to 6.5.0
  • 1.  cluster upgrade from 6.3.0 to 6.5.0
    Posted Sep 07, 2015 10:08 AM
    Hi dears,
    I have to upgrade a ClearPass Cluster, version 6.3.x to 6.5.0 version.
    I think that I have to do the following:
    1) Install the Patch 6.3.6 on all members (Need I to broke the cluster?)
    2) Install on the publisher node the Cluster Upgrade tools
    3) Download on the publsher node the 6.5.0 image.
    I don't need to edit the virtual disk of the Virtual Appliance?
    In the release note of 6.5.0 i found:
    "VM only: If you have two disks already loaded with previous ClearPass versions—for example, 6.2 on SCSI
    0:1 and 6.3 on SCSI 0:2—then drop the inactive disk before upgrading. You must then add a newer disk
    based on the 6.5 disk requirements."
    But in the Cluster Upgrade Tool Guide, there isn't any note about it.
    Can you help to understand the correct steps to upgrade my cluster?
    Thnaks in advance
    Andrea
  • 2.  RE: cluster upgrade from 6.3.0 to 6.5.0
    Posted Sep 13, 2015 11:19 AM
    how big is just cluster? i have done a few small cluster upgrades and i don't use the cluster upgrade tool at all. just do the publisher first and then the subscribers, worked out fine.
    as for the disks, if you started from 6.3 you are fine i believe. this is from earlier instalation when only one disk of 250 gb was added. if you have one of 500 gb you don't have to drop anything.
  • 3.  RE: cluster upgrade from 6.3.0 to 6.5.0
    Posted Sep 13, 2015 12:35 PM
    to add to boneyard -
    If your already on the 6.3 code train you have the new disk config layout so that issue is mute.
    Yes, please ensure you upgrade ALL nodes to 6.3.6 [no need to break the cluster], and again as advised by boneyard, upgrade the PUB first followed by the SUB's in your cluster.
    My recommendation is that you then run for 7-10 days on 6.3.6 to ensure everything is good before you plan your outage to upgrade to 6.5.0.
  • 4.  RE: cluster upgrade from 6.3.0 to 6.5.0
    Posted Sep 14, 2015 07:10 AM
    HI ,
    the cluster is composed by two nodes .
    I have upgraded it succesfully.
    But after some days the appliance starts a particular behavior.
    The publisher node goes down randomly and i have to reboot it becouse it became unreachable.
    any ideas?
    regards
    Andrea
  • 5.  RE: cluster upgrade from 6.3.0 to 6.5.0
    Posted Sep 14, 2015 11:47 AM
    Based upon the symptoms you are better creating a TAC case.
  • 6.  RE: cluster upgrade from 6.3.0 to 6.5.0
    Posted Sep 17, 2015 06:25 AM
    Yes,
    I opened a ticket some day ago.
    I will update you with solution.
    Regards
    Andrea
  • 7.  RE: cluster upgrade from 6.3.0 to 6.5.0
    Posted Oct 19, 2015 01:45 PM
    did TAC come up with something Andrea?
  • 8.  RE: cluster upgrade from 6.3.0 to 6.5.0
    Posted Oct 20, 2015 06:52 AM
    support doesn't found a root cause of the issue.
    The issue seems to been solved aftet a shutdown of the Virtual Appliance.
    We think that in this manner the database has been re-initialized.
    Regards
    Andrea
