Comodo Certificates Expiry
  • 1.  Comodo Certificates Expiry
    Posted Jun 01, 2020 04:00 AM
    Hi, I have been hit by  Comodo AddTrust Root Expiration.
    The certificate chain has expired - I know very little about certificates and I wondered if anyone could help restoring the comodo certificate chain.
    I can access clearpass because it not has not expired on browsers.  But the access tracker shows nothing because the trust is gone.
    Or a work around for it?
  • 2.  RE: Comodo Certificates Expiry
    MVP EXPERT
    Posted Jun 01, 2020 04:04 AM
    If the current certificate is signed by the Root CA (which I suspect it is) you will also need to renew the certificate via Comodo too.
    You can download the current Root & Intermediate CAs from Comdo for below, these will need to be uploaded to CPPM prior uploading a new certificate.
    https://support.comodo.com/index.php?/comodo/Knowledgebase/List/Index/75/instantsslenterprisesslintranetssl
    There is an excellent Tech Note regarding certificates which details how to obtain a CSR, certificate types and the best practices for different CPPM deployments.
    CPPM - Certificates 101 Technote V1.2.pdf
    *EDIT* - Added correct Tech Note link
  • 3.  RE: Comodo Certificates Expiry
    Posted Jun 01, 2020 04:14 AM
    Hello
    I am afraid that link takes you to the old certificates that have expired. I am confused.
  • 4.  RE: Comodo Certificates Expiry
    MVP EXPERT
    Posted Jun 01, 2020 04:16 AM
    Have you reached out to Comodo then to request the new Root/Intermediate certs? Once you have these certs, Comodo will need to sign your certificate in order for it to be valid.
  • 5.  RE: Comodo Certificates Expiry
    Posted Jun 01, 2020 06:41 AM
    Comodo now known as sectigo, now uses a 3 step certificate chain instead of four.  After the 30th of may the old certificates are no longer valid.
    Managed to put the three certificates into a new certificate chain and imported it into clearpass.
    The subscriber needed a services restart but back to normal again.
    Browsers and devices usually handle this themselves, but you have to do it manually on clearpass.
    I live and learn
    Thanks!
    PS Thanks TAC team
  • 6.  RE: Comodo Certificates Expiry
    MVP EXPERT
    Posted Jun 01, 2020 06:56 AM
    Glad to hear it is sorted!
