comparison ruckus r700 vs IAP-32P
  • 1.  comparison ruckus r700 vs IAP-32P
    Posted Feb 23, 2016 12:13 PM
    Can any  one suggest that ruckus  R700 controller based is bette solution or  IAP-325 controller less  is better  solution
  • 2.  RE: comparison ruckus r700 vs IAP-32P
    Posted Feb 23, 2016 12:19 PM
    Please work with your Aruba or partner account team.
  • 3.  RE: comparison ruckus r700 vs IAP-32P
    Posted Feb 23, 2016 12:41 PM
    Easy... Aruba, but I have a biased opinion.
    The IAPs are extremely adequate for an enterprise environment, but without knowing more about your requirements its hard to give you exact reasons why it would be beneficial for your deployment.
