  • 1.  Clustering
    Posted Feb 05, 2018 02:41 PM
    Can someone please explain clustering to me and how it works?  I don't see anything in Aruba Central that deals with a "Cluster".
    Basically I have 10 IAPs that will be deployed in our main HQ on VLAN1 (172.16.0.0/16).  Each SSID will have a different VLAN (100, 110, 120, etc...) and the networks and switching side have already been built, configured and they're working fine.
    At each remote site will be 2 or 3 IAPs that will use the same SSIDs, but will be on a different network (192.168.xxx.0/24).  I was told I need to build out different clusters for each site, but I have no idea how to do this... can someone please help?
  • 2.  RE: Clustering
    Posted Feb 05, 2018 04:20 PM
  • 3.  RE: Clustering
    Posted Feb 05, 2018 04:45 PM
    IAP Cluster:
    All IAPs in same layer 2 domain will automtically join a group known as cluster.
    Plug in the first IAP and configure it (Master IAP).
    Add the remaining IAPs in the same layer 2 domain (Slave IAPs).
    The configuration will be synched from Master IAP to Slave IAPs
    Repeat the same procedure for remote site where you have 2-3 IAPs
    Refer to the video link posted by "cjoseph" above
