CoA with Instants
  • 1.  CoA with Instants
    Posted Oct 08, 2014 11:54 AM
    We are running latest CPPM code 6.4.1.30651 and Aruba Instant code 6.4.2.0
    We are trying to implement CoA to force clients to re-authenticate after a certain
    time period.
    The problem is we see this working with Aruba controller code but NOT with instant.
    Any ideas?
    cheers
    Pete
  • 2.  RE: CoA with Instants
    Posted Oct 08, 2014 12:16 PM
    From ClearPass you can set an radius attribute with session-timeout on the enforcement profile
  • 3.  RE: CoA with Instants
    Posted Oct 08, 2014 12:18 PM
    If you use session-timeout, make sure you have RADIUS accounting enabled.
  • 4.  RE: CoA with Instants
    Posted Oct 08, 2014 12:19 PM
    Valid point by cappalli..
  • 5.  RE: CoA with Instants
    Posted Oct 08, 2014 12:23 PM
    Thanks for reply.
    We have accounting enabled and all works fine, but we have to issue a CoA at specific times
    for the solution to work.
    My question is does CoA work between Instants and CPPM?
    cheers
    pete
    p.s. works great with controller
  • 6.  RE: CoA with Instants
    Posted Oct 08, 2014 12:33 PM
    Yes, CoA should work with Instant. Can you try to manually issue a CoA from access tracker and see if it gives you an error?
  • 7.  RE: CoA with Instants
    Posted Oct 08, 2014 12:35 PM
    already tried that same result.
  • 8.  RE: CoA with Instants
    Posted Oct 08, 2014 12:37 PM
    What does it say in ClearPass when you do it?
    Successful, administratively prohibited or session context not found?
  • 9.  RE: CoA with Instants
    Posted Oct 08, 2014 12:41 PM
    Tim,
    extract from CPPM Access Tracker,
    Date and Time Oct 08, 2014 13:10:22 BST
    Application Name Policy Manager
    RADIUS CoA Action Type Disconnect
    RADIUS CoA Action Name [Aruba Terminate Session]
    Status Code 0
    Status Message Radius [Aruba Terminate Session] failed for client 00224360da63
    RADIUS CoA Attributes Calling-Station-Id = 00224360da63
  • 10.  RE: CoA with Instants
    Posted Oct 08, 2014 12:55 PM
    yes that is enabled
  • 11.  RE: CoA with Instants
    Posted Oct 08, 2014 02:23 PM
    Tim,
    just to let you know we are sourcing the radius traffic from the DRP IP address
    not from the VC. All radius traffic works fine with this but i am wondering if the
    CoA works with this.
  • 12.  RE: CoA with Instants
    Posted Oct 08, 2014 12:52 PM
    Do you have RFC 3576 enabled in your RADIUS server configuration in Instant?
