Network Management
Communication between IAP and AirWave over SNMP
  • 1.  Communication between IAP and AirWave over SNMP
    Posted May 18, 2017 09:55 AM
    Good morning guys,
    I have set up a cluster of Instant APs and communicate with AirWave properly over HTTPS (as I have read recently). If the communication is over HTTPS, do I need to configure SNMP for anything else? What advantages do I have if I configure SNMP for communication between the cluster and AirWave?
    Julián
  • 2.  RE: Communication between IAP and AirWave over SNMP
    Posted May 18, 2017 10:04 AM
    You should not need to configure it over SNMP at all.  If you had a third-party system that you wanted to do SNMP reads from, that is why you would setup SNMP.  Airwave does not need/use SNMP for instant.
  • 3.  RE: Communication between IAP and AirWave over SNMP
    Posted May 18, 2017 11:11 AM
    Hi Colin,
    Clear, thanks!
    Julián
  • 4.  RE: Communication between IAP and AirWave over SNMP
    Posted May 23, 2017 12:32 PM
    Hi Colin,
    One more thing about this. I have an alert in AirWave which is
    If AirWave doesn't use SNMP for Instant and in addition I have configured nothing related to SNMP in my Instant cluster, why do I receive this alert which seems to be related to SNMP?
    Julián
  • 5.  RE: Communication between IAP and AirWave over SNMP
    Posted Jun 21, 2017 06:51 PM
    I believe the iAP sends the traps to Airwave along with syslog data and other telemetry - all wrapped in HTTPS.
  • 6.  RE: Communication between IAP and AirWave over SNMP
    Posted Jun 22, 2017 05:44 AM
    Yes, that is right. As Mathew mentioned IAP sends traps along with the other data send over https. If we dont have Airwave set as a trap receiver on IAP also we would get these data by default through https.
  • 7.  RE: Communication between IAP and AirWave over SNMP
    Posted Jun 22, 2017 10:58 AM
    That's right, but I think the Trigger Summary field comes to confusion. Then I think it should be changed from "SNMP Trap Category is Hardware or SNMP Trap Category is Software" to "HTTPS Trap Category is Hardware or HTTPS Trap Category is Software".
    Julián
