Commands that reset ap?
  • 1.  Commands that reset ap?
    Posted Nov 16, 2017 06:00 PM
    I need to remove old bkup-lms-ip entries on ap system-profiles. Does the "no bkup-lms-ip" command cause APs to reset?
    I see this listed on the commands that reset APs, but I wasn't sure if the bkup ip also would since the "lms-ip" does.
    "ap system-profile {bootstrap-threshold |lms-ip |master-ip }"
    and for the sake of asking, does removing dns-domain in the ap system-profile cause a reset as well? I didn't see it mentioned in the docs.
  • 2.  RE: Commands that reset ap?
    Posted Nov 16, 2017 11:22 PM
     If the AP is on the backup LMS, changing the backup LMS ip address will make it move to that ip address immediately.
    The dns-domain is for split-tunneled RAPs and should not affect a Campus AP.
  • 3.  RE: Commands that reset ap?
    Posted Nov 17, 2017 01:57 PM
    So it would only cause a reset if the AP was actively connected to backup lms.
    In my case the backup lms ip goes nowhere anymore since the controller has been removed. This is a cleanup task I'm looking to preform.
  • 4.  RE: Commands that reset ap?
    Posted Nov 17, 2017 03:01 PM
    Nothing would happen if the AP is not on the backup LMS.
