CoA issue with IAP 215 and CPPM
  • 1.  CoA issue with IAP 215 and CPPM
    Posted Sep 16, 2015 04:22 PM
    When we set CoA to use 3799 it says successful for Aruba Terminate Session, but doesnt actually bounce the client
    When we set CoA to use 5999 then it says it cannot reach the network device.
    Do we need to select the clearpass server under  services > Air Group?
    Also, we noticed when we modified the port under Security, it changes but if we go in under the ssid, it still had the old settings.
  • 2.  RE: CoA issue with IAP 215 and CPPM
    Posted Sep 16, 2015 04:42 PM
    We had mistakently set Airgroup CoA and normal to the same.  CoA needs to be 3799 in Clearpass and AirGroup CoA needed to be 5999.  We also changed to source radius to be from the AP rather than from the VC.  All worked now.
