  • 1.  CoA Extreme
    Posted Jun 03, 2014 08:43 PM
    Hi, I´m trying to send a CoA to 2 Extreme´s Wireless controllers. (I´m using ClearPass 6.3)
    One of them is using RFC 3576 and the other is RFC 5176. so I want to know witch combinations of options I need to send to do a Terminate of Session.
    I know that for Aruba I use this
    Radius:IETFCalling-Station-Id=%{Radius:IETF:Calling-Station-Id}
    And ClearPass doesn´t have a predefined template for Extreme.
    Thanks in advance.
  • 2.  RE: CoA Extreme
    Posted Jun 03, 2014 11:51 PM
    It should just be a standard IETF.
  • 3.  RE: CoA Extreme
    Posted Jun 04, 2014 08:48 AM
    Ok, thank you.
    I will try it.
    I need the calling station id or only with the terminate session?
    Sorry but I have zero experience with CoA.
    Regars.
  • 4.  RE: CoA Extreme
    Posted Jun 04, 2014 08:59 AM
    Use template Motorola. In wireless controller extreme Networks you need activate coa
  • 5.  RE: CoA Extreme
    Posted Apr 21, 2015 12:57 AM
    Is there a document/datasheet that states that RFC 5176 is supported in 6.3.x or 6.4.x firmware? ____
    I could not find it... Pls share if you do :)
  • 6.  RE: CoA Extreme
    Posted Apr 21, 2015 12:47 PM
    From the research I have just done, the difference between RFC 3576 and RFC 5176 is that 5176 introduced CoA as opposed to Disconnect Messages.
    See:
    http://tools.ietf.org/html/rfc5176#section-2.2
    We definitely support CoA, not just DM. So, I think you are good to go. If you require more proof, it is on page 210 of the 6.2 User Guide: http://community.arubanetworks.com/aruba/attachments/aruba/aaa-nac-guest-access-byod/9259/1/Aruba_CPPM_User_Guide.pdf
    "Enable RADIUS CoA
    RADIUS CoA Port
    Enable RADIUS Change of Authorization (RFC 3576/5176) for this device. Set the UDP port on the device to send CoA actions. Default value is 3799."
  • 7.  RE: CoA Extreme
    Posted Apr 23, 2015 12:01 AM
    Hi Zach,
    I saw it in the 6.5 CPPM UG as well.
    I'm just curious why it was not showing in the 6.3.x or 6.4.x controller User Guides...
  • 8.  RE: CoA Extreme
    Posted Apr 23, 2015 09:42 AM
    I'm not sure either.
    I think we just stick with the older RFC number due to name recognition. Most people know what RFC 3576 is but not RFC 5176.
