It was for AOS-CX, threads got changed. For AOS configuration you mentioned is correct. Check the pcap from CISCO ISE and check what was missing.
Original Message:
Sent: Mar 14, 2023 01:59 AM
Subject: CoA Port Bounce with Cisco ISE and Aruba 2530
does this applyes to version 16.11 for AOS-S??
Original Message:
Sent: Mar 13, 2023 12:16 AM
ou have to enable this CLI for radius dyn authorization
radius dyn-authorization enable
radius dyn-authorization client {<IPV4> | <IPV6> | <HOSTNAME>}
[secret-key [plaintext <PASSKEY> | ciphertext] <PASSKEY>]]
[time-window <WIDTH>] [replay-protection {enable|disable}]
More details here -
https://www.arubanetworks.com/techdocs/AOS-CX/10.08/HTML/security_6200-6300-6400/Content/Chp_RAD_dyn_auth/RAD_dyn_auth_cmds/rad-dyn-aut-com-fl-10.html
Shobana
Aruba
Original Message:
Sent: Mar 10, 2023 09:48 AM
i just got the config from the setich and the command
tell me if you see anything incorrect thanks for the help
Original Message:
Sent: Feb 27, 2023 10:39 AM
i will havwe access to the switch soon to get those commands
Original Message:
Sent: Feb 27, 2023 06:32 AM
Topic mentions 2530 which would be similar to 2930F for CoA perspective.
Can you see if the CoA reaches the switch?
show radius dyn-authorization
Original Message:
Sent: Feb 23, 2023 06:27 PM
with what switch were you working im using a ARUBA2930f-48g-4sfp with this configuration on ISE but is not working for me what im trying to do is a port bounce and assing a new ACL on a 802.1x Client that already had a ACL assing via VSA 92 before.
can you giveme any clue
Original Message:
Sent: Nov 16, 2020 07:26 AM
Hi Tom,
thanks for the reply.
I did not try your settings, but today a got the following settings from Cisco TAC and they worked for my.
Probably, there is more than one setting that works.
Joerg Dallhammer
Original Message:
Sent: Nov 14, 2020 11:38 PM
Hi Joerg,
I spent today working on a homelab involving Cisco ISE at https://kd9cpb.com/aruba-captive-portal, which refreshed my memory about the CoA config in the network device profile. Try removing RADIUS: Event-Timestamp and replace with NAS-Port-ID in the RFC 5176 section. I seem to remember this was something Aruba TAC had me try when I was first getting started with captive portals. I don't know if you might need to remove or change the port bounce settings; never needed that for my wired guest setup.
Original Message:
Sent: Nov 09, 2020 09:21 AM
Hi Victor,
the Radius server is not a Clearpass, it is a Cisco ISE. It seems that the ISE configuration causes the issue.
Time sync is ok.
Regards
Joerg
Joerg Dallhammer
Original Message:
Sent: Nov 09, 2020 09:18 AM
is the time in sync between the switch and clearpass?
Are you using a VIP in CLearPass? if so, do you also have it defined ?
Have you tried taking a packet capture from ClearPass and on the switch as well?
Victor Fabian
Original Message:
Sent: Nov 09, 2020 09:10 AM
Hi Tom,
Radius was configured properly.
Unfortunately, the debug output doesn´t give a hint, which attribute is missing.
Regards
Joerg
Joerg Dallhammer
Original Message:
Sent: Nov 04, 2020 04:42 PM
Hi Joerg,
I had similar issues at first trying to get ISE talking with ArubaOS-Switch. Here's a couple quick things to try:
1. Make sure you have accounting turned on (aaa accounting network start-stop radius) otherwise ISE might not track the RADIUS session properly. Took a very long, very painful TAC for me to learn that lesson.
2. Try "debug security radius-server" to see if you get any additional insight into the NAK
Best of luck!
Tom
kd9cpb.com/homelab
Original Message:
Sent: Nov 03, 2020 11:33 AM
I am actually trying to implemement profiling with the Cisco ISE (2.7 patch2) and Aruba 2530 (SW 16.10.011).
After profiling the devices, the ISE sends a CoA POrt Bounce to the switch.
But I am still getting a "Missing attribute" back from the switch.
On the switch, I have configured the following for CoA:
radius-server host <IP-address> key <Some Pass>
radius-server host <IP-address> dyn-authorization
radius-server host <IP-address> time-window 0
The CoA-NAKs increase with every attempt.
On the ISE, I have configured the following for the device profile:
Joerg Dallhammer
