Compare Template
  • 1.  Compare Template
    Posted Mar 26, 2013 08:21 AM
    I have a problem with a command each AP , this command is different for each AP and these APs I have them in a group with a template. Is there a command for me not to compare this line? When I compare it I get the AP is mismatched.
    Regards
  • 2.  RE: Compare Template
    Posted Mar 26, 2013 12:10 PM
    Look at the UserGuide - for 7.5 it's on page 163 "Using Directives to Eliminate Reporting of Configuration Mismatches"
    The command I think you want is:
    <ignore_and_do_not_push>
  • 3.  RE: Compare Template
    Posted Mar 26, 2013 12:12 PM
    On the template edit page, there's a section to the right that describes some possible template flags you can use:
    <ignore_and_do_not_push></ignore_and_do_not_push> and []
    <push_and_exclude></push_and_exclude> and ()
    These tags can be used to achieve a good configuration.
    Please refer to the User Guide for more information.
    For items unique to that device type, you will want to make sure you have an ignore line and a separate push line (especially if you use AMP to manage device config).
    If it's a specific item for a single device, you may also want to use the ap_include variables.
