CoA and Guest - NAS Type / CoA Type?
  • 1.  CoA and Guest - NAS Type / CoA Type?
    Posted Jan 20, 2019 11:03 AM
    Hi there,
    I wonder how does "CoA" works with Guest?
    I see under "Configuration > Authentication" the option for "Dynamic Authorization" with a NAS Type Option.
    Say I have multiple NAS from different brands. How will this work, given that I can only select one "NAS Type" for all the Guest installation.
    Also, say I add a "change_of_authorization" field to a form. What CoA type and NAS will the guest system use? Cisco, Aruba, Generic? Bounce, Terminate, Reauth? I'm puzzled.
  • 2.  RE: CoA and Guest - NAS Type / CoA Type?
    Posted Jan 20, 2019 12:16 PM
    What are you trying to do? Policy Manager handles mostly everything for Dynamic Authorization.
    The field in the form simply generates a request that you can write policy against.
  • 3.  RE: CoA and Guest - NAS Type / CoA Type?
    Posted Jan 21, 2019 05:35 AM
    I see.
    Can you shortly explain how can I "glue" the field to the Policy Manager?
    What kind of service should I create, and how does it work?
    What I'm trying to do is:
    - Send a CoA reauth when a user creates or edits a mactrac device
    - Send a CoA terminate when the user deletes the mactrac device
  • 4.  RE: CoA and Guest - NAS Type / CoA Type?
    Posted Jan 21, 2019 12:25 PM
    Requests are only generated on a device registration create event. Use the screenshots below for that service.
    Guest will automatically try to make a CoA-Request when the role is changed in the form. Guest will look for the role name in a Dynamic Authorization Enforcement Profile Name and if found, will attempt to make the request.
    Screen Shot 2019-01-21 at 12.24.17 PM.pngScreen Shot 2019-01-21 at 12.24.23 PM.png
  • 5.  RE: CoA and Guest - NAS Type / CoA Type?
    Posted Jan 21, 2019 01:19 PM
    Hi Tim,
    Thanks for your patience.
    That solution works perfectly.
    But I still have some doubts:
    - Is there no option to also send CoA when I edit the device?
    - What is the use of the "change_of_authorization" field? Will it only work for mac_create?
    - When I remove the mactrac device I do not see anything on Policy Manager. How does the disconnect works in this case?
    - What is the use for Configuration > Authentication > Dynamic Authorization,  and how does it work when I have multiple different NAS types?
  • 6.  RE: CoA and Guest - NAS Type / CoA Type?
    Posted Jan 21, 2019 02:01 PM
    >> WEBAUTH requests are only generated during a device create event.
    >> This is what triggers the WEBAUTH. It's only used with Device Registration.
    >> As mentioned, it's only on create.
    >> It's not used.
  • 7.  RE: CoA and Guest - NAS Type / CoA Type?
    Posted Sep 06, 2020 08:36 AM
    Any change of explaining this better?
    Edit: https://www.arubanetworks.com/techdocs/ClearPass/6.6/Guest/Content/GuestManagement/ManagingGuestAccounts_changeRole.htm
