combine variables
  • 1.  combine variables
    Posted Nov 08, 2018 05:50 AM
    I'm testing clearpass. Authentication works with our AD.
    We have 25 Aruba switch stacks and 5 types of Workstations with different names like PC-W1, PC-W2 .. PC-W5.
    For each Workstation type we want to use a different VLAN.
    Stack 1   PC-W1      VLAN 11
    Stack 1   PC-W2      VLAN 12
    Stack 2   PC-W1      VLAN 21
    Stack 2   PC-W2      VLAN 22
    I don't want to make a lot of policies.
    By devices I can use an attribute and put an value in it. By example for Stack 1 I made a custom attribute Vlan-Prefix=1
    In the policy I want to combine the VLAN-Prefix with a number. By Example:
    If Stack 1 and PC-W2 -> combine the VLAN-Prefix (1) + 2. The policy wille then use 12 for the VLAN.
    If Stack 2 and PC-W4 -> combine the VLAN-Prefix (2) + 4. The policy wille then use 24 for the VLAN.
    Is something like this possible?
    Mark
  • 2.  RE: combine variables
    Posted Nov 08, 2018 06:37 AM
    Yes, you can apply it. You can for example save an attribute for each NAS and used it en the enforcement. You can combine it with other attribute too.
    In this example you can save an attribute in the NAS:Screen Shot 2018-11-08 at 12.30.02.png
     An other attribute in the Endpoint:
     The enforcement looks like this:
     And this is the result:
  • 3.  RE: combine variables
    Posted Nov 08, 2018 07:31 AM
    It works with my custom attribute %{device:Vlan Prefix}
  • 4.  RE: combine variables
    Posted Nov 08, 2018 06:49 AM
    not exactly what you asked for, but maybe something below helps...
    (hopefully I understood you right)
    First idea:
    Instead of combining prefixes and suffixes just send enforcement profile.
    The way you are thinking about below, you already have to define 125 if clauses (25 Stacks multiplied by 5 workstation types). If you also define 125 enformcement profiles for the different VLANs, you do not need the prefix thing...
    if NAS=Stack1 and AD-Group=PCW1 then VLANID=11
    if NAS=Stack1 and AD-Group=PCW2 then VLANID=12
    if NAS=Stack25 and AD-Group=PCW5 then VLANID=255
    Second idea: (depends on model and version of your switch)
    name the five VLANs identical on the stacks and pass vlan by name.
    Stack1, VLANID 11, VLAN-Name PC-W1-VLAN
    Stack 25, VLANid 255, VLAN-Name PC-W1-VLAN
    then you simply need 5 if clauses:
    if AD-Group=PC-W1 then VLAN-Name=PC-W1-VLAN
    if AD-Group=PC-W5 then VLAN-Name=PCW5-VLAN
    I didn't test this myself. But others did.
    Search community to find information on this.
    One reference: https://community.arubanetworks.com/t5/Security/Assign-Tagged-VLAN-via-Radius-attribute-using-quot-HP-Egress/m-p/274863/highlight/true#M27509
    The answer of networkingsire shows information about assignement by name.
    Third idea: (depends on model and version of your switch)
    Use the new aruba role features of newer switches. define roles for the 5 pc types on the stacks and assign vlans to the roles as needed.
    Again you just need 5 if clauses to assing the roles.
    if AD-Group=PC-W1 then Role=PC-W1-Role
    if AD-Group=PC-W5 then Role=PC-W5-Role
    What you cannot use this way is downloadable roles to download them from clearpass. You'd need 125 different roles and if clauses again to do this. (each stack needs to download its own set of roles...)
    Regards, Jö
