Below is console output from the AP. The web gui redirects to the current cluster master, but doesn't load on the AP IP and SSH is not connecting. Confirmed the switch port and vlan config is the same for each AP.
The console output continues with !!! Init ---> Member
passed
SHA2 Signature available
Signer Cert OK
Policy Cert OK
RSA signature verified using SHA2.
Uncompressing Kernel Image ... OK
[ 0.000000]
[ 0.000000] Aruba Networks
[ 0.000000] ArubaOS Version 8.11.0.1-8.11.0.1 (build 85785 / label #85785)
[ 0.000000] Built by jenkins@pr-hpn-cd-build39 on 2022-12-15 at 00:23:12 PST (gcc version 4.6.3)
[ 0.000000]
[ 0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c5387d
[ 0.016603] SMP: Total of 4 processors activated (384.00 BogoMIPS).
[ 0.052328] i2c-gpio driver registered
[ 17.139916] 3 ofpart partitions found on MTD device 7980000.qcom,nand
[ 17.206804] Creating 3 MTD partitions on "7980000.qcom,nand":
[ 17.275552] 0x000000000000-0x000002000000 : "aos0"
[ 17.375316] 0x000002000000-0x000004000000 : "aos1"
[ 17.462578] 0x000004000000-0x000008000000 : "ubifs"
[ 17.599380] m25p80 spi0.0: found w25q32, expected n25q128a11
[ 17.694828] Found AT97SC3203 on MSM-I2C-v2-adapter
[ 17.750458] Key type dns_resolver registered
[ 17.790786] Registering SWP/SWPB emulation handler
[ 19.134046] There is no gpio reset info
[ 19.230129]
Starting Kernel SHA1 KAT ...
[ 19.264607] Completed Kernel SHA1 KAT
[ 19.311452] Starting Kernel HMAC-SHA1 KAT ...
[ 19.361662] Starting Kernel DES KAT ...[ 19.407340] Completed Kernel DES KAT
[ 19.451145] Starting Kernel AES KAT ...
[ 19.494856] Completed Kernel AES KAT
[ 19.494856]
[ 19.558373] Starting Kernel AESGCM KAT ...
[ 19.605197] Completed Kernel AESGCM KAT
[ 19.654448] Completed Kernel HMAC-SHA1 KAT
Thu Jan 1 00:00:00 PST 1970
Populate AP type info
Domain Name: SetMeUp.arubanetworks.com
Current OEM Name : Aruba Networks
Disabling ipv6 for devices by default
AP-type has_ble_support: ONBOARD.
IPv6 capability is supported for devices
No panic info available
Enabling ble_daemon and ble_relay via nanny
glenmorangie: Start hotplug
per-ap-setting not in backup and restore mode, Backup ENV.
Installing glenmorangie ethernet driver
[ 32.907238] edma module_init
Enter non-FIPS mode
Cfg len is 965
no SSID detected...
uap controller less detected
Mesh enabled
single uplink platform
Starting watchdog process...
Aruba watchdog daemon started [4 thread(s)]
Loading configuration file of length 965...
wifi uplink not present...
No valid ssid was found...
extended ssid activate due to no valid ssid ...
touching file /tmp/ip_mode_0
[ 38.995344] bond0: GMAC Link is up with phy_speed=1000
error in reading source file
Mesh is DISABLED on this device.
extended ssid is activated on the platform ...
copying bootuplog ...
[ 39.830652] uol: module license 'Proprietary' taints kernel.
[ 39.894652] Disabling lock debugging due to kernel taint
[ 39.959687] uol_init_driver:434 HW offload not applicable, AP will use cutting through path!
allow PAPI
set device anul0 mtu to 2000
notify asap_mod 3g no present...
Starting update SBL1 ...
SBL1 was updated already
Done.
apdot1x authentication is not enabled
LLDP not sent yet, DHCP is waiting
Starting DHCP
Getting an IP address...
Jan 1 00:00:24 udhcpc[4225]: udhcpc (v0.9.9-pre) started
Jan 1 00:00:24 udhcpc[4225]: send_discover: pkt num 0, secs 0
Jan 1 00:00:24 udhcpc[4225]: Sending discover...
Jan 1 00:00:24 udhcpc[4225]: send_selecting: pkt num 0, secs 0
Jan 1 00:00:24 udhcpc[4225]: Sending select for 192.168.1.180...
