Combine Aruba Mobility Controller to support more AP
  • 1.  Combine Aruba Mobility Controller to support more AP
    Posted Nov 25, 2020 03:12 AM
    Hi, is it possible to combine 2 Aruba Mobility Controller to support more AP? For example, the customer has Aruba 7010 in the environment, they want to add more than 32 APs.
    Can I add another Aruba 7005 so that they can add another 16 AP, all the AP under the same management?
    Thank you.
    Wei Kwong Ong
  • 2.  RE: Combine Aruba Mobility Controller to support more AP
    MVP GURU
    Posted Nov 25, 2020 08:13 AM
    You could, but you may put yourself in a situation where you over subscribe a controller if the other fails. Best practice for redundancy is to make sure you have another controller/controllers that can take the full AP/Client load.
    Dustin Burns
  • 3.  RE: Combine Aruba Mobility Controller to support more AP
    Posted Nov 26, 2020 08:41 AM
    Yes, of course you can, and you can add a MM above the controllers and make use of its benefits
    https://www.arubanetworks.com/products/wireless/gateways-and-controllers/mobility-conductor/
    Take into account the Dustin's recommendation as well.
    Julian Ortiz
