Compatibility aruba 103 and 204 on the same network !!!
  • 1.  Compatibility aruba 103 and 204 on the same network !!!
    Posted May 23, 2016 05:15 PM
    Hi all,
    Currently I configured an IAP 103 and IAP 204 on the same network but on my virtual controler i can't see the IAP 103, I see IAP103 has not the same firmware but when i tried to change the firmware (same that IAP204) i cannot migrate firmware.
    Do you know a solution for me?
    Thank you in advance.
    Best regards
    chabin972
  • 2.  RE: Compatibility aruba 103 and 204 on the same network !!!
    Posted May 23, 2016 05:17 PM
    Before you join it to the cluster you need to make sure both IAPs are on the same firmware version
  • 3.  RE: Compatibility aruba 103 and 204 on the same network !!!
    Posted May 23, 2016 09:06 PM
    Thanks for your reply, it's one of my problem I can't make the same firmware of 204 on my 103, When I tried to make the firmware update the action is ok but the firmware doesn't change.
    I Will Check again tomorrow
  • 4.  RE: Compatibility aruba 103 and 204 on the same network !!!
    Posted May 23, 2016 11:09 PM
    Chabin_972,
    Here is what you do:
    Obtain the same version of code for both 103 and 204 here:  http://support.arubanetworks.com/LifetimeWarrantySoftware/tabid/121/DMXModule/661/EntryId/20388/Default.aspx
    Reset the 103, and upgrade the firmware manually.  Do the same thing with the 204 separately.  Reset the 103 and introduce it to the same subnet as the 204 and see if it joins the cluster with the 204.
  • 5.  RE: Compatibility aruba 103 and 204 on the same network !!!
    Posted May 24, 2016 06:37 AM
    had the same problem with an 205 and a 103. firware update solves the issue
    #AirheadsMobile
