Wired Intelligent Edge
Compatibility Cisco QSFP-40/100-SRBD transceiver with Aruba 40G QSFP+ LC BiDi 150m MMF
  • 1.  Compatibility Cisco QSFP-40/100-SRBD transceiver with Aruba 40G QSFP+ LC BiDi 150m MMF
    Posted Apr 17, 2019 06:43 AM
    I have to connect an 8320 with Aruba 40G QSFP+ LC BiDi 150m MMF (JL308A) with a Cisco Nexus which use the Cisco QSFP-40/100-SRBD transceiver.
    Due to the datasheet the Aruba transceiver works with 850 nm
    and Cisco works with 855 nm
    Is it possible to build up a link between those transceiver?
    Frank
  • 2.  RE: Compatibility Cisco QSFP-40/100-SRBD transceiver with Aruba 40G QSFP+ LC BiDi 150m MMF
    Posted Apr 17, 2019 09:45 PM
    Hi Frank,
    As far as I know, nowadays 40GE bidirectional transceivers are prorietary, they do not follow a IEEE standard, so the only way to know if the transceivers you mentioned work together it is trying them on the field.
    Regards
  • 3.  RE: Compatibility Cisco QSFP-40/100-SRBD transceiver with Aruba 40G QSFP+ LC BiDi 150m MMF
    Posted Dec 10, 2021 10:15 AM
    did you try the transcivers. Are they working together on the same line?
    Regards
    Tomas
    Tomas Nohejl
