We suppose you (a) assigned an IP address to each of your VLANs defined on your Aruba 2930F (let we suppose you assigned 10.0.1.254/24 to VLAN 1, 10.0.2.254/24 to VLAN 2, 10.0.3.254/24 to VLAN 3...and so on up to 10.0.6.254/24 to VLAN 6) and (b) you enabled IP routing (see ip routing command).
If you did that each message of any host of a particular VLAN (say Host A of VLAN 1) - if the host is properly addresses (with an IP Address set within the 10.0.1.0/24 subnet and Default Gateway set to 10.0.1.254) - will be correctly routed to any other host of another VLAN (say Host B of VLAN 3, example of VLAN 3 host: 10.0.3.x/24 with D.G 10.0.3.254 and Host B with IP address 10.0.3.y and Default Gateway 10.0.3.254). Clearly you must deal with proper settings IF OS Firewalls interfere with ICMP Ping or other protocols/ports.
Can you report about that? ...that's the essential minimum to have inter-VLANs communication.
