Hi
I have two nodes want to configure them as primary and secondary cluster, so;
-can I configure VIP floating between the two nodes (active in primary)?
- if VIP is supported, then is it recommended to configure it or keep each node with different IPs?
- Is there a preempt option in cluster, that the primary (publisher) will be the primary whenever its active?
