Hi, you're comparing too different switch series even if the core role could be easily performed by both of them (with differences on the ways each one achieves resiliency, at various levels).
Just consider for a moment the concept of (standalone) chassis resiliency achieveable by using two Management Modules working in a fully redundant operation...this is a supported configuration of Aruba 5400R zl2 switch series and it's not available on Aruba 8320 Switch series (there isn't such type of modularity on Aruba 8320 chassis...because that series was not engineered to provide a "cpu-failsafe" approach *that* way but it relies on using two Aruba 8320 in VSX cluster <- the same approach is possible deploying two Aruba 5400R zl2 as a VSF cluster and, indeed, in such configuration both Aruba 5400R zl2 will disable the dual MMs functionality on each chassis, if any).
As you can see, first there are a lot of considerations (pro versus cons) to be carefully analyzed on the table...and also available budget is important too....not to forget the network topology and desired (or current) characteristics.
For unskilled networking team use the KISS approach keeping both eyes wide open on items like redundancy/resiliency of operations and (day to day) management simplicity.
