  • 1.  CoA Fails
    Posted Feb 01, 2013 04:10 PM
    I'm testing CoA over Aruba wireless and it's failing.  The following message is logged in access tracker: Session-Context-Not-Found.
    I've verified the following:
    CPPM: In device details, RADIUS CoA is enabled and using port 3799.
    Controller: RFC3746 server defined in AAA profile. Key matches key specific in device details above.
    Any thoughts on troubleshooting this further?
  • 2.  RE: CoA Fails
    Posted Feb 01, 2013 04:14 PM
    Are you going into the access tracker and doing something like "Terminate Session"?  What are you doing to generate this COA?  Session not found normally means that the device never authenticated, so there is no session to "change".
    Edit: Also, do you have Radius Accounting enabled from the controller to CPPM?
  • 3.  RE: CoA Fails
    Posted Feb 01, 2013 04:21 PM
    Yeah, I'm going into access tracker and clicking on the connection.  Then Change Status and I issue an Aruba Terminate Session.
    To be sure I'm working with an active session, I disconnected my test device and reconnected it.  Then, I terminated the connection that just appeared in access tracker.  I received the same error message.
  • 4.  RE: CoA Fails
    Posted Feb 04, 2013 06:19 PM
    CoA started working today.  The only thing I did was change the NAS IP on each controller to match its loopback IP.  Before, each controller inherited the master's IP as the NAS IP.  Could this be what fixed it?
  • 5.  RE: CoA Fails
    Posted Feb 09, 2013 09:46 AM
    yes, that could very well be it, i worked with CoA in the past (different context; Juniper switches) and not having the correct NAS IP was the issue back then also.
  • 6.  RE: CoA Fails
    Posted Nov 18, 2013 01:44 AM
    Your solution saved my day!!
    Thank you!!!
    Bharani..
