Hello everybody.
I have theses two switches, 3Com 4500 and 3Com 2928.
3Com 4500 - IP: 20.20.X.X ; Mask: 255.255.240.0
3Com 2928 - IP: 192.168.1.X; Mask: 255.255.255.0
And a printer(20.20.2.1) connected in the switch 3Com 4500 and i need access this printer from the devices on the 3Com 2928. I already tried to make a trunk between the switches, and the same Vlan(Vlan 100) in theses two switches one with interface and another without interface, and enable IP Routing, but doesn't work.
I dont know if this is good practice or not, but i did this way...
I create 2 Vlans in each switches
Switch A:
Vlan 255 - 10.5.0.1; 255.255.255.0
Vlan 100 - 192.168.100.2; 255.255.255.0
Swtich B:
Vlan 255 - 10.5.0.2; 255.255.255.0
Vlan 200 - 172.168.200.2; 255.255.255.0
So i create this routes:
Switch A:
10.5.0.1 - 255.255.255. - 10.5.0.2
172.16.200.2 - 255.255.255.0 - 10.5.0.2
Switch B :
10.5.0.2 - 255.255.255. - 10.5.0.1
192.168.100.2 - 255.255.255.0 - 10.5.0.1
Now the Switch A can ping i the switch and the vlans of the "B" and "vice versa". But i can't ping from Vlan 1 in any other vlan.
#switch#3Com#VLAN#routing
