COA - works from CPG, won't work from [Aruba Terminate Session]
  • 1.  COA - works from CPG, won't work from [Aruba Terminate Session]
    Posted Aug 28, 2017 09:17 AM
    I'm trying to setup a Service in CPPM to disconnect a device (macauth) after WebAuth via the [Aruba Terminate Session].  The service is accepted once the device is registered, but the system stays in the preauth role on the controller.  I can successfully Disconnect devices on the controller via CPG, which I presume means the rfc-3576-server CoA is working correctly, and the device is successfully booted from the role.
    Am I missing something simple, or am I mistaken that CPG Disconnect is not using the same mechanism as the [Aruba Terminate Session] profile?
    thanks
    mike
  • 2.  RE: COA - works from CPG, won't work from [Aruba Terminate Session]
    Posted Aug 28, 2017 09:20 AM
    Does it work manually from access tracker for the same client?
    Are you returning a REJECT or ACCEPT on the initial MAC auth?
  • 3.  RE: COA - works from CPG, won't work from [Aruba Terminate Session]
    Posted Aug 28, 2017 09:44 AM
    (Thanks for responding Tim, I'm trying to get your DEVICE-REG_DM-COA working from the educause Wireless-LAN group email)
    It does work manually from Access Tracker
    The default profile on the macauth service is [Drop Access Profile] which
    has the Drop action.  The Access Tracker details has:
    Post-Auth-Check:Action   Disconnect
    and
    MAC-AUTH: MAC Authentication attempted by unknown client, rejected.
    thanks
    mike
  • 4.  RE: COA - works from CPG, won't work from [Aruba Terminate Session]
    Posted Aug 28, 2017 09:49 AM
    Your MAC auth service should be using Allow All MAC Auth and returning a captive portal role for unknown devices.
    Can you post screenshots of the request hitting the DM-COA WebAuth service?
  • 5.  RE: COA - works from CPG, won't work from [Aruba Terminate Session]
    Posted Aug 28, 2017 10:05 AM
    OK, that makes this more than a minor change..    Here's the screenshot..
    thanks
    mike
  • 6.  RE: COA - works from CPG, won't work from [Aruba Terminate Session]
    Posted Aug 28, 2017 10:13 AM
    Why do you have 2 terminate sessions there? What is "UD [Terminate Session]?
  • 7.  RE: COA - works from CPG, won't work from [Aruba Terminate Session]
    Posted Aug 28, 2017 10:23 AM
    After the default terminate didn't work, I copied it and only included the local controllers in the list and added that also...
  • 8.  RE: COA - works from CPG, won't work from [Aruba Terminate Session]
    Posted Aug 28, 2017 10:27 AM
    I'm not following that. Can you post a screenshot? You should only be using the default [Aruba Terminate Session].
  • 9.  RE: COA - works from CPG, won't work from [Aruba Terminate Session]
    Posted Aug 28, 2017 10:43 AM
    It was just an initial troubleshooting test, since we have both local and eduroam federation controllers listed, I wanted to make sure the eduroam list wasn't causing the terminate to end abnormally so I copied the profile and listed only the local controllers.  I've removed it now..
  • 10.  RE: COA - works from CPG, won't work from [Aruba Terminate Session]
    Posted Aug 28, 2017 02:33 PM
    "Your MAC auth service should be using Allow All MAC Auth and returning a captive portal role for unknown devices."
    Are there examples of this anywhere?  I've gone through the wizard and made several attempts modifying that service for mine but not having any luck.
    thanks
    mike
  • 11.  RE: COA - works from CPG, won't work from [Aruba Terminate Session]
    Posted Aug 28, 2017 03:22 PM
    If you look at the original MAC auth request after the device was registered, do you see a CoA tab?
  • 12.  RE: COA - works from CPG, won't work from [Aruba Terminate Session]
    Posted Aug 29, 2017 06:44 AM
    That's the problem, there never is another mac auth request after the device was registered, it just sits in the initial-role stupid but content. The WEBAUTH source is setup to do the Aruba Terminate Session, but nothing ever happens.
    "You need to use Allow All MAC Auth and add a fail through rule that returns your captive portal role."
    The macauth wizard didn't make anything resembling a captive portal role, so I'm flying blind trying to understand your references here and other posts on the subject.  I was able to modify the standard enforcement policy from the default days-of-the-week to something that properly sets the authenticated devices into the correct role, but the fail
    through rule to a captive portal role doesn't seem to happen.
    Screen Shot 2017-08-29 at 6.40.16 AM.pngScreen Shot 2017-08-29 at 6.40.36 AM.png
  • 13.  RE: COA - works from CPG, won't work from [Aruba Terminate Session]
    Posted Aug 29, 2017 09:10 AM
    Sorry, I didn't see the forest for the trees on this one (I'll blame move-in week stress)  Once I changed the Service Authentication Method from the default MAC AUTH to Allow All MAC AUTH, everything started working as expected...
    thanks
    mike
  • 14.  RE: COA - works from CPG, won't work from [Aruba Terminate Session]
    Posted Aug 29, 2017 09:16 AM
    Mike,
    You may want to tweak your MAC auth service. The guest service templates aren't really designed for headless device authentication so you have a lot of profiles in there that aren't designed for this.
    Here is an example of a multi-use guest + headless MAC authentication service. Ignore rules 2-4, they're just for testing.
