Community Feedback
How is the community doing? Do you have any questions or feedback related for the Airheads Community team? This is the place to let us know.
Compatibilidad SFP CISCO CON 5400 Aruba
  • 1.  Compatibilidad SFP CISCO CON 5400 Aruba
    Posted Feb 04, 2020 08:53 AM
    Hola, existe algun documento donde pueda verificar la compatibilidad de estos tranceivers de CISCO con los Aruba 5400R..?
    GLC-SX-MMD
    GLC-LH-SMD
    GLC-SX-MMD
    GLC-TE
    SFP-10G-LR-S
    SFP-10GBase-SR
    GLC-T
  • 2.  RE: Compatibilidad SFP CISCO CON 5400 Aruba
    MVP GURU
    Posted Mar 07, 2020 05:45 PM
    Hi! what do you mean with "compatibility"? are you planning to use CISCO Transceiver into HPE Aruba 5400R zl2 Switch? ...if so forget better.
    Aruba supports its own HPE Aruba Transceivers...the ArubaOS-Switch operating system allows unsupported transceivers (just a reference here) BUT this absolutely doesn't mean that HPE Aruba is granting you they will work (as original supported ones) and/or they will not damage your HPE Aruba Switch during use (read: they can work but then, if something broke or doesn't work as you expect, anything bad that could happen related to unsupported Transceivers is up to you...no grant, no support...or very limited).
    If - instead - you're asking: I will use Cisco on Cisco and Aruba on Aruba...then I will interconnect Cisco and Aruba by means of a fiber optic cable...then no issue...provided that you match the type of Transceivers (media/speed)...so, as example, a Cisco SFP+ Short Range Transceiver will connect to an Aruba SFP+ Short Range Transceiver through a good OM3 Fibre Optic Multi-Mode cable...that's just an example.
