Communication between 2 MACOS device on same SSID
  • 1.  Communication between 2 MACOS device on same SSID
    Posted Apr 30, 2018 03:57 AM
    Hello
    this is my problem
    i have 2 device on mac os 1 ipad , 1 mac mini
    this two device get a ip by the WIFI so it's ok, but the end user use a application on ipad  and this application dont work it use bonjour proccess
    i check the the airgroup, it's enable
    when i check AirGroup Blocked Service IDs
    i see the ip of the device with the service
    I check also Deny inter user traffic is not checked
    i check also BC/MC Rate Optimization is not check
    How i check is the mdns is block by the wifi controller ?
    my question is can i add this service on the airgroup service already present on the controler and make work good this application ?
    Thank by advance for your feed back
    Perly
  • 2.  RE: Communication between 2 MACOS device on same SSID
    Posted Apr 30, 2018 03:59 AM
    The wifi controler is 3600  on 6.3.1.3 os
  • 3.  RE: Communication between 2 MACOS device on same SSID
    Posted Apr 30, 2018 04:03 AM
    Please see here:  http://community.arubanetworks.com/t5/Controller-Based-WLANs/What-are-the-AirGroup-service-IDs-required-to-allow-casting-via/ta-p/340268 for an example.
    The blocked service id command is how you check to see if specific traffic is being blocked.
