CN failure on certificate "name$"
  • 1.  CN failure on certificate "name$"
    Posted Dec 03, 2015 01:43 PM
    I'm getting a CN failure in CP using EAP-TLS. The Certificate is failing b/c name is being returned as name$. if I use "Strip Username Rules" can i strip that character off when configuring the service? The User Manual just does not explain it well.
    what is format if doable? Or even better send me a more detailed faq
  • 2.  RE: CN failure on certificate "name$"
    Posted Dec 03, 2015 01:45 PM
    name$ is valid for machine account.
    Are you using Onboard or ADCS?
    Can you post a screenshot of the error?
    Are you doing cert authorization or just authentication?
  • 3.  RE: CN failure on certificate "name$"
    Posted Dec 03, 2015 01:52 PM
    2015-11-30 09:09:48,688 [Th 1 Req 3124 SessId R00000226-01-565c58ac] INFO RadiusServer.Radius - rlm_eap_tls: Certificate CN (Computers) does not match specified value (DFC-HP$)
    No onboard. Just authentication at this point
  • 4.  RE: CN failure on certificate "name$"
    Posted Dec 03, 2015 02:14 PM
    Where is the certificate issued from?
    Please try creating a new EAP-TLS authentication method and unchecking authorization required, add it to your service and test authentication again.