Jan 1 00:00:24 udhcpc[4225]: Lease of 192.168.1.180 obtained, lease time 60000000
[ 45.152063] ip_time_handler: Got ip and packets on bond0 Started conductor election 3-0, rand 21
[ 45.970221] (08:00:26) !!! Init ---> Member
192.168.1.180 255.255.255.0 192.168.1.200
Compressing all files in the /etc/httpd directory...
Done.
Starting Webserver
bind: Transport endpoint is not connected
Put ntpdate to the nannylist.
AP rebooted caused by cold HW reset(power loss)
shutting down watchdog process (nanny will restart it)...
<<<<< Welcome to the Access Point >>>>>
Completed SW FIPS KAT test
Power supply mode is POE:, USB Modem is not present.
User: [ 77.002024] Starting Kernel HMAC SHA1 FIPS KAT ...
[ 77.044816] Completed Kernel HMAC SHA1 FIPS KAT
[ 79.008029] Starting Kernel HMAC SHA256 FIPS KAT ...
[ 79.052918] Completed Kernel HMAC SHA256 FIPS KAT
ble_ready NOT present @init ....
[ 81.008056] Starting Kernel HMAC SHA384 FIPS KAT ...
[ 81.052974] Completed Kernel HMAC SHA384 FIPS KAT
[ 83.008039] Starting Kernel HMAC SHA512 FIPS KAT ...
[ 83.052943] Completed Kernel HMAC SHA512 FIPS KAT
Firmware AES-CCM Known Answer Test Passed
[ 104.703446] asap_send_elected_conductor: sent successfully
[ 104.970390] asap_send_elected_conductor: sent successfully
[ 106.970351] (15:07:08) !!! Init ---> Member
[ 107.970332] (15:07:09) !!! Init ---> Member
[ 108.970358] (15:07:10) !!! Init ---> Member
[ 109.970363] (15:07:11) !!! Init ---> Member
[ 110.970387] (15:07:12) !!! Init ---> Member
[ 111.970364] (15:07:13) !!! Init ---> Member
[ 112.970348] (15:07:14) !!! Init ---> Member
[ 113.970374] (15:07:15) !!! Init ---> Member
[ 114.970373] (15:07:16) !!! Init ---> Member
[ 115.970369] (15:07:17) !!! Init ---> Member
[ 116.970406] (15:07:18) !!! Init ---> Member
[ 117.970381] (15:07:19) !!! Init ---> Member
[ 118.970384] (15:07:20) !!! Init ---> Member
[ 119.970390] (15:07:21) !!! Init ---> Member
[ 120.970396] (15:07:22) !!! Init ---> Member
[ 121.970395] (15:07:23) !!! Init ---> Member
[ 122.970393] (15:07:24) !!! Init ---> Member
[ 123.970402] (15:07:25) !!! Init ---> Member
[ 124.970402] (15:07:26) !!! Init ---> Member
[ 125.970406] (15:07:27) !!! Init ---> Member
[ 126.970413] (15:07:28) !!! Init ---> Member
[ 127.970410] (15:07:29) !!! Init ---> Member
[ 128.970422] (15:07:30) !!! Init ---> Member
[ 129.970407] (15:07:31) !!! Init ---> Member
Original Message:
Sent: Mar 07, 2023 09:42 AM
Subject: Compatibility 303 and 365
I have done a factory reset, but I will try again and post results.
Are there any settings that aren't cleared on a factory reset?
Mike
Original Message:
Sent: Mar 06, 2023 11:30 AM
If they can run the same version of OS, then they can cluster. Have you tried to factory reset the outdoor AP. Make sure its in the same VLAN as the other APs when its booting back up for the first time.
Dustin Burns
ACCX 1271| ACMX 509| ACSP | ACDA | MVP Guru 2022-2023
Original Message:
Sent: Mar 06, 2023 10:29 AM
Hey all,
I have 3 303 indoor APs in an IAP cluster and a 'new' 365 I need to put outside (they are all used APs that I have factory reset). I've got them all on the most current 8.11.0.1_85785 firmware, but I can't get the 365 to join the 303 cluster. Before I post more details I just want to make sure these models are compatible.
Should they be able to be in the same cluster?
What's strange is that when I go to the 365 IP, it redirects to the cluster master, but it doesn't show in the cluster and doesn't have the shared config if I ssh to it.
I have confirmed they all have different IPs from DHCP reservations.
Mike
